ffplay -f v4l2 -input_format mjpeg -framerate 4 -i /dev/video0
ffplay -f v4l2 -input_format mjpeg -framerate 4 -i /dev/video1
But I fail to get ZM to do the same. I am getting:
Failed to start capture stream: No space left on device
I have tried to set "FFMPEG_INPUT_OPTIONS Additional input options to ffmpeg (?)" to:
framerate and mjpeg also selected at source tab.
This is my log:
2017-03-08 22:30:14.958590 zmdc 14397 ERR 'zmc -d /dev/video1' exited abnormally, exit status 255 zmdc.pl
2017-03-08 22:30:14.944485 zmc_dvideo1 14441 FAT Failed to start capture stream: No space left on device zm_local_camera.cpp 2001
2017-03-08 22:30:14.941917 zmc_dvideo1 14441 WAR Hue control is not supported zm_local_camera.cpp 1810
2017-03-08 22:30:14.935910 zmc_dvideo1 14441 WAR Failed to get JPEG compression options: Inappropriate ioctl for device zm_local_camera.cpp 773
2017-03-08 22:30:14.650890 zmdc 14474 INF 'zmtelemetry.pl' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.650890 zmdc 14397 INF 'zmtelemetry.pl' starting at 17/03/08 22:30:14, pid = 14474 zmdc.pl
2017-03-08 22:30:14.645820 zmwatch 14467 INF Watchdog pausing for 30 seconds zmwatch.pl
2017-03-08 22:30:14.643980 zmwatch 14467 INF Watchdog starting zmwatch.pl
2017-03-08 22:30:14.575920 zmtrigger 14460 INF Opening connection 'Chan2 Unix Socket at /var/run/zm/zmtrigger.sock' zmtrigger.pl
2017-03-08 22:30:14.574960 zmtrigger 14460 INF Opening connection 'Chan1 TCP on port 6802' zmtrigger.pl
2017-03-08 22:30:14.573530 zmtrigger 14460 INF Trigger daemon starting zmtrigger.pl
2017-03-08 22:30:14.570390 zmdc 14397 INF 'zmwatch.pl' starting at 17/03/08 22:30:14, pid = 14467 zmdc.pl
2017-03-08 22:30:14.570390 zmdc 14467 INF 'zmwatch.pl' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.492540 zmdc 14397 INF 'zmtrigger.pl' starting at 17/03/08 22:30:14, pid = 14460 zmdc.pl
2017-03-08 22:30:14.492540 zmdc 14460 INF 'zmtrigger.pl' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.416520 zmfilter 14449 INF Scanning for events zmfilter.pl
2017-03-08 22:30:14.368770 zmdc 14397 INF 'zmaudit.pl -c' starting at 17/03/08 22:30:14, pid = 14454 zmdc.pl
2017-03-08 22:30:14.368770 zmdc 14454 INF 'zmaudit.pl -c' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.258676 zmc_dvideo0 14428 WAR Hue control is not supported zm_local_camera.cpp 1810
2017-03-08 22:30:14.258341 zmc_dvideo1 14441 INF Starting Capture version 1.30.2 zmc.cpp 250
2017-03-08 22:30:14.252186 zmc_dvideo0 14428 WAR Failed to get JPEG compression options: Inappropriate ioctl for device zm_local_camera.cpp 773
2017-03-08 22:30:14.244380 zmdc 14449 INF 'zmfilter.pl' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.243950 zmdc 14397 INF 'zmfilter.pl' starting at 17/03/08 22:30:14, pid = 14449 zmdc.pl
2017-03-08 22:30:14.212010 zmdc 14397 ERR 'zma -m 5' exited abnormally, exit status 255 zmdc.pl
2017-03-08 22:30:14.208632 zma_m5 14447 ERR Shared data not initialised by capture daemon for monitor Monitor-5 zm_monitor.cpp 442
2017-03-08 22:30:14.181730 zmdc 14447 INF 'zma -m 5' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.181680 zmdc 14397 INF 'zma -m 5' starting at 17/03/08 22:30:14, pid = 14447 zmdc.pl
2017-03-08 22:30:14.175980 zmdc 14397 INF Starting pending process, zma -m 5 zmdc.pl
2017-03-08 22:30:14.174170 zmdc 14397 ERR 'zma -m 5' exited abnormally, exit status 255 zmdc.pl
2017-03-08 22:30:14.170811 zma_m5 14443 ERR Shared data not initialised by capture daemon for monitor Monitor-5 zm_monitor.cpp 442
