Zoneminder crashed
mattionline
Zoneminder crashed
Post by mattionline » Sun May 07, 2017 11:47 am
this night zoneminder crashed.
Does anybody know why this happened?
At 13:41 i started zm and now its working again.
My last event was at 05/06 22:59:40 so im a bit confused why it is capturing at 01:44:01.
Thanks for help
ZM 1.30.2 Ubuntu iconnors ppa
2017-05-07 13:41:07.394005	zms		13444	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x555739950bb9]	zm_signal.cpp	102
2017-05-07 13:41:07.371704	zms		13445	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x555625c6ebb9]	zm_signal.cpp	102
2017-05-07 13:41:07.371595	zms		13443	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x55a182370bb9]	zm_signal.cpp	102
2017-05-07 13:41:07.349402	zms		13444	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fc274dbe830]	zm_signal.cpp	102
2017-05-07 13:41:07.327209	zms		13445	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f0124b62830]	zm_signal.cpp	102
2017-05-07 13:41:07.327023	zms		13443	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fe8e566f830]	zm_signal.cpp	102
2017-05-07 13:41:07.297409	zms		13444	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x55573994fe01]	zm_signal.cpp	102
2017-05-07 13:41:07.226961	zms		13445	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x555625c6de01]	zm_signal.cpp	102
2017-05-07 13:41:07.226717	zms		13443	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x55a18236fe01]	zm_signal.cpp	102
2017-05-07 13:41:07.204296	zms		13444	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x555739989648]	zm_signal.cpp	102
2017-05-07 13:41:07.182122	zms		13445	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x555625ca7648]	zm_signal.cpp	102
2017-05-07 13:41:07.181906	zms		13443	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x55a1823a9648]	zm_signal.cpp	102
2017-05-07 13:41:07.159715	zms		13443	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55a18239c9ad]	zm_signal.cpp	102
2017-05-07 13:41:07.159669	zms		13444	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55573997c9ad]	zm_signal.cpp	102
2017-05-07 13:41:07.137463	zms		13445	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x555625c9a9ad]	zm_signal.cpp	102
2017-05-07 13:41:07.113979	zms		13443	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fe8e8f7d390]	zm_signal.cpp	102
2017-05-07 13:41:07.113841	zms		13444	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fc2786cc390]	zm_signal.cpp	102
2017-05-07 13:41:07.091461	zms		13445	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f0128470390]	zm_signal.cpp	102
2017-05-07 13:41:07.069187	zms		13443	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55a1823efbb8]	zm_signal.cpp	102
2017-05-07 13:41:07.069100	zms		13444	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5557399cfbb8]	zm_signal.cpp	102
2017-05-07 13:41:07.031299	zms		13445	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x555625cedbb8]	zm_signal.cpp	102
2017-05-07 13:41:07.031022	zms		13444	ERR	Signal address is 0x4, from 0x55573997c9ad	zm_signal.cpp	81
2017-05-07 13:41:06.964570	zms		13443	ERR	Signal address is 0x4, from 0x55a18239c9ad	zm_signal.cpp	81
2017-05-07 13:41:06.963787	zms		13445	ERR	Signal address is 0x4, from 0x555625c9a9ad	zm_signal.cpp	81
2017-05-07 13:41:06.894852	zms		13444	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-05-07 13:41:06.894653	zms		13445	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-05-07 13:41:06.833938	zms		13443	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-05-07 13:41:06.603529	zms		13445	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-05-07 13:41:06.603504	zms		13444	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-05-07 13:41:06.599924	zms		13443	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-05-07 01:46:53.079738	zmc_m2		9300	ERR	Unable to get response, disconnecting	zm_remote_camera_http.cpp	1141
2017-05-07 01:46:47.902019	zmc_m2		9300	ERR	Unable to read subheader	zm_remote_camera_http.cpp	977
2017-05-07 01:46:42.037693	zmc_m2		9300	ERR	Select error: Interrupted system call	zm_remote_camera_http.cpp	175
2017-05-07 01:46:33.935192	zmc_m2		9300	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-05-07 01:46:33.935128	zmc_m1		18126	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-05-07 01:46:33.934598	zmc_m3		18783	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-05-07 01:46:33.934569	zma_m1		17711	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-05-07 01:46:33.934525	zma_m3		7894	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-05-07 01:46:30.300980	zmpkg		18800	INF	Command: stop	zmpkg.pl
2017-05-07 01:46:25.040310	zmpkg		18800	INF	Sanity checking States table...	zmpkg.pl
2017-05-07 01:46:22.267046	zmc_m2		9300	INF	Haustuer: 396000 - Capturing at 7.09 fps	zm_monitor.cpp	3125
2017-05-07 01:46:15.239020	zmdc		6791	INF	'zma -m 2' exited normally	zmdc.pl
2017-05-07 01:46:15.237238	zmc_m2		9300	WAR	Last image read from shared memory 1494114375 seconds ago, zma may have gone away	zm_monitor.cpp	3100
2017-05-07 01:46:10.153053	zmc_m2		9300	WAR	Buffer overrun at index 46, image 395996, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-05-07 01:46:09.738150	zmdc		6791	WAR	'zma -m 2' has not stopped at 17/05/07 01:46:09. Sending KILL to pid 9343	zmdc.pl
2017-05-07 01:46:09.004294	zmc_m3		18783	INF	Priming capture from rtsp://username:password@192.168.2.141:88/videoMain	zm_ffmpeg_camera.cpp	104
2017-05-07 01:46:03.737586	zma_m2		9343	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-05-07 01:45:51.745697	zmc_m3		18783	INF	Starting Capture version 1.30.2	zmc.cpp	250
2017-05-07 01:45:51.738580	zmdc		6791	INF	'zma -m 2' sending stop to pid 9343 at 17/05/07 01:45:51	zmdc.pl
2017-05-07 01:45:46.667610	zmdc		6791	INF	'zmc -m 3' starting at 17/05/07 01:45:46, pid = 18783	zmdc.pl
2017-05-07 01:45:46.667550	zmdc		18783	INF	'zmc -m 3' started at 17/05/07 01:45:46	zmdc.pl
2017-05-07 01:45:46.665170	zmwatch		6867	INF	Restarting analysis daemon for Haustuer	zmwatch.pl
2017-05-07 01:45:46.665157	zmc_m2		9300	WAR	Last image read from shared memory 11 seconds ago, zma may have gone away	zm_monitor.cpp	3100
2017-05-07 01:45:44.820368	zma_m2		9343	WAR	Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size	zm_monitor.cpp	1324
2017-05-07 01:45:42.163538	zmc_m2		9300	WAR	Buffer overrun at index 29, image 395779, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-05-07 01:45:41.214480	zmwatch		6867	INF	Analysis daemon for Haustuer needs restarting, time since last analysis 6 seconds (1494114341-1494114335)	zmwatch.pl
2017-05-07 01:45:36.018160	zmdc		6791	INF	Starting pending process, zmc -m 3	zmdc.pl
2017-05-07 01:45:35.861806	zma_m2		9343	INF	Haustuer: 395000 - Analysing at 7.69 fps	zm_monitor.cpp	1296
2017-05-07 01:45:26.858420	zmdc		6791	INF	'zmc -m 3' exited, signal 14	zmdc.pl
2017-05-07 01:45:23.797723	zmc_m3		18766	INF	Starting Capture version 1.30.2	zmc.cpp	250
2017-05-07 01:45:21.663250	zmdc		6791	INF	'zmc -m 3' sending stop to pid 18766 at 17/05/07 01:45:21	zmdc.pl
2017-05-07 01:45:18.723570	zmdc		6791	INF	'zmc -m 3' starting at 17/05/07 01:45:18, pid = 18766	zmdc.pl
2017-05-07 01:45:18.723450	zmdc		18766	INF	'zmc -m 3' started at 17/05/07 01:45:18	zmdc.pl
2017-05-07 01:45:16.714520	zmdc		6791	INF	Starting pending process, zmc -m 3	zmdc.pl
2017-05-07 01:45:05.977590	zmdc		6791	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2017-05-07 01:45:05.941490	zmwatch		6867	INF	Restarting capture daemon for Autos, shared data not valid	zmwatch.pl
2017-05-07 01:45:02.844870	zmwatch		6867	ERR	Memory map file '/dev/shm/zm.mmap.3' does not exist. zmc might not be running.	zmwatch.pl
2017-05-07 01:44:56.603650	zmdc		6791	INF	'zmc -m 3' starting at 17/05/07 01:44:56, pid = 18750	zmdc.pl
2017-05-07 01:44:56.603610	zmdc		18750	INF	'zmc -m 3' started at 17/05/07 01:44:56	zmdc.pl
2017-05-07 01:44:52.941740	zmdc		6791	INF	Starting pending process, zmc -m 3	zmdc.pl
2017-05-07 01:44:48.779160	zmdc		6791	INF	'zmc -m 3' exited normally	zmdc.pl
2017-05-07 01:44:44.709695	zmc_m3		6851	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-05-07 01:44:38.692660	zmdc		6791	INF	'zmc -m 3' sending stop to pid 6851 at 17/05/07 01:44:38	zmdc.pl
2017-05-07 01:44:35.351620	zmwatch		6867	INF	Restarting capture daemon for Autos, time since last capture 6 seconds (1494114275-1494114269)	zmwatch.pl
2017-05-07 01:44:29.868604	zmc_m3		6851	INF	Autos: 3849000 - Capturing at 2.64 fps	zm_monitor.cpp	3125
2017-05-07 01:44:01.415801	zmc_m2		9300	INF	Haustuer: 395000 - Capturing at 7.75 fps	zm_monitor.cpp	3125
2017-05-07 01:43:25.299417	zma_m2		9343	INF	Haustuer: 394000 - Analysing at 7.41 fps	zm_monitor.cpp	1296
2017-05-07 01:41:52.274272	zmc_m2		9300	INF	Haustuer: 394000 - Capturing at 7.75 fps	zm_monitor.cpp	3125
My Personal Blog: https://mattionline.de
Re: Zoneminder crashed
Post by bbunge » Sun May 07, 2017 11:53 am
Check for free space in /dev/shm.
mattionline
Post by mattionline » Sun May 07, 2017 2:45 pm
Now it is at:
tmpfs 7.8G 528M 7.3G 7% /dev/shm
I also configured an icinga2 check to monitor it if it happens again.
Thanks for your help.
Post by iconnor » Sun May 07, 2017 10:32 pm
Looks like zmwatch restarted the zmc process. While the zmc proces was restarting zms was crashing because it couldn't talk to zmc.
mattionline
Post by mattionline » Mon Jun 05, 2017 7:07 pm
my zoneminder crashed one more time. Here are the logs:
I also saw in my monitoring that the load was higher that normal and after 9 hours it was normalizing.
My shm graph didn't worked correctly so i can't say if it was full. I fixed the monitoring and now i hope that i can reproduce the problem to fix it.
Does anybody have an idea what i can do to fix this problem?
Times:
2017-06-04 00:58:21 - crash
2017-06-05 14:40:24 - start zoneminder button in webinterface
I also saw the line
2017-06-05 15:07:12.449762 zmc_m2 15248 INF Haustuer: 12000 - Capturing at 7.69 fps
in the logs and saw that in the events there isn't a entry between 06/05 14:45:05 and 06/05 15:15:40 (clicked on day view, so this are all events for today). Does anybody know why it is capturing and there is no recorded event?
