Hello everyone.
Please help me solve my problem. I try to export event, But nothing happens.
I made all the settings according to the instructions (Easy Way: Ubuntu 16.04).
In the attachment print screen error.
Export Error
Export Error
- 2017-03-21_173204.jpg (240.52 KiB) Viewed 3278 times
- 2017-03-21_172551.jpg (485.48 KiB) Viewed 3278 times
- 2017-03-21_172442.jpg (275.62 KiB) Viewed 3278 times
Re: Export Error
I think your ZM is unable to write to /var/cache/zoneminder/temp (/var/cache/zoneminder is the location of event,images,temp directories in an ubuntu install)
Check the permissions and that the directory exists......
Re: Export Error
Did you enable ffmpeg?
Options - Images - OPT_FFMPEG
Re: Export Error
bbunge wrote:Did you enable ffmpeg?
Also check Options::Images::PATH_FFMPEG, it should have the path to the ffmpeg (in my system is /usr/bin/ffmpeg). If you don´t know the path, run the command which ffmpeg.
Hope it helps,
PacoLM
Re: Export Error
FFMPEG enabled.
root@PC:/home/user# which ffmpeg
/usr/bin/ffmpeg
Options::Images:OPT_FFMPEG - checked
Options::Images::PATH_FFMPEG - /usr/bin/ffmpeg
Directories and permissions is OK
root@PC:/var/cache/zoneminder# ls -la
drwxr-xr-x 5 www-data www-data 4096 мар 21 09:08 .
drwxr-xr-x 18 root root 4096 мар 21 17:37 ..
drwxr-xr-x 3 www-data www-data 4096 мар 21 18:36 events
drwxr-xr-x 2 www-data www-data 4096 фев 15 02:45 images
drwxr-xr-x 2 www-data www-data 4096 мар 22 08:43 temp
I also noticed the following: if you export to a tar file, then the export goes (the file "zmExport.tar.gz" appears in the directory "/var/cache/zoneminder/temp"), but the link for downloading the file does not appear and in the window export is still in progress.
/usr/bin/ffmpeg
Re: Export Error
The problem was sold by changing OPTION::SYSTEM::LANG_DEFAULT (from ru_ru to en_us). Export now works exelent.
It's a pity but not all the functional works with the Russian interface. To the note to the developers!!!
Re: Export Error
За здоровье!
Re: Export Error
Impressive catch!
