FOSCAM FI9961EP SETUP
wjcunning
Post by wjcunning »
Here are the parameters that work in ZM.
Enjoy!
Source Type: Remote
Analysis FPS: 30
Maximum FPS: 30
Alarm Max FPS: 30
Remote Protocol: RTSP
Remote Method: RTP/RTSP
Remote Name Host: login:password@IPaddress
Remote Host Port: 88
Remote Host Path: /VideoMain
Capture Width: 1920
Capture Height: 1080
Wild Bill
Re: FOSCAM FI9961EP SETUP
For starters:
Analysis FPS:
Maximum FPS:
Alarm Max FPS:
Check your resolution with VLC. Lower the resolution and frame rate by half or more
wjcunning
Post by wjcunning »
Works for me with the numbers posted. Leaving as is. Seems to like ZM.
Mata2
Post by Mata2 »
Hi... I have tried this and keep getting a blank screen on ZM 1.30.4 and Ubuntu 17.10. Firmware on Camera is updated. The camera works fine on Foscam software. Can anyone help?
Get the camera to stream with VLC. Also use VLC to check the reported resolution and use that in ZM. Use ffmpeg.
Techno_81
Post by Techno_81 »
Does any one have this working?
Would it possible to post a few screen shots of their settings in ZoneMinder and from the FOSCAM camera Settings.
I just cant get this to work for the life of me. Works fine from VLC.
rpdrewes
Post by rpdrewes »
The url posted in the initial message as "/VideoMain" did not work for me but "/videoMain" (with initial letter not capital) did work. It's quite possible if you are having problems you may be capitalizing it without realizing so.
Rich