2017-06-05 15:38:07.576198 	zma_m1
	15237 	INF 	HintermHaus: 17000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:38:04.311066 	zmc_m1
	15232 	INF 	HintermHaus: 17000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:37:44.443878 	zma_m3
	15262 	INF 	Autos: 27000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:37:38.037328 	zmc_m3
	15257 	INF 	Autos: 27000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:37:24.074853 	zma_m2
	15249 	INF 	Haustuer: 26000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-05 15:37:22.417717 	zmc_m2
	15248 	INF 	Haustuer: 26000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:35:39.543912 	zma_m3
	15262 	INF 	Autos: 26000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:35:33.147348 	zmc_m3
	15257 	INF 	Autos: 26000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:35:14.960635 	zma_m2
	15249 	INF 	Haustuer: 25000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:35:13.260939 	zmc_m2
	15248 	INF 	Haustuer: 25000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-05 15:34:47.739171 	zma_m1
	15237 	INF 	HintermHaus: 16000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:34:44.500351 	zmc_m1
	15232 	INF 	HintermHaus: 16000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:33:34.656047 	zma_m3
	15262 	INF 	Autos: 25000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:33:28.238837 	zmc_m3
	15257 	INF 	Autos: 25000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:33:15.575059 	zma_m3
	15262 	INF 	Autos: 24847 - Closing event 96819, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:33:15.546658 	zma_m3
	15262 	INF 	Autos: 24847 - Left alarm state (96819) - 86(16) images 	zm_monitor.cpp 	1711
2017-06-05 15:33:11.555073 	zma_m3
	15262 	INF 	Autos: 24812 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:33:09.249308 	zma_m3
	15262 	INF 	Autos: 24797 - Opening new event 96819, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:33:09.180619 	zma_m3
	15262 	INF 	Autos: 24797 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:33:09.042485 	zma_m3
	15262 	INF 	Autos: 24796 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:33:05.278144 	zma_m2
	15249 	INF 	Haustuer: 24000 - Analysing at 7.63 fps 	zm_monitor.cpp 	1296
2017-06-05 15:33:03.595600 	zmc_m2
	15248 	INF 	Haustuer: 24000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:33:02.381879 	zma_m3
	15262 	INF 	Autos: 24742 - Closing event 96818, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:33:02.362883 	zma_m3
	15262 	INF 	Autos: 24742 - Left alarm state (96818) - 125(55) images 	zm_monitor.cpp 	1711
2017-06-05 15:32:57.595418 	zma_m3
	15262 	INF 	Autos: 24707 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:32:54.844587 	zma_m2
	15249 	INF 	Haustuer: 23919 - Closing event 96817, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:32:54.822573 	zma_m2
	15249 	INF 	Haustuer: 23919 - Left alarm state (96817) - 68(18) images 	zm_monitor.cpp 	1711
2017-06-05 15:32:51.593195 	zma_m2
	15249 	INF 	Haustuer: 23894 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:32:49.989021 	zma_m3
	15262 	INF 	Autos: 24653 - Opening new event 96818, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:32:49.869106 	zma_m3
	15262 	INF 	Autos: 24653 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:32:49.735336 	zma_m3
	15262 	INF 	Autos: 24652 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:32:49.475337 	zma_m2
	15249 	INF 	Haustuer: 23877 - Opening new event 96817, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:32:49.431973 	zma_m2
	15249 	INF 	Haustuer: 23877 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:32:49.297911 	zma_m2
	15249 	INF 	Haustuer: 23876 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:32:01.608463 	zma_m3
	15262 	INF 	Autos: 24267 - Closing event 96814, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:32:01.589331 	zma_m3
	15262 	INF 	Autos: 24267 - Left alarm state (96814) - 281(207) images 	zm_monitor.cpp 	1711
2017-06-05 15:31:59.673077 	zma_m2
	15249 	INF 	Haustuer: 23492 - Closing event 96816, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:31:59.584787 	zma_m2
	15249 	INF 	Haustuer: 23492 - Left alarm state (96816) - 165(67) images 	zm_monitor.cpp 	1711
2017-06-05 15:31:57.257253 	zma_m3
	15262 	INF 	Autos: 24232 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:56.385805 	zma_m2
	15249 	INF 	Haustuer: 23467 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:53.181104 	zma_m2
	15249 	INF 	Haustuer: 23442 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:31:53.060278 	zma_m2
	15249 	INF 	Haustuer: 23441 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:52.891159 	zma_m2
	15249 	INF 	Haustuer: 23440 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:31:50.507571 	zma_m2
	15249 	INF 	Haustuer: 23418 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:49.870764 	zma_m2
	15249 	INF 	Haustuer: 23414 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:31:49.637890 	zma_m2
	15249 	INF 	Haustuer: 23412 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:46.181345 	zma_m2
	15249 	INF 	Haustuer: 23395 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:31:43.283829 	zma_m2
	15249 	INF 	Haustuer: 23372 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:40.853871 	zma_m2
	15249 	INF 	Haustuer: 23353 - Opening new event 96816, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:31:40.792324 	zma_m2
	15249 	INF 	Haustuer: 23353 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:31:40.629044 	zma_m2
	15249 	INF 	Haustuer: 23352 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:31:40.213901 	zma_m3
	15262 	INF 	Autos: 24105 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:31:40.144390 	zma_m3
	15262 	INF 	Autos: 24104 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:39.066954 	zma_m3
	15262 	INF 	Autos: 24095 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:31:38.887586 	zma_m2
	15249 	INF 	Haustuer: 23337 - Closing event 96815, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:31:38.689291 	zma_m2
	15249 	INF 	Haustuer: 23337 - Left alarm state (96815) - 78(28) images 	zm_monitor.cpp 	1711
2017-06-05 15:31:38.661510 	zma_m3
	15262 	INF 	Autos: 24092 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:35.820533 	zma_m2
	15249 	INF 	Haustuer: 23312 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:31:31.839856 	zma_m2
	15249 	INF 	Haustuer: 23285 - Opening new event 96815, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:31:31.766999 	zma_m2
	15249 	INF 	Haustuer: 23285 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:31:31.615125 	zma_m2
	15249 	INF 	Haustuer: 23284 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:31:27.924551 	zma_m1
	15237 	INF 	HintermHaus: 15000 - Analysing at 5.03 fps 	zm_monitor.cpp 	1296
2017-06-05 15:31:27.863517 	zma_m3
	15262 	INF 	Autos: 24022 - Opening new event 96814, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:31:27.795667 	zma_m3
	15262 	INF 	Autos: 24022 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:31:27.656350 	zma_m3
	15262 	INF 	Autos: 24021 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:31:25.139544 	zma_m3
	15262 	INF 	Autos: 24000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:31:24.670491 	zmc_m1
	15232 	INF 	HintermHaus: 15000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:31:23.379765 	zmc_m3
	15257 	INF 	Autos: 24000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:30:54.970994 	zma_m2
	15249 	INF 	Haustuer: 23000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:30:54.465300 	zmc_m2
	15248 	INF 	Haustuer: 23000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:29:20.265775 	zma_m3
	15262 	INF 	Autos: 23000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:29:18.471902 	zmc_m3
	15257 	INF 	Autos: 23000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:28:45.815029 	zma_m2
	15249 	INF 	Haustuer: 22000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:28:45.277157 	zmc_m2
	15248 	INF 	Haustuer: 22000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:28:08.099315 	zma_m1
	15237 	INF 	HintermHaus: 14000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:28:04.848315 	zmc_m1
	15232 	INF 	HintermHaus: 14000 - Capturing at 5.03 fps 	zm_monitor.cpp 	3125
2017-06-05 15:27:15.323080 	zma_m3
	15262 	INF 	Autos: 22000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:27:13.565054 	zmc_m3
	15257 	INF 	Autos: 22000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:26:36.544850 	zma_m2
	15249 	INF 	Haustuer: 21000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:26:36.012261 	zmc_m2
	15248 	INF 	Haustuer: 21000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-05 15:26:22.109090 	zmaudit
	15268 	INF 	Deleted 130 log table entries by time 	zmaudit.pl
2017-06-05 15:25:10.425458 	zma_m3
	15262 	INF 	Autos: 21000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:25:08.665910 	zmc_m3
	15257 	INF 	Autos: 21000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:24:48.380708 	zma_m1
	15237 	INF 	HintermHaus: 13000 - Analysing at 4.98 fps 	zm_monitor.cpp 	1296
2017-06-05 15:24:45.007906 	zmc_m1
	15232 	INF 	HintermHaus: 13000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:24:27.374143 	zma_m2
	15249 	INF 	Haustuer: 20000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-05 15:24:26.866974 	zmc_m2
	15248 	INF 	Haustuer: 20000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:23:05.523200 	zma_m3
	15262 	INF 	Autos: 20000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:23:03.784596 	zmc_m3
	15257 	INF 	Autos: 20000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:22:17.964423 	zma_m2
	15249 	INF 	Haustuer: 19000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:22:17.461822 	zmc_m2
	15248 	INF 	Haustuer: 19000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:21:27.537112 	zma_m1
	15237 	INF 	HintermHaus: 12000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:21:25.173608 	zmc_m1
	15232 	INF 	HintermHaus: 12000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:21:00.649071 	zma_m3
	15262 	INF 	Autos: 19000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:20:58.918993 	zmc_m3
	15257 	INF 	Autos: 19000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:20:08.823781 	zma_m2
	15249 	INF 	Haustuer: 18000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:20:08.280790 	zmc_m2
	15248 	INF 	Haustuer: 18000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-05 15:19:05.036355 	zma_m3
	15262 	INF 	Autos: 18075 - Closing event 96813, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:19:05.010584 	zma_m3
	15262 	INF 	Autos: 18075 - Left alarm state (96813) - 90(20) images 	zm_monitor.cpp 	1711
