I'm currently experiencing the "Time to next event = x seconds" error when trying to view events. When viewing an event you get a few frames of footage out of order then periodic black frames with the text "Time to next event = x seconds".
I've searched and found a few old forum topics highlighting this error with the following suggested solutions:
- Set all monitor buffer settings back to default (check)
- Need to repair your mysql database with both 'mysqlcheck' or via phpmyadmin (check)
- Make sure mysql timezone matches the system timezone/time (check)
None of these has resolved the error for me. I've also checked both mysql and zoneminder logs at the time events are triggered and see no errors at all.
Wondering if anyone could suggestion other possible solutions or things I can check?
Thanks in advance
Time to next event error
Re: Time to next event error
I'm getting the same symptoms on my zoneminder install. One interesting thing I can add is that if you look at the frame data every frame has a duplicate with a timestamp off by some set amount of time. This time varies by quite a bit, I haven't seen a pattern to it. The other timestamp is correct.
Anyone have any ideas?
FRAME ID TYPE TIME STAMP TIME DELTA SCORE
1 Normal 03:19:15 0.00 0
1 Normal 14:05:06 0.00 0
2 Normal 14:05:06 0.03 0
2 Normal 03:19:15 0.09 0
3 Normal 14:05:06 0.08 0
3 Normal 03:19:15 0.29 0
4 Normal 03:19:15 0.38 0
4 Normal 14:05:06 0.10 0
5 Normal 03:19:15 0.50 0
5 Normal 14:05:06 0.14 0
