new install on Ubuntu, not finding Kodicom 8800
darkpaw
Post by darkpaw »
I had to flatten my server, so I figured I'd go to the most recent Ubuntu (17.4). It installed fine, and the new docs for installing ZM are fantastic, it was a breeze.
The problem appears to be my input card. I setup the bttv.conf in modprobe.d, and it finds the card fine. But no /dev/video* gets created. Is this something that changed in newer versions of Ubuntu? My previous (running long time) install was 14.4 LTS.
root@zm:/dev# dmesg | grep bttv
[ 14.545525] bttv: driver version 0.9.19 loaded
[ 14.545527] bttv: using 2 buffers with 2080k (520 pages) each for capture
[ 14.545569] bttv: Bt8xx card found (0)
[ 14.545909] bttv: 0: Bt878 (rev 17) at 0000:06:0c.0, irq: 17, latency: 64, mmio: 0xf4ffe000
[ 14.545927] bttv: 0: using: IVC-200 [card=102,insmod option]
[ 14.546109] bttv: 0: tuner absent
[ 14.546110] bttv: 0: the autoload option is obsolete
[ 14.546111] bttv: 0: use option msp3400, tda7432 or tvaudio to override which audio module should be used
[ 14.546178] bttv: probe of 0000:06:0c.0 failed with error -34
[ 14.546185] bttv: Bt8xx card found (0)
[ 14.546249] bttv: 0: Bt878 (rev 17) at 0000:06:0d.0, irq: 18, latency: 64, mmio: 0xf4ffc000
[ 14.546258] bttv: 0: using: IVC-200 [card=102,insmod option]
[ 14.546413] bttv: 0: tuner absent
[ 14.546414] bttv: 0: the autoload option is obsolete
[ 14.546415] bttv: 0: use option msp3400, tda7432 or tvaudio to override which audio module should be used
[ 14.546498] bttv: probe of 0000:06:0d.0 failed with error -34
[ 14.546506] bttv: Bt8xx card found (0)
[ 14.546574] bttv: 0: Bt878 (rev 17) at 0000:06:0e.0, irq: 19, latency: 64, mmio: 0xf4ffa000
[ 14.546581] bttv: 0: using: IVC-200 [card=102,insmod option]
[ 14.546718] bttv: 0: tuner absent
[ 14.546719] bttv: 0: the autoload option is obsolete
[ 14.546720] bttv: 0: use option msp3400, tda7432 or tvaudio to override which audio module should be used
[ 14.546798] bttv: probe of 0000:06:0e.0 failed with error -34
[ 14.546806] bttv: Bt8xx card found (0)
[ 14.546858] bttv: 0: Bt878 (rev 17) at 0000:06:0f.0, irq: 16, latency: 64, mmio: 0xf4ff8000
[ 14.546866] bttv: 0: using: IVC-200 [card=102,insmod option]
[ 14.546994] bttv: 0: tuner absent
[ 14.546995] bttv: 0: the autoload option is obsolete
[ 14.546996] bttv: 0: use option msp3400, tda7432 or tvaudio to override which audio module should be used
[ 14.547061] bttv: probe of 0000:06:0f.0 failed with error -34
root@zm:/dev# ls /dev/video*
ls: cannot access '/dev/video*': No such file or directory
root@zm:/dev#
darkpaw
Re: new install on Ubuntu, not finding Kodicom 8800
Post by darkpaw »
Turns out the card was dead. Swapped it with another card and good to go. These cards seem to burn out fairly easily.
I've heard it said that you should put heatsinks on the chips... I usually just make sure there is direct airflow over them.
mastertheknife
Post by mastertheknife »
A bit late but this also happened to me today, after upgrading my ZM box from CentOS6 to CentOS7.
The exact same error: "bttv: probe of 0000:06:08.0 failed with error -34"
I know for a fact that the card is fine because it has been working fine for years.
After many attempts with the options in bttv.conf, i found that its the combfilter option causing this error. Removing it got the card working!
So don't give up, its not your card, its just a newer kernel\driver.
Here is my /etc/modprobe.d/bttv.conf file that is currently working (after removing combfilter):
# bttv module options
# For fast loading
options i2c-algo-bit bit_test=1
# The first bttv device is a pico2000 clone, the other 8 are a kodicom 8800 clone.
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 full_luma_range=1 coring=1
Kfir Itzhak.