2017-06-05 15:19:00.741102 	zma_m3
	15262 	INF 	Autos: 18040 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:18:58.337276 	zma_m3
	15262 	INF 	Autos: 18021 - Opening new event 96813, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:18:58.293407 	zma_m3
	15262 	INF 	Autos: 18021 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:18:58.210997 	zma_m3
	15262 	INF 	Autos: 18020 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:18:55.751893 	zma_m3
	15262 	INF 	Autos: 18000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:18:53.992236 	zmc_m3
	15257 	INF 	Autos: 18000 - Capturing at 8.06 fps 	zm_monitor.cpp 	3125
2017-06-05 15:18:07.355727 	zma_m1
	15237 	INF 	HintermHaus: 11000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:18:05.352156 	zmc_m1
	15232 	INF 	HintermHaus: 11000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:17:59.410987 	zma_m2
	15249 	INF 	Haustuer: 17000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:17:58.912699 	zmc_m2
	15248 	INF 	Haustuer: 17000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:16:50.845925 	zma_m3
	15262 	INF 	Autos: 17000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:16:49.109243 	zmc_m3
	15257 	INF 	Autos: 17000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:16:04.914190 	zma_m1
	15237 	INF 	HintermHaus: 10387 - Closing event 96812, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:16:04.883030 	zma_m1
	15237 	INF 	HintermHaus: 10387 - Left alarm state (96812) - 69(17) images 	zm_monitor.cpp 	1711
2017-06-05 15:16:00.635469 	zma_m1
	15237 	INF 	HintermHaus: 10362 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:15:59.272747 	zma_m1
	15237 	INF 	HintermHaus: 10359 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:15:59.078503 	zma_m1
	15237 	INF 	HintermHaus: 10358 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:15:57.822768 	zma_m1
	15237 	INF 	HintermHaus: 10350 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:15:57.741553 	zma_m1
	15237 	INF 	HintermHaus: 10349 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:15:56.756884 	zma_m1
	15237 	INF 	HintermHaus: 10345 - Opening new event 96812, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:15:56.638343 	zma_m1
	15237 	INF 	HintermHaus: 10345 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:15:55.801600 	zma_m1
	15237 	INF 	HintermHaus: 10343 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:15:53.882722 	zma_m1
	15237 	INF 	HintermHaus: 10334 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:15:53.327366 	zma_m1
	15237 	INF 	HintermHaus: 10331 - Closing event 96811, alarm end 	zm_monitor.cpp 	1716
2017-06-05 15:15:53.302681 	zma_m1
	15237 	INF 	HintermHaus: 10331 - Left alarm state (96811) - 67(13) images 	zm_monitor.cpp 	1711
2017-06-05 15:15:50.274014 	zma_m2
	15249 	INF 	Haustuer: 16000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-05 15:15:49.714686 	zmc_m2
	15248 	INF 	Haustuer: 16000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:15:48.824173 	zma_m1
	15237 	INF 	HintermHaus: 10306 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:15:47.283207 	zma_m1
	15237 	INF 	HintermHaus: 10301 - Gone back into alarm state 	zm_monitor.cpp 	1695
2017-06-05 15:15:46.615790 	zma_m1
	15237 	INF 	HintermHaus: 10297 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 15:15:45.435510 	zma_m1
	15237 	INF 	HintermHaus: 10291 - Opening new event 96811, alarm start 	zm_monitor.cpp 	1660
2017-06-05 15:15:45.311858 	zma_m1
	15237 	INF 	HintermHaus: 10291 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 15:15:44.924581 	zma_m1
	15237 	INF 	HintermHaus: 10289 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 15:14:47.169331 	zma_m1
	15237 	INF 	HintermHaus: 10000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:14:45.966799 	zma_m3
	15262 	INF 	Autos: 16000 - Analysing at 8.06 fps 	zm_monitor.cpp 	1296
2017-06-05 15:14:45.520549 	zmc_m1
	15232 	INF 	HintermHaus: 10000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:14:44.239926 	zmc_m3
	15257 	INF 	Autos: 16000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:13:40.974817 	zma_m2
	15249 	INF 	Haustuer: 15000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:13:40.438233 	zmc_m2
	15248 	INF 	Haustuer: 15000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:12:41.056005 	zma_m3
	15262 	INF 	Autos: 15000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:12:39.351698 	zmc_m3
	15257 	INF 	Autos: 15000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:11:31.805011 	zma_m2
	15249 	INF 	Haustuer: 14000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:11:31.274446 	zmc_m2
	15248 	INF 	Haustuer: 14000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-05 15:11:27.105259 	zma_m1
	15237 	INF 	HintermHaus: 9000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:11:25.703224 	zmc_m1
	15232 	INF 	HintermHaus: 9000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:10:36.184583 	zma_m3
	15262 	INF 	Autos: 14000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:10:34.432024 	zmc_m3
	15257 	INF 	Autos: 14000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:09:22.417835 	zma_m2
	15249 	INF 	Haustuer: 13000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-05 15:09:21.872872 	zmc_m2
	15248 	INF 	Haustuer: 13000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:08:31.289531 	zma_m3
	15262 	INF 	Autos: 13000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:08:29.542728 	zmc_m3
	15257 	INF 	Autos: 13000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:08:07.326845 	zma_m1
	15237 	INF 	HintermHaus: 8000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:08:05.861382 	zmc_m1
	15232 	INF 	HintermHaus: 8000 - Capturing at 5.03 fps 	zm_monitor.cpp 	3125
2017-06-05 15:07:12.977653 	zma_m2
	15249 	INF 	Haustuer: 12000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
	15248 	INF 	Haustuer: 12000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-05 15:06:26.398175 	zma_m3
	15262 	INF 	Autos: 12000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:06:24.659920 	zmc_m3
	15257 	INF 	Autos: 12000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:05:03.346283 	zma_m2
	15249 	INF 	Haustuer: 11000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:05:02.792472 	zmc_m2
	15248 	INF 	Haustuer: 11000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:04:47.450501 	zma_m1
	15237 	INF 	HintermHaus: 7000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:04:46.043778 	zmc_m1
	15232 	INF 	HintermHaus: 7000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:04:21.500121 	zma_m3
	15262 	INF 	Autos: 11000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:04:19.771574 	zmc_m3
	15257 	INF 	Autos: 11000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:02:54.051334 	zma_m2
	15249 	INF 	Haustuer: 10000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-05 15:02:53.503109 	zmc_m2
	15248 	INF 	Haustuer: 10000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:02:16.586567 	zma_m3
	15262 	INF 	Autos: 10000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:02:14.856387 	zmc_m3
	15257 	INF 	Autos: 10000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:01:27.630765 	zma_m1
	15237 	INF 	HintermHaus: 6000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:01:26.196118 	zmc_m1
	15232 	INF 	HintermHaus: 6000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 15:00:44.757287 	zma_m2
	15249 	INF 	Haustuer: 9000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 15:00:44.213512 	zmc_m2
	15248 	INF 	Haustuer: 9000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 15:00:11.687209 	zma_m3
	15262 	INF 	Autos: 9000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 15:00:09.978999 	zmc_m3
	15257 	INF 	Autos: 9000 - Capturing at 8.06 fps 	zm_monitor.cpp 	3125
2017-06-05 14:58:35.595703 	zma_m2
	15249 	INF 	Haustuer: 8000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 14:58:35.072036 	zmc_m2
	15248 	INF 	Haustuer: 8000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 14:58:07.620404 	zma_m1
	15237 	INF 	HintermHaus: 5000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 14:58:06.834112 	zma_m3
	15262 	INF 	Autos: 8000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 14:58:06.394529 	zmc_m1
	15232 	INF 	HintermHaus: 5000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:58:05.105482 	zmc_m3
	15257 	INF 	Autos: 8000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:56:26.580283 	zma_m2
	15249 	INF 	Haustuer: 7000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 14:56:26.058288 	zmc_m2
	15248 	INF 	Haustuer: 7000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-05 14:56:21.935820 	zmaudit
	15268 	INF 	Deleted 14085 log table entries by time 	zmaudit.pl
2017-06-05 14:56:01.949200 	zma_m3
	15262 	INF 	Autos: 7000 - Analysing at 8.06 fps 	zm_monitor.cpp 	1296
2017-06-05 14:56:00.188106 	zmc_m3
	15257 	INF 	Autos: 7000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:54:47.595168 	zma_m1
	15237 	INF 	HintermHaus: 4000 - Analysing at 5.00 fps 	zm_monitor.cpp 	1296
2017-06-05 14:54:46.561525 	zmc_m1
	15232 	INF 	HintermHaus: 4000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:54:17.158500 	zma_m2
	15249 	INF 	Haustuer: 6000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 14:54:16.655027 	zmc_m2
	15248 	INF 	Haustuer: 6000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 14:53:57.037646 	zma_m3
	15262 	INF 	Autos: 6000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 14:53:55.302486 	zmc_m3
	15257 	INF 	Autos: 6000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:52:08.127334 	zma_m2
	15249 	INF 	Haustuer: 5000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-05 14:52:07.630811 	zmc_m2
	15248 	INF 	Haustuer: 5000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 14:51:52.148474 	zma_m3
	15262 	INF 	Autos: 5000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 14:51:50.419159 	zmc_m3
	15257 	INF 	Autos: 5000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:51:27.332942 	zma_m1
	15237 	INF 	HintermHaus: 3000 - Analysing at 4.98 fps 	zm_monitor.cpp 	1296
2017-06-05 14:51:26.329629 	zmc_m1
	15232 	INF 	HintermHaus: 3000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:49:58.850972 	zma_m2
	15249 	INF 	Haustuer: 4000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 14:49:58.329407 	zmc_m2
	15248 	INF 	Haustuer: 4000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 14:49:47.305925 	zma_m3
	15262 	INF 	Autos: 4000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 14:49:45.518313 	zmc_m3
	15257 	INF 	Autos: 4000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:48:06.913856 	zma_m1
	15237 	INF 	HintermHaus: 2000 - Analysing at 5.03 fps 	zm_monitor.cpp 	1296
