camera feed not diplaying in ZM firefox/chrome interface
bilaly
Post by bilaly »
I recently installed ZoneMinder on an old laptop and configured my Amcrest ProHD IP2M-841B to work with it. When I try to view the feed in both firefox and chrome by clicking the Name of the monitor a window opens but no image is displayed. I can view the stills in the event log for when motion is detected and I can view the live camera feed from my Home Assistant Installation (using the ZoneMinder Camera component).
I feel that there must be something wrong with my browsers. I have tried deleting web cache etc and reinstalling the browsers but no luck.
Not sure what i can or should provide in terms of logs to help others assist me.
Re: camera feed not diplaying in ZM firefox/chrome interface
check the Apache configuration that the alias for /cgi-bin is correct.
check the paths for /cgi-bin in Options->Paths->PATH_ZMS.
This sounds like the streaming components aren't being engaged.
bilaly
Post by bilaly »
thanks for the reply..
i checked /etc/apache2/conf-enabled/zoneminder.conf
and found:
AllowOverride All
Require all granted
</Directory>
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
AllowOverride All
</Directory>
Under Options->Paths->PATH_ZMS: PATH_ZMS = /cgi-bin/nph-zms
This looks right according to the docs in the ubuntu installation section 'Socket_sendto or no live streaming'
bilaly wrote: Under Options->Paths->PATH_ZMS: PATH_ZMS = /cgi-bin/nph-zms
I assume you are you are referring to this?
http://zoneminder.readthedocs.io/en/sta ... -streaming
Might want to look at it again because your PATH_ZMS is not set correctly. You are missing /zm.
When installing zoneminder on Ubuntu, follow the "Easy way" documentation in the wiki. It steps you through everything needed to get zoneminder working properly, including the proper value for PATH_ZMS.
https://wiki.zoneminder.com/Ubuntu
IMPORTANT FINAL STEP: open Zoneminder in a web browser (http://server-ip/zm). Click on Options - Paths and change PATH_ZMS to
/zm/cgi-bin/nph-zms
Click the SAVE button
bilaly
Post by bilaly »
haha wow my apologies I feel like an idiot. thanks a bunch worked like a treat. can't believe i missed the /zm