2017-03-08 22:30:14.143960 zmdc 14443 INF 'zma -m 5' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.143960 zmdc 14397 INF 'zma -m 5' starting at 17/03/08 22:30:14, pid = 14443 zmdc.pl
2017-03-08 22:30:14.087098 zmc_dvideo1 14441 INF No direct match for the selected palette ( zm_local_camera.cpp 412
2017-03-08 22:30:14.067840 zmdc 14441 INF 'zmc -d /dev/video1' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.067830 zmdc 14397 INF 'zmc -d /dev/video1' starting at 17/03/08 22:30:14, pid = 14441 zmdc.pl
2017-03-08 22:30:14.065490 zmdc 14397 INF Starting pending process, zmc -d /dev/video1 zmdc.pl
2017-03-08 22:30:14.064581 zmc_dvideo0 14428 INF Starting Capture version 1.30.2 zmc.cpp 250
2017-03-08 22:30:14.063730 zmdc 14397 ERR 'zmc -d /dev/video1' exited abnormally, exit status 255 zmdc.pl
2017-03-08 22:30:14.060171 zmc_dvideo1 14438 INF No direct match for the selected palette ( zm_local_camera.cpp 412
2017-03-08 22:30:14.036490 zmdc 14438 INF 'zmc -d /dev/video1' started at 17/03/08 22:30:14 zmdc.pl
2017-03-08 22:30:14.036470 zmdc 14397 INF 'zmc -d /dev/video1' starting at 17/03/08 22:30:14, pid = 14438 zmdc.pl
2017-03-08 22:30:14.003490 zmdc 14397 ERR 'zma -m 4' exited abnormally, exit status 255 zmdc.pl
2017-03-08 22:30:13.999806 zma_m4 14435 ERR Shared data not initialised by capture daemon for monitor Monitor-4 zm_monitor.cpp 442
2017-03-08 22:30:13.972010 zmdc 14435 INF 'zma -m 4' started at 17/03/08 22:30:13 zmdc.pl
2017-03-08 22:30:13.972010 zmdc 14397 INF 'zma -m 4' starting at 17/03/08 22:30:13, pid = 14435 zmdc.pl
2017-03-08 22:30:13.969740 zmdc 14397 INF Starting pending process, zma -m 4 zmdc.pl
2017-03-08 22:30:13.968000 zmdc 14397 ERR 'zma -m 4' exited abnormally, exit status 255 zmdc.pl
2017-03-08 22:30:13.964429 zma_m4 14430 ERR Shared data not initialised by capture daemon for monitor Monitor-4 zm_monitor.cpp 442
2017-03-08 22:30:13.939830 zmdc 14430 INF 'zma -m 4' started at 17/03/08 22:30:13 zmdc.pl
2017-03-08 22:30:13.939810 zmdc 14397 INF 'zma -m 4' starting at 17/03/08 22:30:13, pid = 14430 zmdc.pl
2017-03-08 22:30:13.903000 zmc_dvideo0 14428 INF No direct match for the selected palette ( zm_local_camera.cpp 412
2017-03-08 22:30:13.883560 zmdc 14428 INF 'zmc -d /dev/video0' started at 17/03/08 22:30:13 zmdc.pl
2017-03-08 22:30:13.883510 zmdc 14397 INF 'zmc -d /dev/video0' starting at 17/03/08 22:30:13, pid = 14428 zmdc.pl
2017-03-08 22:30:13.881680 zmdc 14397 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
2017-03-08 22:30:13.879890 zmdc 14397 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2017-03-08 22:30:13.877022 zmc_dvideo0 14424 INF No direct match for the selected palette ( zm_local_camera.cpp 412
2017-03-08 22:30:13.852920 zmdc 14424 INF 'zmc -d /dev/video0' started at 17/03/08 22:30:13 zmdc.pl
2017-03-08 22:30:13.852910 zmdc 14397 INF 'zmc -d /dev/video0' starting at 17/03/08 22:30:13, pid = 14424 zmdc.pl
2017-03-08 22:30:13.752610 zmpkg 14383 INF Single server configuration detected. Starting up services. zmpkg.pl
2017-03-08 22:30:10.745890 zmdc 14397 INF Server starting at 17/03/08 22:30:10 zmdc.pl
2017-03-08 22:30:10.593310 zmpkg 14383 INF Command: start zmpkg.pl
2017-03-08 22:30:10.589910 zmpkg 14383 INF Sanity checking States table... zmpkg.pl
2017-03-08 22:30:10.500340 zmsystemctl 14379 INF Redirecting command through systemctl zmsystemctl.pl
2017-03-08 22:30:10.428710 zmpkg 14373 INF Command: start zmpkg.pl
2017-03-08 22:30:10.425340 zmpkg 14373 INF Sanity checking States table... zmpkg.pl