2017-06-05 14:48:06.167631 	zmc_m1
	15232 	INF 	HintermHaus: 2000 - Capturing at 5.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:47:49.730926 	zma_m2
	15249 	INF 	Haustuer: 3000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-05 14:47:49.191720 	zmc_m2
	15248 	INF 	Haustuer: 3000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-05 14:47:42.339299 	zma_m3
	15262 	INF 	Autos: 3000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 14:47:40.619996 	zmc_m3
	15257 	INF 	Autos: 3000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:45:40.434999 	zma_m2
	15249 	INF 	Haustuer: 2000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-05 14:45:39.912210 	zmc_m2
	15248 	INF 	Haustuer: 2000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 14:45:37.497582 	zma_m3
	15262 	INF 	Autos: 2000 - Analysing at 8.00 fps 	zm_monitor.cpp 	1296
2017-06-05 14:45:35.741006 	zmc_m3
	15257 	INF 	Autos: 2000 - Capturing at 8.00 fps 	zm_monitor.cpp 	3125
2017-06-05 14:45:14.984971 	zma_m3
	15262 	INF 	Autos: 1819 - Closing event 96810, alarm end 	zm_monitor.cpp 	1716
2017-06-05 14:45:14.945194 	zma_m3
	15262 	INF 	Autos: 1819 - Left alarm state (96810) - 72(2) images 	zm_monitor.cpp 	1711
2017-06-05 14:45:10.897062 	zma_m3
	15262 	INF 	Autos: 1784 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-05 14:45:10.432532 	zma_m3
	15262 	INF 	Autos: 1783 - Opening new event 96810, alarm start 	zm_monitor.cpp 	1660
2017-06-05 14:45:10.366865 	zma_m3
	15262 	INF 	Autos: 1783 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-05 14:45:10.185195 	zma_m3
	15262 	INF 	Autos: 1782 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-05 14:44:47.073659 	zma_m1
	15237 	INF 	HintermHaus: 1000 - Analysing at 4.83 fps 	zm_monitor.cpp 	1296
2017-06-05 14:44:46.242957 	zmc_m1
	15232 	INF 	HintermHaus: 1000 - Capturing at 4.85 fps 	zm_monitor.cpp 	3125
2017-06-05 14:43:32.584008 	zma_m3
	15262 	INF 	Autos: 1000 - Analysing at 7.63 fps 	zm_monitor.cpp 	1296
2017-06-05 14:43:30.845119 	zmc_m3
	15257 	INF 	Autos: 1000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-05 14:43:30.634782 	zma_m2
	15249 	INF 	Haustuer: 1000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-05 14:43:30.114715 	zmc_m2
	15248 	INF 	Haustuer: 1000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-05 14:41:28.867118 	zma_m3
	15262 	INF 	In mode 3/1, warming up 	zma.cpp 	142
2017-06-05 14:41:27.910437 	zma_m1
	15237 	INF 	In mode 3/1, warming up 	zma.cpp 	142
2017-06-05 14:41:27.757172 	zma_m3
	15262 	WAR 	Waiting for capture daemon 	zm_monitor.cpp 	503
2017-06-05 14:41:26.655975 	zma_m1
	15237 	WAR 	Waiting for capture daemon 	zm_monitor.cpp 	503
2017-06-05 14:41:26.611394 	zma_m3
2017-06-05 14:41:25.633379 	zma_m1
2017-06-05 14:41:25.499963 	zma_m3
2017-06-05 14:41:24.610806 	zma_m1
2017-06-05 14:41:24.433246 	zma_m3
2017-06-05 14:41:23.588679 	zma_m1
2017-06-05 14:41:23.365970 	zma_m3
2017-06-05 14:41:22.564954 	zma_m1
2017-06-05 14:41:22.398110 	zmupdate
	15278 	INF 	Got version: '1.30.0' 	zmupdate.pl
2017-06-05 14:41:22.319618 	zma_m3
2017-06-05 14:41:21.897068 	zma_m2
	15249 	INF 	In mode 3/1, warming up 	zma.cpp 	142
2017-06-05 14:41:21.765280 	zmupdate
	15278 	INF 	Checking for updates 	zmupdate.pl
2017-06-05 14:41:21.753340 	zmdc
	15282 	INF 	'zmtelemetry.pl' started at 17/06/05 14:41:21 	zmdc.pl
2017-06-05 14:41:21.753300 	zmdc
	15202 	INF 	'zmtelemetry.pl' starting at 17/06/05 14:41:21, pid = 15282 	zmdc.pl
2017-06-05 14:41:21.642840 	zmwatch
	15273 	INF 	Watchdog pausing for 30 seconds 	zmwatch.pl
2017-06-05 14:41:21.627820 	zmdc
	15278 	INF 	'zmupdate.pl -c' started at 17/06/05 14:41:21 	zmdc.pl
2017-06-05 14:41:21.627720 	zmdc
	15202 	INF 	'zmupdate.pl -c' starting at 17/06/05 14:41:21, pid = 15278 	zmdc.pl
2017-06-05 14:41:21.618930 	zmwatch
	15273 	INF 	Watchdog starting 	zmwatch.pl
2017-06-05 14:41:21.527902 	zma_m1
2017-06-05 14:41:21.496620 	zmdc
	15273 	INF 	'zmwatch.pl' started at 17/06/05 14:41:21 	zmdc.pl
2017-06-05 14:41:21.496150 	zmdc
	15202 	INF 	'zmwatch.pl' starting at 17/06/05 14:41:21, pid = 15273 	zmdc.pl
2017-06-05 14:41:21.429250 	zmfilter
	15263 	INF 	Scanning for events 	zmfilter.pl
2017-06-05 14:41:21.358730 	zmdc
	15268 	INF 	'zmaudit.pl -c' started at 17/06/05 14:41:21 	zmdc.pl
2017-06-05 14:41:21.358620 	zmdc
	15202 	INF 	'zmaudit.pl -c' starting at 17/06/05 14:41:21, pid = 15268 	zmdc.pl
2017-06-05 14:41:21.279460 	zma_m3
2017-06-05 14:41:21.252884 	zmc_m3
	15257 	INF 	Priming capture from rtsp://USER:PW@192.168.2.141:88/videoMain 	zm_ffmpeg_camera.cpp 	104
2017-06-05 14:41:21.233120 	zmdc
	15263 	INF 	'zmfilter.pl' started at 17/06/05 14:41:21 	zmdc.pl
2017-06-05 14:41:21.233020 	zmdc
	15202 	INF 	'zmfilter.pl' starting at 17/06/05 14:41:21, pid = 15263 	zmdc.pl
2017-06-05 14:41:21.213287 	zmc_m3
	15257 	INF 	Starting Capture version 1.30.2 	zmc.cpp 	250
2017-06-05 14:41:21.210520 	zmdc
	15262 	INF 	'zma -m 3' started at 17/06/05 14:41:21 	zmdc.pl
2017-06-05 14:41:21.210370 	zmdc
	15202 	INF 	'zma -m 3' starting at 17/06/05 14:41:21, pid = 15262 	zmdc.pl
2017-06-05 14:41:21.185710 	zmdc
	15202 	INF 	Starting pending process, zma -m 3 	zmdc.pl
2017-06-05 14:41:21.165480 	zmdc
	15202 	ERR 	'zma -m 3' exited abnormally, exit status 255 	zmdc.pl
2017-06-05 14:41:21.141559 	zma_m3
	15258 	ERR 	Shared data not initialised by capture daemon for monitor Autos 	zm_monitor.cpp 	442
2017-06-05 14:41:21.076600 	zmdc
	15258 	INF 	'zma -m 3' started at 17/06/05 14:41:21 	zmdc.pl
2017-06-05 14:41:21.076520 	zmdc
	15202 	INF 	'zma -m 3' starting at 17/06/05 14:41:21, pid = 15258 	zmdc.pl
2017-06-05 14:41:21.054290 	zmdc
	15257 	INF 	'zmc -m 3' started at 17/06/05 14:41:21 	zmdc.pl
2017-06-05 14:41:21.054220 	zmdc
	15202 	INF 	'zmc -m 3' starting at 17/06/05 14:41:21, pid = 15257 	zmdc.pl
2017-06-05 14:41:21.027390 	zmdc
	15202 	INF 	Starting pending process, zmc -m 3 	zmdc.pl
2017-06-05 14:41:20.998730 	zmdc
	15202 	ERR 	'zmc -m 3' exited abnormally, exit status 255 	zmdc.pl
2017-06-05 14:41:20.913600 	zmdc
	15253 	INF 	'zmc -m 3' started at 17/06/05 14:41:20 	zmdc.pl
2017-06-05 14:41:20.913500 	zmdc
	15202 	INF 	'zmc -m 3' starting at 17/06/05 14:41:20, pid = 15253 	zmdc.pl
2017-06-05 14:41:20.870614 	zma_m2
	15249 	WAR 	Waiting for capture daemon 	zm_monitor.cpp 	503
2017-06-05 14:41:20.842587 	zmc_m2
	15248 	INF 	Starting Capture version 1.30.2 	zmc.cpp 	250
2017-06-05 14:41:20.707500 	zmdc
	15249 	INF 	'zma -m 2' started at 17/06/05 14:41:20 	zmdc.pl
2017-06-05 14:41:20.707420 	zmdc
	15202 	INF 	'zma -m 2' starting at 17/06/05 14:41:20, pid = 15249 	zmdc.pl
2017-06-05 14:41:20.669260 	zmdc
	15248 	INF 	'zmc -m 2' started at 17/06/05 14:41:20 	zmdc.pl
2017-06-05 14:41:20.669180 	zmdc
	15202 	INF 	'zmc -m 2' starting at 17/06/05 14:41:20, pid = 15248 	zmdc.pl
2017-06-05 14:41:20.605390 	zmdc
	15202 	INF 	Starting pending process, zmc -m 2 	zmdc.pl
2017-06-05 14:41:20.554610 	zmdc
	15202 	ERR 	'zmc -m 2' exited abnormally, exit status 255 	zmdc.pl
2017-06-05 14:41:20.378050 	zma_m1
2017-06-05 14:41:20.357100 	zmdc
	15238 	INF 	'zmc -m 2' started at 17/06/05 14:41:20 	zmdc.pl
2017-06-05 14:41:20.351310 	zmdc
	15202 	INF 	'zmc -m 2' starting at 17/06/05 14:41:20, pid = 15238 	zmdc.pl
2017-06-05 14:41:20.284290 	zmdc
	15237 	INF 	'zma -m 1' started at 17/06/05 14:41:20 	zmdc.pl
2017-06-05 14:41:20.284210 	zmdc
	15202 	INF 	'zma -m 1' starting at 17/06/05 14:41:20, pid = 15237 	zmdc.pl
2017-06-05 14:41:20.245971 	zmc_m1
	15232 	INF 	Priming capture from rtsp://USER:PW@192.168.1.3:88/videoMain 	zm_ffmpeg_camera.cpp 	104
2017-06-05 14:41:20.148100 	zmdc
	15202 	INF 	Starting pending process, zma -m 1 	zmdc.pl
2017-06-05 14:41:20.139710 	zmc_m1
	15232 	INF 	Starting Capture version 1.30.2 	zmc.cpp 	250
2017-06-05 14:41:20.116360 	zmdc
	15202 	ERR 	'zma -m 1' exited abnormally, exit status 255 	zmdc.pl
2017-06-05 14:41:20.085803 	zma_m1
	15233 	ERR 	Shared data not initialised by capture daemon for monitor HintermHaus 	zm_monitor.cpp 	442
2017-06-05 14:41:19.994980 	zmdc
	15233 	INF 	'zma -m 1' started at 17/06/05 14:41:19 	zmdc.pl
2017-06-05 14:41:19.994880 	zmdc
	15202 	INF 	'zma -m 1' starting at 17/06/05 14:41:19, pid = 15233 	zmdc.pl
2017-06-05 14:41:19.961280 	zmdc
	15232 	INF 	'zmc -m 1' started at 17/06/05 14:41:19 	zmdc.pl
2017-06-05 14:41:19.961210 	zmdc
	15202 	INF 	'zmc -m 1' starting at 17/06/05 14:41:19, pid = 15232 	zmdc.pl
2017-06-05 14:41:19.925000 	zmdc
	15202 	INF 	Starting pending process, zmc -m 1 	zmdc.pl
2017-06-05 14:41:19.896430 	zmdc
	15202 	ERR 	'zmc -m 1' exited abnormally, exit status 255 	zmdc.pl
2017-06-05 14:41:19.804360 	zmdc
	15228 	INF 	'zmc -m 1' started at 17/06/05 14:41:19 	zmdc.pl
2017-06-05 14:41:19.804260 	zmdc
	15202 	INF 	'zmc -m 1' starting at 17/06/05 14:41:19, pid = 15228 	zmdc.pl
2017-06-05 14:41:19.642040 	zmpkg
	15187 	INF 	Single server configuration detected. Starting up services. 	zmpkg.pl
2017-06-05 14:41:16.640900 	zmdc
	15202 	INF 	Server starting at 17/06/05 14:41:16 	zmdc.pl
2017-06-05 14:41:16.349500 	zmpkg
	15187 	INF 	Command: start 	zmpkg.pl
2017-06-05 14:41:16.273760 	zmpkg
	15187 	INF 	Sanity checking States table... 	zmpkg.pl
2017-06-05 14:41:16.115630 	zmsystemctl
	15183 	INF 	Redirecting command through systemctl 	zmsystemctl.pl
2017-06-05 14:41:15.969590 	zmpkg
	15177 	INF 	Command: start 	zmpkg.pl
2017-06-05 14:41:15.894060 	zmpkg
	15177 	INF 	Sanity checking States table... 	zmpkg.pl
2017-06-05 14:40:40.924619 	zms
	15143 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x55b7c3db7bb8 0x7f88184a2390 0x55b7c3d649ad 0x55b7c3d71648 0x55b7c3d37e01 0x7f8814b94830 0x55b7c3d38bb9 	zm_signal.cpp 	110
2017-06-05 14:40:40.902381 	zms
	15143 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:40.879969 	zms
	15143 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x55b7c3d38bb9] 	zm_signal.cpp 	102
2017-06-05 14:40:40.862126 	zms
	15143 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f8814b94830] 	zm_signal.cpp 	102
2017-06-05 14:40:40.828736 	zms
	15143 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x55b7c3d37e01] 	zm_signal.cpp 	102
2017-06-05 14:40:40.795242 	zms
	15143 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x55b7c3d71648] 	zm_signal.cpp 	102
2017-06-05 14:40:40.761826 	zms
	15143 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55b7c3d649ad] 	zm_signal.cpp 	102
2017-06-05 14:40:40.728398 	zms
	15143 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f88184a2390] 	zm_signal.cpp 	102
2017-06-05 14:40:40.694527 	zms
	15143 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55b7c3db7bb8] 	zm_signal.cpp 	102
2017-06-05 14:40:40.601117 	zms
	15143 	ERR 	Signal address is 0x4, from 0x55b7c3d649ad 	zm_signal.cpp 	81
