Attention zmrepo el7 users
Rpmfusion recently added rhel 7 support to their repository. That means I no longer have to build ffmpeg, vlc, and all their dependencies by hand.
Over the weekend, I cut zmrepo over to use the new rpmfusion rpms. These packages are slightly newer, and even add h265 support (if anyone has a really new ip camera which streams h265).
These packages will show up during the next "yum update" on your rhel/centos/sl system.
Be advised that, in order to avoid any signing key failures, you should first update the zmrepo rpm, and only then update the rest of your system.
In other words, do this:
sudo yum update zmrepo
sudo yum update
benf
Re: Attention zmrepo el7 users
Post by benf »
Thanks for this - had been seeing updates failing reporting incorrect GPG keys - but with above now all sorted.