2017-06-05 14:40:40.528012 	zms
	15143 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:40.475721 	zms
	15143 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:40.309508 	web_php
	15087 	ERR 	socket_sendto( /var/run/zm/zms-728733s.sock ) failed: Connection refused 	/usr/share/zoneminder/www/includes/functions.php 	2031
2017-06-05 14:40:35.805304 	zms
	15142 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x564c722e8bb8 0x7fcd5516f390 0x564c722959ad 0x564c722a2648 0x564c72268e01 0x7fcd51861830 0x564c72269bb9 	zm_signal.cpp 	110
2017-06-05 14:40:35.771885 	zms
	15142 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:35.738413 	zms
	15142 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x564c72269bb9] 	zm_signal.cpp 	102
2017-06-05 14:40:35.704962 	zms
	15142 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fcd51861830] 	zm_signal.cpp 	102
2017-06-05 14:40:35.671466 	zms
	15142 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x564c72268e01] 	zm_signal.cpp 	102
2017-06-05 14:40:35.638022 	zms
	15142 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x564c722a2648] 	zm_signal.cpp 	102
2017-06-05 14:40:35.604553 	zms
	15142 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x564c722959ad] 	zm_signal.cpp 	102
2017-06-05 14:40:35.571137 	zms
	15142 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fcd5516f390] 	zm_signal.cpp 	102
2017-06-05 14:40:35.537793 	zms
	15142 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x564c722e8bb8] 	zm_signal.cpp 	102
2017-06-05 14:40:35.504302 	zms
	15142 	ERR 	Signal address is 0x4, from 0x564c722959ad 	zm_signal.cpp 	81
2017-06-05 14:40:35.470856 	zms
	15142 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:35.440642 	zms
	15142 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:35.327771 	web_php
	28316 	ERR 	socket_sendto( /var/run/zm/zms-246422s.sock ) failed: Connection refused 	/usr/share/zoneminder/www/includes/functions.php 	2031
2017-06-05 14:40:35.237181 	zms
	15113 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x55724a8f7bb8 0x7fb04749d390 0x55724a8a49ad 0x55724a8b1648 0x55724a877e01 0x7fb043b8f830 0x55724a878bb9 	zm_signal.cpp 	110
2017-06-05 14:40:35.203630 	zms
	15113 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:35.170210 	zms
	15113 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x55724a878bb9] 	zm_signal.cpp 	102
2017-06-05 14:40:35.136829 	zms
	15113 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fb043b8f830] 	zm_signal.cpp 	102
2017-06-05 14:40:35.103319 	zms
	15113 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x55724a877e01] 	zm_signal.cpp 	102
2017-06-05 14:40:35.069808 	zms
	15113 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x55724a8b1648] 	zm_signal.cpp 	102
2017-06-05 14:40:35.036551 	zms
	15113 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55724a8a49ad] 	zm_signal.cpp 	102
2017-06-05 14:40:35.004286 	zms
	15113 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fb04749d390] 	zm_signal.cpp 	102
2017-06-05 14:40:34.903060 	zms
	15113 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55724a8f7bb8] 	zm_signal.cpp 	102
2017-06-05 14:40:34.835879 	zms
	15113 	ERR 	Signal address is 0x4, from 0x55724a8a49ad 	zm_signal.cpp 	81
2017-06-05 14:40:34.810068 	zms
	15113 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:34.399045 	zms
	15113 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:34.309398 	web_php
	15108 	ERR 	socket_sendto( /var/run/zm/zms-646531s.sock ) failed: Connection refused 	/usr/share/zoneminder/www/includes/functions.php 	2031
2017-06-05 14:40:28.946403 	zms
	15111 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x555f5c0d3bb8 0x7f1bbddb4390 0x555f5c0809ad 0x555f5c08d648 0x555f5c053e01 0x7f1bba4a6830 0x555f5c054bb9 	zm_signal.cpp 	110
2017-06-05 14:40:28.946323 	zms
	15110 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x565091caabb8 0x7f2df7e92390 0x565091c579ad 0x565091c64648 0x565091c2ae01 0x7f2df4584830 0x565091c2bbb9 	zm_signal.cpp 	110
2017-06-05 14:40:28.912958 	zms
	15109 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x561bb948bbb8 0x7ff85b5f0390 0x561bb94389ad 0x561bb9445648 0x561bb940be01 0x7ff857ce2830 0x561bb940cbb9 	zm_signal.cpp 	110
2017-06-05 14:40:28.879464 	zms
	15110 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:28.879417 	zms
	15111 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:28.801601 	zms
	15109 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:28.779511 	zms
	15110 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x565091c2bbb9] 	zm_signal.cpp 	102
2017-06-05 14:40:28.779209 	zms
	15111 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x555f5c054bb9] 	zm_signal.cpp 	102
2017-06-05 14:40:28.757142 	zms
	15109 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x561bb940cbb9] 	zm_signal.cpp 	102
2017-06-05 14:40:28.734884 	zms
	15111 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f1bba4a6830] 	zm_signal.cpp 	102
2017-06-05 14:40:28.734820 	zms
	15110 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f2df4584830] 	zm_signal.cpp 	102
2017-06-05 14:40:28.712457 	zms
	15109 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7ff857ce2830] 	zm_signal.cpp 	102
2017-06-05 14:40:28.690308 	zms
	15110 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x565091c2ae01] 	zm_signal.cpp 	102
2017-06-05 14:40:28.690159 	zms
	15111 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x555f5c053e01] 	zm_signal.cpp 	102
2017-06-05 14:40:28.667732 	zms
	15109 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x561bb940be01] 	zm_signal.cpp 	102
2017-06-05 14:40:28.645525 	zms
	15110 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x565091c64648] 	zm_signal.cpp 	102
2017-06-05 14:40:28.645290 	zms
	15111 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x555f5c08d648] 	zm_signal.cpp 	102
2017-06-05 14:40:28.622904 	zms
	15109 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x561bb9445648] 	zm_signal.cpp 	102
2017-06-05 14:40:28.600871 	zms
	15110 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x565091c579ad] 	zm_signal.cpp 	102
2017-06-05 14:40:28.600728 	zms
	15111 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x555f5c0809ad] 	zm_signal.cpp 	102
2017-06-05 14:40:28.570743 	zms
	15109 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x561bb94389ad] 	zm_signal.cpp 	102
2017-06-05 14:40:28.467309 	zms
	15110 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f2df7e92390] 	zm_signal.cpp 	102
2017-06-05 14:40:28.467027 	zms
	15111 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f1bbddb4390] 	zm_signal.cpp 	102
2017-06-05 14:40:28.444552 	zms
	15109 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7ff85b5f0390] 	zm_signal.cpp 	102
2017-06-05 14:40:28.422434 	zms
	15110 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x565091caabb8] 	zm_signal.cpp 	102
2017-06-05 14:40:28.422263 	zms
	15111 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x555f5c0d3bb8] 	zm_signal.cpp 	102
2017-06-05 14:40:28.399975 	zms
	15109 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x561bb948bbb8] 	zm_signal.cpp 	102
2017-06-05 14:40:28.377686 	zms
	15110 	ERR 	Signal address is 0x4, from 0x565091c579ad 	zm_signal.cpp 	81
2017-06-05 14:40:28.377516 	zms
	15111 	ERR 	Signal address is 0x4, from 0x555f5c0809ad 	zm_signal.cpp 	81
2017-06-05 14:40:28.355152 	zms
	15109 	ERR 	Signal address is 0x4, from 0x561bb94389ad 	zm_signal.cpp 	81
2017-06-05 14:40:28.332933 	zms
	15110 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:28.332815 	zms
	15111 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:28.305135 	zms
	15109 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:28.249022 	zms
	15111 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:28.248859 	zms
	15110 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:28.247451 	zms
	15109 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:25.986133 	zms
	15107 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x5582c0223bb8 0x7fe8a9b33390 0x5582c01d09ad 0x5582c01dd648 0x5582c01a3e01 0x7fe8a6225830 0x5582c01a4bb9 	zm_signal.cpp 	110
2017-06-05 14:40:25.954545 	zms
	15107 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:25.908750 	zms
	15107 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x5582c01a4bb9] 	zm_signal.cpp 	102
2017-06-05 14:40:25.875244 	zms
	15104 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x56321a359bb8 0x7f4d240f8390 0x56321a3069ad 0x56321a313648 0x56321a2d9e01 0x7f4d207ea830 0x56321a2dabb9 	zm_signal.cpp 	110
2017-06-05 14:40:25.841794 	zms
	15107 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fe8a6225830] 	zm_signal.cpp 	102
2017-06-05 14:40:25.808312 	zms
	15104 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:25.774829 	zms
	15107 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x5582c01a3e01] 	zm_signal.cpp 	102
2017-06-05 14:40:25.741537 	zms
	15104 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x56321a2dabb9] 	zm_signal.cpp 	102
2017-06-05 14:40:25.708142 	zms
	15107 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x5582c01dd648] 	zm_signal.cpp 	102
2017-06-05 14:40:25.674618 	zms
	15104 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f4d207ea830] 	zm_signal.cpp 	102
2017-06-05 14:40:25.641165 	zms
	15107 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x5582c01d09ad] 	zm_signal.cpp 	102
2017-06-05 14:40:25.607686 	zms
	15104 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x56321a2d9e01] 	zm_signal.cpp 	102
2017-06-05 14:40:25.574125 	zms
	15107 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fe8a9b33390] 	zm_signal.cpp 	102
2017-06-05 14:40:25.540668 	zms
	15104 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x56321a313648] 	zm_signal.cpp 	102
2017-06-05 14:40:25.507462 	zms
	15107 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5582c0223bb8] 	zm_signal.cpp 	102
2017-06-05 14:40:25.473824 	zms
	15104 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x56321a3069ad] 	zm_signal.cpp 	102
2017-06-05 14:40:25.440481 	zms
	15107 	ERR 	Signal address is 0x4, from 0x5582c01d09ad 	zm_signal.cpp 	81
2017-06-05 14:40:25.406962 	zms
	15104 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f4d240f8390] 	zm_signal.cpp 	102
2017-06-05 14:40:25.373885 	zms
	15107 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:25.340222 	zms
	15104 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x56321a359bb8] 	zm_signal.cpp 	102
2017-06-05 14:40:25.338403 	zms
	15107 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:25.306887 	zms
	15104 	ERR 	Signal address is 0x4, from 0x56321a3069ad 	zm_signal.cpp 	81
2017-06-05 14:40:25.273465 	zms
	15104 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:25.237812 	zms
	15104 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:25.102343 	zms
	15103 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x55a0fe48abb8 0x7fab00f97390 0x55a0fe4379ad 0x55a0fe444648 0x55a0fe40ae01 0x7faafd689830 0x55a0fe40bbb9 	zm_signal.cpp 	110
2017-06-05 14:40:25.080174 	zms
	15103 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:25.057694 	zms
	15103 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x55a0fe40bbb9] 	zm_signal.cpp 	102
2017-06-05 14:40:25.035351 	zms
	15103 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7faafd689830] 	zm_signal.cpp 	102
2017-06-05 14:40:25.013062 	zms
	15103 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x55a0fe40ae01] 	zm_signal.cpp 	102
2017-06-05 14:40:24.990800 	zms
	15103 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x55a0fe444648] 	zm_signal.cpp 	102
2017-06-05 14:40:24.968376 	zms
	15103 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55a0fe4379ad] 	zm_signal.cpp 	102
2017-06-05 14:40:24.946033 	zms
	15103 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fab00f97390] 	zm_signal.cpp 	102
2017-06-05 14:40:24.923879 	zms
	15103 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55a0fe48abb8] 	zm_signal.cpp 	102
2017-06-05 14:40:24.901332 	zms
	15103 	ERR 	Signal address is 0x4, from 0x55a0fe4379ad 	zm_signal.cpp 	81
2017-06-05 14:40:24.879103 	zms
	15103 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:24.860843 	zms
	15103 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-05 14:40:24.778830 	zms
	15102 	INF 	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x55710c96abb8 0x7f75f53cc390 0x55710c9179ad 0x55710c924648 0x55710c8eae01 0x7f75f1abe830 0x55710c8ebbb9 	zm_signal.cpp 	110
2017-06-05 14:40:24.753862 	zms
	15102 	INF 	Backtrace complete, please execute the following command for more information 	zm_signal.cpp 	109
2017-06-05 14:40:24.723000 	zms
	15102 	ERR 	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x55710c8ebbb9] 	zm_signal.cpp 	102
2017-06-05 14:40:24.698038 	zms
	15102 	ERR 	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f75f1abe830] 	zm_signal.cpp 	102
2017-06-05 14:40:24.667182 	zms
	15102 	ERR 	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x55710c8eae01] 	zm_signal.cpp 	102
2017-06-05 14:40:24.642284 	zms
	15102 	ERR 	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x55710c924648] 	zm_signal.cpp 	102
2017-06-05 14:40:24.611420 	zms
	15102 	ERR 	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55710c9179ad] 	zm_signal.cpp 	102
2017-06-05 14:40:24.586458 	zms
	15102 	ERR 	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f75f53cc390] 	zm_signal.cpp 	102
2017-06-05 14:40:24.555649 	zms
	15102 	ERR 	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55710c96abb8] 	zm_signal.cpp 	102
2017-06-05 14:40:24.530557 	zms
	15102 	ERR 	Signal address is 0x4, from 0x55710c9179ad 	zm_signal.cpp 	81
2017-06-05 14:40:24.499546 	zms
	15102 	ERR 	Got signal 11 (Segmentation fault), crashing 	zm_signal.cpp 	50
2017-06-05 14:40:24.341925 	zms
	15102 	ERR 	Got empty memory map file size 0, is the zmc process for this monitor running? 	zm_monitor.cpp 	533
2017-06-04 00:58:54.758947 	zmc_m2
	2518 	ERR 	Unable to get response, disconnecting 	zm_remote_camera_http.cpp 	1141
2017-06-04 00:58:53.801193 	zmc_m2
	2518 	ERR 	Unable to read subheader 	zm_remote_camera_http.cpp 	977
2017-06-04 00:58:52.890349 	zmc_m2
	2518 	ERR 	Select error: Interrupted system call 	zm_remote_camera_http.cpp 	175
2017-06-04 00:58:49.900366 	zma_m1
	12371 	INF 	Got signal 15 (Terminated), exiting 	zm_signal.cpp 	40
2017-06-04 00:58:49.899840 	zma_m3
	2532 	INF 	Got signal 15 (Terminated), exiting 	zm_signal.cpp 	40
2017-06-04 00:58:49.899730 	zmc_m2
	2518 	INF 	Got signal 15 (Terminated), exiting 	zm_signal.cpp 	40
2017-06-04 00:58:49.899400 	zmc_m3
	2528 	INF 	Got signal 15 (Terminated), exiting 	zm_signal.cpp 	40
2017-06-04 00:58:49.897375 	zmc_m1
	12360 	INF 	Got signal 15 (Terminated), exiting 	zm_signal.cpp 	40
2017-06-04 00:58:48.820170 	zmpkg
	23858 	INF 	Command: stop 	zmpkg.pl
2017-06-04 00:58:42.603960 	zmpkg
	23858 	INF 	Sanity checking States table... 	zmpkg.pl
2017-06-04 00:58:40.122943 	zmc_m2
	2518 	INF 	Haustuer: 8110000 - Capturing at 7.69 fps 	zm_monitor.cpp 	3125
2017-06-04 00:58:36.386300 	zmdc
	2479 	INF 	'zma -m 2' exited normally 	zmdc.pl
2017-06-04 00:58:32.447600 	zmdc
	2479 	WAR 	'zma -m 2' has not stopped at 17/06/04 00:58:32. Sending KILL to pid 2520 	zmdc.pl
2017-06-04 00:58:30.614622 	zma_m2
	2520 	INF 	Haustuer: 8107377 - Closing event 96809, shutting down 	zm_monitor.cpp 	625
2017-06-04 00:58:29.582144 	zmc_m2
	2518 	WAR 	Last image read from shared memory 14 seconds ago, zma may have gone away 	zm_monitor.cpp 	3100
2017-06-04 00:58:28.764597 	zmc_m2
	2518 	WAR 	Buffer overrun at index 11, image 8109911, slow down capture, speed up analysis or increase ring buffer size 	zm_monitor.cpp 	3094
2017-06-04 00:58:26.452778 	zma_m2
	2520 	INF 	Got signal 15 (Terminated), exiting 	zm_signal.cpp 	40
2017-06-04 00:58:24.652215 	zma_m3
	2532 	INF 	Autos: 6527000 - Analysing at 2.67 fps 	zm_monitor.cpp 	1296
2017-06-04 00:58:23.761100 	zmdc
	2479 	INF 	'zma -m 2' sending stop to pid 2520 at 17/06/04 00:58:23 	zmdc.pl
2017-06-04 00:58:22.315639 	zmc_m2
	2518 	WAR 	Buffer overrun at index 11, image 8109861, slow down capture, speed up analysis or increase ring buffer size 	zm_monitor.cpp 	3094
2017-06-04 00:58:22.308430 	zmwatch
	2544 	INF 	Restarting analysis daemon for Haustuer 	zmwatch.pl
2017-06-04 00:58:21.019640 	zmwatch
	2544 	INF 	Analysis daemon for Haustuer needs restarting, time since last analysis 6 seconds (1496530701-1496530695) 	zmwatch.pl
2017-06-04 00:58:19.366177 	zma_m2
	2520 	INF 	Haustuer: 8107376 - Opening new event 96809, alarm start 	zm_monitor.cpp 	1660
2017-06-04 00:58:16.912228 	zma_m2
	2520 	INF 	Haustuer: 8107376 - Gone into alarm state 	zm_monitor.cpp 	1614
2017-06-04 00:58:15.858532 	zma_m2
	2520 	INF 	Haustuer: 8107375 - Gone into prealarm state 	zm_monitor.cpp 	1689
2017-06-04 00:57:51.351062 	zma_m1
	12371 	INF 	HintermHaus: 2637000 - Analysing at 1.67 fps 	zm_monitor.cpp 	1296
2017-06-04 00:57:27.111953 	zma_m2
	2520 	INF 	Haustuer: 8107000 - Analysing at 7.69 fps 	zm_monitor.cpp 	1296
2017-06-04 00:56:30.952527 	zmc_m2
	2518 	INF 	Haustuer: 8109000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-04 00:55:34.174036 	zmc_m3
	2528 	INF 	Autos: 6541000 - Capturing at 2.67 fps 	zm_monitor.cpp 	3125
2017-06-04 00:55:17.946609 	zma_m2
	2520 	INF 	Haustuer: 8106000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-04 00:54:21.801184 	zmc_m2
	2518 	INF 	Haustuer: 8108000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-04 00:53:08.936340 	zma_m2
	2520 	INF 	Haustuer: 8105000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-04 00:52:12.792430 	zmc_m2
	2518 	INF 	Haustuer: 8107000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-04 00:52:09.968320 	zma_m3
	2532 	INF 	Autos: 6526000 - Analysing at 2.67 fps 	zm_monitor.cpp 	1296
2017-06-04 00:50:59.885943 	zma_m2
	2520 	INF 	Haustuer: 8104000 - Analysing at 7.75 fps 	zm_monitor.cpp 	1296
2017-06-04 00:50:04.472092 	zma_m2
	2520 	INF 	Haustuer: 8103572 - Closing event 96808, alarm end 	zm_monitor.cpp 	1716
2017-06-04 00:50:04.439654 	zma_m2
	2520 	INF 	Haustuer: 8103572 - Left alarm state (96808) - 56(6) images 	zm_monitor.cpp 	1711
2017-06-04 00:50:03.490649 	zmc_m2
	2518 	INF 	Haustuer: 8106000 - Capturing at 7.75 fps 	zm_monitor.cpp 	3125
2017-06-04 00:50:01.210680 	zma_m2
	2520 	INF 	Haustuer: 8103547 - Gone into alert state 	zm_monitor.cpp 	1704
2017-06-04 00:50:00.616972 	zma_m2
	2520 	INF 	Haustuer: 8103542 - Opening new event 96808, alarm start 	zm_monitor.cpp 	1660
2017-06-04 00:50:00.556172 	zma_m2
	2520 	INF 	Haustuer: 8103542 - Gone into alarm state 	zm_monitor.cpp 	1614
mattionline
Post by mattionline » Fri Jun 09, 2017 1:14 pm
Zoneminder crashed again :(
How can i avoid crashing zoneminder if i am unpacking some things and have temporarily a high load?
Load: 4.08 - Disk: 70% - /dev/shm: 0%
tmpfs 7.8G 728K 7.8G 1% /dev/shm
root@homeserver:~# top
top - 15:07:07 up 41 days, 17:11, 4 users, load average: 3.71, 3.76, 2.83
Tasks: 214 total, 1 running, 213 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.7 us, 8.0 sy, 0.0 ni, 55.7 id, 35.4 wa, 0.0 hi, 0.2 si, 0.0 st
KiB Mem : 16291160 total, 161892 free, 3049192 used, 13080076 buff/cache
KiB Swap: 8245244 total, 6878716 free, 1366528 used. 12666960 avail Mem
2017-06-09 14:49:32.109513	zms		18153	INF	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x5598e6af4bb8 0x7fd944d8c390 0x5598e6aa19ad 0x5598e6aae648 0x5598e6a74e01 0x7fd94147e830 0x5598e6a75bb9	zm_signal.cpp	110
2017-06-09 14:49:32.043861	zms		18153	INF	Backtrace complete, please execute the following command for more information	zm_signal.cpp	109
2017-06-09 14:49:32.008365	zms		18153	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x5598e6a75bb9]	zm_signal.cpp	102
2017-06-09 14:49:31.859821	zms		18153	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fd94147e830]	zm_signal.cpp	102
2017-06-09 14:49:31.583432	zms		18153	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xa91) [0x5598e6a74e01]	zm_signal.cpp	102
2017-06-09 14:49:31.477756	zms		18153	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x5598e6aae648]	zm_signal.cpp	102
2017-06-09 14:49:31.346685	zms		18153	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x5598e6aa19ad]	zm_signal.cpp	102
2017-06-09 14:49:31.304368	zms		18153	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fd944d8c390]	zm_signal.cpp	102
2017-06-09 14:49:31.171478	zms		18153	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5598e6af4bb8]	zm_signal.cpp	102
2017-06-09 14:49:31.023767	zms		18153	ERR	Signal address is 0x4, from 0x5598e6aa19ad	zm_signal.cpp	81
2017-06-09 14:49:30.982939	zms		18153	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-06-09 14:49:30.870570	zms		18153	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-06-09 14:49:30.515753	web_php		28711	ERR	Socket does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.	/usr/share/zoneminder/www/includes/functions.php	2031
2017-06-09 14:48:32.112632	zmc_m2		15248	ERR	Unable to get response, disconnecting	zm_remote_camera_http.cpp	1141
2017-06-09 14:48:31.938044	zma_m3		15664	INF	Autos: 314258 - Closing event 98617, shutting down	zm_monitor.cpp	625
2017-06-09 14:48:31.738781	zmc_m2		15248	ERR	Unable to read subheader	zm_remote_camera_http.cpp	977
2017-06-09 14:48:31.376255	zmc_m2		15248	ERR	Select error: Interrupted system call	zm_remote_camera_http.cpp	175
2017-06-09 14:48:31.171181	zmc_m1		15232	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:31.171129	zmc_m2		15248	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:31.170870	zma_m1		15237	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:31.170402	zmc_m3		15638	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:31.168062	zma_m3		15664	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:30.960720	zmpkg		18090	INF	Command: stop	zmpkg.pl
2017-06-09 14:48:30.804510	zmpkg		18090	INF	Sanity checking States table...	zmpkg.pl
2017-06-09 14:48:30.409903	zmc_m3		15638	WAR	Last image read from shared memory 13 seconds ago, zma may have gone away	zm_monitor.cpp	3100
2017-06-09 14:48:30.162610	zmdc		15202	INF	'zma -m 2' exited normally	zmdc.pl
2017-06-09 14:48:29.986547	zmc_m3		15638	WAR	Buffer overrun at index 15, image 315215, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-06-09 14:48:29.705330	zmdc		15202	WAR	'zma -m 2' has not stopped at 17/06/09 14:48:29. Sending KILL to pid 18041	zmdc.pl
2017-06-09 14:48:29.153825	zma_m2		18041	INF	Haustuer: 028 - Closing event 98619, shutting down	zm_monitor.cpp	625
2017-06-09 14:48:24.087891	zms		18073	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:23.887047	zms		18071	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:23.701470	zma_m2		18041	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:23.192600	zmdc		15202	INF	'zma -m 2' sending stop to pid 18041 at 17/06/09 14:48:23	zmdc.pl
2017-06-09 14:48:23.114400	zmc_m3		15638	WAR	Last image read from shared memory 16 seconds ago, zma may have gone away	zm_monitor.cpp	3100
2017-06-09 14:48:23.114314	zmc_m2		15248	WAR	Last image read from shared memory 16 seconds ago, zma may have gone away	zm_monitor.cpp	3100
2017-06-09 14:48:23.103083	zms		18072	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:20.113278	zmc_m3		15638	WAR	Buffer overrun at index 12, image 315162, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-06-09 14:48:19.969466	zmc_m2		15248	WAR	Buffer overrun at index 37, image 2677687, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-06-09 14:48:17.334020	zmwatch		15273	INF	Restarting analysis daemon for Haustuer	zmwatch.pl
2017-06-09 14:48:13.702790	zmwatch		15273	INF	Analysis daemon for Haustuer needs restarting, time since last analysis 6 seconds (1497012493-1497012487)	zmwatch.pl
2017-06-09 14:48:13.507606	zmc_m2		15248	WAR	Buffer overrun at index 37, image 2677637, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-06-09 14:48:09.930148	zms		18043	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:09.728583	zmc_m3		15638	WAR	Buffer overrun at index 7, image 315107, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-06-09 14:48:09.160958	zma_m2		18041	INF	Haustuer: 027 - Opening new event 98619, alarm start	zm_monitor.cpp	1660
2017-06-09 14:48:07.516594	zma_m2		18041	INF	Haustuer: 027 - Gone into alarm state	zm_monitor.cpp	1614
2017-06-09 14:48:07.057463	zma_m2		18041	INF	Haustuer: 026 - Gone into prealarm state	zm_monitor.cpp	1689
2017-06-09 14:48:04.892992	zma_m2		18041	INF	In mode 3/1, warming up	zma.cpp	142
2017-06-09 14:48:04.446680	zmdc		18041	INF	'zma -m 2' started at 17/06/09 14:48:04	zmdc.pl
2017-06-09 14:48:04.446050	zmdc		15202	INF	'zma -m 2' starting at 17/06/09 14:48:04, pid = 18041	zmdc.pl
2017-06-09 14:48:04.324029	zma_m1		15237	INF	HintermHaus: 1375027 - Gone into prealarm state	zm_monitor.cpp	1689
2017-06-09 14:48:03.801310	zmdc		15202	INF	Starting pending process, zma -m 2	zmdc.pl
2017-06-09 14:48:03.192590	zmdc		15202	INF	'zma -m 2' exited normally	zmdc.pl
2017-06-09 14:48:02.058636	zma_m2		15249	INF	Haustuer: 2675676 - Closing event 98618, shutting down	zm_monitor.cpp	625
2017-06-09 14:48:01.365272	zma_m2		15249	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-06-09 14:48:00.383910	zmdc		15202	INF	'zma -m 2' sending stop to pid 15249 at 17/06/09 14:48:00	zmdc.pl
2017-06-09 14:47:59.327180	zmwatch		15273	INF	Restarting analysis daemon for Haustuer	zmwatch.pl
2017-06-09 14:47:58.086704	zma_m1		15237	INF	HintermHaus: 1375000 - Analysing at 4.98 fps	zm_monitor.cpp	1296
2017-06-09 14:47:57.236890	zmwatch		15273	INF	Analysis daemon for Haustuer needs restarting, time since last analysis 8 seconds (1497012477-1497012469)	zmwatch.pl
2017-06-09 14:47:56.628253	zmc_m3		15638	WAR	Buffer overrun at index 44, image 315044, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-06-09 14:47:55.982397	zmc_m2		15248	WAR	Buffer overrun at index 4, image 2677504, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-06-09 14:47:52.763522	zmc_m3		15638	WAR	Buffer overrun at index 40, image 315040, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-06-09 14:47:50.304845	zma_m2		15249	INF	Haustuer: 2675674 - Opening new event 98618, alarm start	zm_monitor.cpp	1660
2017-06-09 14:47:49.676293	zma_m2		15249	INF	Haustuer: 2675674 - Gone into alarm state	zm_monitor.cpp	1614
2017-06-09 14:47:49.518239	zma_m2		15249	INF	Haustuer: 2675673 - Gone into prealarm state	zm_monitor.cpp	1689
2017-06-09 14:47:47.666470	zmc_m3		15638	INF	Autos: 315000 - Capturing at 8.00 fps	zm_monitor.cpp	3125
2017-06-09 14:47:41.767530	zma_m3		15664	INF	Autos: 314233 - Opening new event 98617, alarm start	zm_monitor.cpp	1660
2017-06-09 14:47:40.831443	zma_m3		15664	INF	Autos: 314233 - Gone into alarm state	zm_monitor.cpp	1614
2017-06-09 14:47:40.160099	zma_m3		15664	INF	Autos: 314232 - Gone into prealarm state	zm_monitor.cpp	1689
2017-06-09 14:41:30.017110	zmupdate		17704	INF	Got version: '1.30.0'	zmupdate.pl
2017-06-09 14:41:29.397340	zmupdate		17704	INF	Checking for updates	zmupdate.pl
2017-06-09 14:41:29.196120	zmdc		17704	INF	'zmupdate.pl -c' started at 17/06/09 14:41:29	zmdc.pl
2017-06-09 14:41:29.193760	zmdc		15202	INF	'zmupdate.pl -c' starting at 17/06/09 14:41:29, pid = 17704	zmdc.pl
2017-06-09 14:41:29.136360	zmdc		15202	INF	Starting pending process, zmupdate.pl -c	zmdc.pl
2017-06-09 14:41:29.089290	zmdc		15202	ERR	'zmupdate.pl -c' exited abnormally, exit status 9	zmdc.pl
2017-06-09 14:41:28.976460	zmupdate		19310	INF	Got version: '1.30.0'	zmupdate.pl
2017-06-09 14:41:28.335980	zmupdate		19310	INF	Checking for updates	zmupdate.pl
My Personal Blog: https://mattionline.de
mattionline
Re: Zoneminder crashed
Post by mattionline » Sun Jul 02, 2017 2:09 pm
I don't know why this happens.
#before restart of zoneminder
tmpfs 7.8G 24K 7.8G 1% /dev/shm
#after manual restart of zoneminder
tmpfs 7.8G 528M 7.3G 7% /dev/shm
2017-07-02 14:35:12.664458	zms		21115	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x563446704d9d]	zm_signal.cpp	102
2017-07-02 14:35:12.664377	zms		21116	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55f480635d9d]	zm_signal.cpp	102
2017-07-02 14:35:12.448278	zms		21114	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x564626588d9d]	zm_signal.cpp	102
2017-07-02 14:35:12.309865	zms		21115	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7efcc8d51390]	zm_signal.cpp	102
2017-07-02 14:35:12.309189	zms		21116	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fa6fe2e7390]	zm_signal.cpp	102
2017-07-02 14:35:12.236544	zms		21114	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7efcba56f390]	zm_signal.cpp	102
2017-07-02 14:35:12.214396	zms		21116	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55f480688fa8]	zm_signal.cpp	102
2017-07-02 14:35:12.214366	zms		21115	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x563446757fa8]	zm_signal.cpp	102
2017-07-02 14:35:12.193782	zms		21114	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5646265dbfa8]	zm_signal.cpp	102
2017-07-02 14:35:12.169837	zms		21116	ERR	Signal address is 0x4, from 0x55f480635d9d	zm_signal.cpp	81
2017-07-02 14:35:12.169675	zms		21115	ERR	Signal address is 0x4, from 0x563446704d9d	zm_signal.cpp	81
2017-07-02 14:35:12.147167	zms		21114	ERR	Signal address is 0x4, from 0x564626588d9d	zm_signal.cpp	81
2017-07-02 14:35:12.125322	zms		21116	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-07-02 14:35:12.125197	zms		21115	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-07-02 14:35:12.091375	zms		21114	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-07-02 14:35:11.978737	zms		21115	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-07-02 14:35:11.978717	zms		21116	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-07-02 14:35:11.974798	zms		21114	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-07-02 01:41:22.577207	zmc_m2		2553	ERR	Unable to get response, disconnecting	zm_remote_camera_http.cpp	1141
2017-07-02 01:41:15.796313	zmc_m2		2553	ERR	Unable to read subheader	zm_remote_camera_http.cpp	977
2017-07-02 01:41:08.861623	zmc_m2		2553	ERR	Select error: Interrupted system call	zm_remote_camera_http.cpp	175
2017-07-02 01:41:00.173607	zmc_m3		23806	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-02 01:41:00.173134	zma_m2		2556	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-02 01:41:00.173096	zmc_m2		2553	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-02 01:41:00.173064	zma_m1		2541	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-02 01:41:00.173017	zmc_m1		2540	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-02 01:40:56.405290	zmwatch		2617	INF	Restarting analysis daemon for Autos	zmwatch.pl
2017-07-02 01:40:53.086600	zmpkg		23868	INF	Command: stop	zmpkg.pl
2017-07-02 01:40:52.977400	zmwatch		2617	ERR	Error getting last capture time for Autos	zmwatch.pl
2017-07-02 01:40:43.073020	zmpkg		23868	INF	Sanity checking States table...	zmpkg.pl
2017-07-02 01:40:40.734160	zmdc		2507	INF	'zma -m 3' exited normally	zmdc.pl
2017-07-02 01:40:35.175260	zmdc		2507	WAR	'zma -m 3' has not stopped at 17/07/02 01:40:35. Sending KILL to pid 18763	zmdc.pl
2017-07-02 01:40:29.174691	zma_m3		18763	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-02 01:40:22.004340	zmdc		2507	INF	'zma -m 3' sending stop to pid 18763 at 17/07/02 01:40:22	zmdc.pl
2017-07-02 01:40:19.448250	zmaudit		2611	INF	Deleted 46 log table entries by time	zmaudit.pl
2017-07-02 01:40:14.937300	zmwatch		2617	INF	Restarting analysis daemon for Autos	zmwatch.pl
2017-07-02 01:40:14.407109	zmc_m2		2553	INF	Haustuer: 6229000 - Capturing at 7.75 fps	zm_monitor.cpp	3125
2017-07-02 01:40:10.564200	zmwatch		2617	ERR	Error getting last capture time for Autos	zmwatch.pl
2017-07-02 01:40:04.103964	zma_m1		2541	INF	HintermHaus: 3170000 - Analysing at 1.66 fps	zm_monitor.cpp	1296
2017-07-02 01:40:00.362357	zmc_m3		23806	INF	Priming capture from rtsp://username:password@192.168.2.141:88/videoMain	zm_ffmpeg_camera.cpp	104
2017-07-02 01:39:58.303774	zmc_m3		23806	INF	Starting Capture version 1.30.4	zmc.cpp	247
2017-07-02 01:39:51.929330	zmdc		23806	INF	'zmc -m 3' started at 17/07/02 01:39:51	zmdc.pl
2017-07-02 01:39:51.929240	zmdc		2507	INF	'zmc -m 3' starting at 17/07/02 01:39:51, pid = 23806	zmdc.pl
2017-07-02 01:39:45.064700	zmdc		2507	INF	Starting pending process, zmc -m 3	zmdc.pl
2017-07-02 01:39:35.887130	zmdc		2507	INF	'zmc -m 3' crashed, signal 8	zmdc.pl
2017-07-02 01:39:28.796870	zmdc		2507	WAR	'zmc -m 3' has not stopped at 17/07/02 01:39:28. Sending KILL to pid 23783	zmdc.pl
2017-07-02 01:39:22.796338	zmc_m3		23783	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-02 01:39:19.960185	zmc_m2		2553	WAR	Last image read from shared memory 11 seconds ago, zma may have gone away	zm_monitor.cpp	3100
2017-07-02 01:39:19.959576	zmc_m3		23783	INF	Priming capture from rtsp://username:password@192.168.2.141:88/videoMain	zm_ffmpeg_camera.cpp	104
2017-07-02 01:39:17.218150	zmdc		2507	INF	'zmc -m 3' sending stop to pid 23783 at 17/07/02 01:39:17	zmdc.pl
2017-07-02 01:39:17.218147	zma_m2		2556	WAR	Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size	zm_monitor.cpp	1324
2017-07-02 01:39:15.422627	zmc_m2		2553	WAR	Buffer overrun at index 42, image 6228542, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3094
2017-07-02 01:39:09.700160	zmc_m3		23783	INF	Starting Capture version 1.30.4	zmc.cpp	247
2017-07-02 01:39:09.111143	zma_m2		2556	INF	Haustuer: 6226000 - Analysing at 7.30 fps	zm_monitor.cpp	1296
2017-07-02 01:39:07.125500	zmdc		2507	INF	'zmc -m 3' starting at 17/07/02 01:39:07, pid = 23783	zmdc.pl
2017-07-02 01:39:07.124240	zmdc		23783	INF	'zmc -m 3' started at 17/07/02 01:39:07	zmdc.pl
2017-07-02 01:39:03.205020	zmdc		2507	INF	Starting pending process, zmc -m 3	zmdc.pl
2017-07-02 01:38:56.283580	zmdc		2507	ERR	'zmc -m 3' exited abnormally, exit status 255	zmdc.pl
2017-07-02 01:38:56.237470	zmwatch		2617	INF	Restarting capture daemon for Autos, shared data not valid	zmwatch.pl
2017-07-02 01:38:49.170980	zmwatch		2617	ERR	Memory map file '/dev/shm/zm.mmap.3' does not exist. zmc might not be running.	zmwatch.pl
2017-07-02 01:38:47.386210	zmdc		23727	INF	'zmc -m 3' started at 17/07/02 01:38:47	zmdc.pl
2017-07-02 01:38:47.386000	zmdc		2507	INF	'zmc -m 3' starting at 17/07/02 01:38:47, pid = 23727	zmdc.pl
2017-07-02 01:38:39.261140	zmdc		2507	INF	Starting pending process, zmc -m 3	zmdc.pl
2017-07-02 01:38:35.179600	zmdc		2507	INF	'zmc -m 3' exited normally	zmdc.pl
2017-07-02 01:38:31.727609	zmc_m3		2597	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-02 01:38:29.176450	zmdc		2507	INF	'zmc -m 3' sending stop to pid 2597 at 17/07/02 01:38:29	zmdc.pl
2017-07-02 01:38:22.559210	zmwatch		2617	INF	Restarting capture daemon for Autos, time since last capture 7 seconds (1498952302-1498952295)	zmwatch.pl
2017-07-02 01:38:15.501826	zmc_m3		2597	INF	Autos: 5023000 - Capturing at 2.67 fps	zm_monitor.cpp	3125
2017-07-02 01:38:05.240266	zmc_m2		2553	INF	Haustuer: 6228000 - Capturing at 7.75 fps	zm_monitor.cpp	3125
2017-07-02 01:36:52.365730	zma_m2		2556	INF	Haustuer: 6225000 - Analysing at 7.58 fps	zm_monitor.cpp	1296
2017-07-02 01:36:16.875579	zmc_m1		2540	INF	HintermHaus: 3173000 - Capturing at 1.67 fps	zm_monitor.cpp	3125
2017-07-02 01:35:56.231286	zmc_m2		2553	INF	Haustuer: 6227000 - Capturing at 7.75 fps	zm_monitor.cpp	3125
2017-07-02 01:34:40.257258	zma_m2		2556	INF	Haustuer: 6224000 - Analysing at 7.46 fps	zm_monitor.cpp	1296
Post by rockedge » Mon Jul 03, 2017 12:23 am
this was happening to me with v 1.30.1 and 1.30.2....I upgraded to v 1.30.4 and it stopped. It seemed in my case one of my cameras (wifi net cam) would lose signal. When this cam restarted on its own the original process would be still running and a new one created. The camera would lose signal again...restart and this process of creating zms instances kept up until zoneminder crashed with /dev/shm at 100%. But until then, everything seemed normal.
mattionline
Post by mattionline » Mon Jul 03, 2017 2:56 pm
I currently have Version 1.30.4.
Just one Camera is connected via wifi.
I will Test it with a Network cable.
But independently a deadlock/livelock should not happen in a software.
mattionline
Post by mattionline » Sat Jul 29, 2017 8:24 am
It happened again :(
How is it possible to stop zoneminder crashing?
I think i will try a new clean installation with the newest version.
It could be the problem with a wifi camera that it loses sometimes the connection, but zoneminder should close the old process like you described it.
2017-07-29 10:21:03.735772	zms		17429	INF	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x5559cafe8fa8 0x7fb022285390 0x5559caf95d9d 0x5559cafa2a38 0x5559caf6906e 0x7fb01e976830 0x5559caf69f69	zm_signal.cpp	110
2017-07-29 10:21:03.713567	zms		17427	INF	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x55cccd803fa8 0x7f1ba1433390 0x55cccd7b0d9d 0x55cccd7bda38 0x55cccd78406e 0x7f1b9db24830 0x55cccd784f69	zm_signal.cpp	110
2017-07-29 10:21:03.713405	zms		17428	INF	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x55a87bb97fa8 0x7f5c4596d390 0x55a87bb44d9d 0x55a87bb51a38 0x55a87bb1806e 0x7f5c4205e830 0x55a87bb18f69	zm_signal.cpp	110
2017-07-29 10:21:03.691160	zms		17429	INF	Backtrace complete, please execute the following command for more information	zm_signal.cpp	109
2017-07-29 10:21:03.668967	zms		17427	INF	Backtrace complete, please execute the following command for more information	zm_signal.cpp	109
2017-07-29 10:21:03.668737	zms		17428	INF	Backtrace complete, please execute the following command for more information	zm_signal.cpp	109
2017-07-29 10:21:03.646412	zms		17429	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x5559caf69f69]	zm_signal.cpp	102
2017-07-29 10:21:03.624240	zms		17428	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x55a87bb18f69]	zm_signal.cpp	102
2017-07-29 10:21:03.624121	zms		17427	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x29) [0x55cccd784f69]	zm_signal.cpp	102
2017-07-29 10:21:03.601760	zms		17429	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fb01e976830]	zm_signal.cpp	102
2017-07-29 10:21:03.579655	zms		17427	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f1b9db24830]	zm_signal.cpp	102
2017-07-29 10:21:03.579500	zms		17428	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f5c4205e830]	zm_signal.cpp	102
2017-07-29 10:21:03.557089	zms		17429	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xb9e) [0x5559caf6906e]	zm_signal.cpp	102
2017-07-29 10:21:03.534920	zms		17428	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xb9e) [0x55a87bb1806e]	zm_signal.cpp	102
2017-07-29 10:21:03.534737	zms		17427	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xb9e) [0x55cccd78406e]	zm_signal.cpp	102
2017-07-29 10:21:03.512295	zms		17429	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x5559cafa2a38]	zm_signal.cpp	102
2017-07-29 10:21:03.490141	zms		17427	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x55cccd7bda38]	zm_signal.cpp	102
2017-07-29 10:21:03.490012	zms		17428	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x48) [0x55a87bb51a38]	zm_signal.cpp	102
2017-07-29 10:21:03.467651	zms		17429	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x5559caf95d9d]	zm_signal.cpp	102
2017-07-29 10:21:03.445502	zms		17427	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55cccd7b0d9d]	zm_signal.cpp	102
2017-07-29 10:21:03.445341	zms		17428	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0xd) [0x55a87bb44d9d]	zm_signal.cpp	102
2017-07-29 10:21:03.374682	zms		17429	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7fb022285390]	zm_signal.cpp	102
2017-07-29 10:21:03.352622	zms		17427	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f1ba1433390]	zm_signal.cpp	102
2017-07-29 10:21:03.352382	zms		17428	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x11390) [0x7f5c4596d390]	zm_signal.cpp	102
2017-07-29 10:21:03.330111	zms		17429	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5559cafe8fa8]	zm_signal.cpp	102
2017-07-29 10:21:03.307909	zms		17428	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55a87bb97fa8]	zm_signal.cpp	102
2017-07-29 10:21:03.307904	zms		17427	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55cccd803fa8]	zm_signal.cpp	102
2017-07-29 10:21:03.285455	zms		17428	ERR	Signal address is 0x4, from 0x55a87bb44d9d	zm_signal.cpp	81
2017-07-29 10:21:03.285382	zms		17429	ERR	Signal address is 0x4, from 0x5559caf95d9d	zm_signal.cpp	81
2017-07-29 10:21:03.263113	zms		17427	ERR	Signal address is 0x4, from 0x55cccd7b0d9d	zm_signal.cpp	81
2017-07-29 10:21:03.240863	zms		17429	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-07-29 10:21:03.240778	zms		17428	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-07-29 10:21:03.218505	zms		17427	ERR	Got signal 11 (Segmentation fault), crashing	zm_signal.cpp	50
2017-07-29 10:21:03.214167	zms		17429	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-07-29 10:21:03.212928	zms		17428	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-07-29 10:21:03.102329	zms		17427	ERR	Got empty memory map file size 0, is the zmc process for this monitor running?	zm_monitor.cpp	533
2017-07-29 02:15:33.744198	zmc_m2		8274	ERR	Unable to get response, disconnecting	zm_remote_camera_http.cpp	1141
2017-07-29 02:15:33.721457	zmc_m2		8274	ERR	Unable to read subheader	zm_remote_camera_http.cpp	977
2017-07-29 02:15:33.699288	zmc_m2		8274	ERR	Select error: Interrupted system call	zm_remote_camera_http.cpp	175
2017-07-29 02:15:33.644091	zmc_m3		8218	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-29 02:15:33.643840	zmc_m2		8274	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-29 02:15:33.643551	zmc_m1		726	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-29 02:15:33.643213	zma_m1		29044	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-29 02:15:33.642913	zma_m2		29031	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-29 02:15:33.642561	zma_m3		29046	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-07-29 02:15:33.521870	zmpkg		31701	INF	Command: stop	zmpkg.pl
2017-07-29 02:15:33.479650	zmpkg		31701	INF	Sanity checking States table...	zmpkg.pl
2017-07-29 02:15:33.233800	zmupdate		3721	INF	Got version: '1.30.0'	zmupdate.pl
2017-07-29 02:15:32.328720	zmupdate		3721	INF	Checking for updates	zmupdate.pl
2017-07-29 02:15:27.423409	zmc_m2		8274	INF	Haustuer: 14139000 - Capturing at 7.75 fps	zm_monitor.cpp	3125
2017-07-29 02:15:23.393591	zmc_m1		726	INF	HintermHaus: 7129000 - Capturing at 1.67 fps	zm_monitor.cpp	3125
2017-07-29 02:14:41.990265	zma_m2		29031	INF	Haustuer: 9774000 - Analysing at 7.75 fps	zm_monitor.cpp	1296
Post by rockedge » Sun Jul 30, 2017 2:50 pm
I think you have a good idea by installing a newer version of ZM. A fresh start on a fresh system. Follow all the steps according to your version of operating system.
let us know how you progress!
Users browsing this forum: No registered users and 11 guests
