{RESOLVED} 1.30.2 bug with api and authentification
fennec
Post by fennec »
Hi
after update from iconnor-zoneminder-master to 1.30.2
all my python scripts stop because i have a problem with cookies
My code
url1="http://"+ip+"/zm/index.php?username="+username+"&password="+password+"&action=login&view=console"
	req1 = urllib2.Request(url1)
	response = urllib2.urlopen(req1)
	cookie = response.headers.get('Set-Cookie')
	url=urllib2.Request('http://'+ip+'/zm/api/events/index/MonitorId:'+monit+'/StartTime%20=:'+date+'%20'+heur+'.json')
	url.add_header('cookie', cookie)
	url=urllib2.urlopen(url)
in 1.30.1 all is ok but now
Traceback (most recent call last):
  File "/home/fennec/scripts/videozm.py", line 90, in <module>
  File "/usr/lib/python2.7/urllib2.py", line 127, in urlopen
    return _opener.open(url, data, timeout)
  File "/usr/lib/python2.7/urllib2.py", line 410, in open
    response = meth(req, response)
  File "/usr/lib/python2.7/urllib2.py", line 523, in http_response
    'http', request, response, code, msg, hdrs)
  File "/usr/lib/python2.7/urllib2.py", line 448, in error
    return self._call_chain(*args)
  File "/usr/lib/python2.7/urllib2.py", line 382, in _call_chain
    result = func(*args)
  File "/usr/lib/python2.7/urllib2.py", line 531, in http_error_default
    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 401: Unauthorized
print cookie
ZMSESSID=4allb0rbi9mi9cbpjbee9ssdm0; path=/; HttpOnly, zmSkin=classic; expires=Mon, 21-Dec-2026 13:23:20 GMT; Max-Age=311040000, zmCSS=flat; expires=Mon, 21-Dec-2026 13:23:20 GMT; Max-Age=311040000, ZMSESSID=dnktpou2l27lqga7s80eeqfn52; path=/; HttpOnly
Thanks for your help
Re: 1.30.2 bug with api and authentification
I don't have a lot of experience working with cookies or how they should work with zoneminder, so we may need to wait until someone else can jump in.
However, what I can tell you is that the following works for me on a couple of 1.30.2 machines (one CentOS 7 and the other Armbian/Debian 8 ) I am testing from:
- http://server/zm/api/host/getVersion.json returns proper result after authenticating
- The commandline works too: curl http://server/zm/api/host/getVersion.json
- zmninja works
If you don't have zmninja, then try at least first step:
- login to the web console using the same user & pwd as your python script
- paste http://server/zm/api/host/getVersion.json into you bowser and tell us what you get
One of the security issues we fixed with this release had to do with setting the secure flag when setting the cookie. I'm not exactly sure why that would cause you problems, but to restore 1.30.1 behaviour, you can comment out lines 113 to 121 of index.php in /usr/share/zoneminder/www/index.php
fennec
Post by fennec »
Thanks for all
i try that
SteveGilvarry
Post by SteveGilvarry »
I think the new flags on the cookie are preventing you from passing the cookie around between two requests, I tried cookielib and it works for me. But not a bug, just client side cookie handling complexity.
import cookielib, urllib2
ip='xxx.xxx.xxx.xxx'
username='admin'
password='admin'
monit='1'
date='20170212'
heur='06'
url1='http://'+ip+'/zm/index.php?username='+username+'&password='+password+'&action=login&view=console'
apiurl='http://'+ip+'/zm/api/events/index/MonitorId:'+monit+'/StartTime%20=:'+date+'%20'+heur+'.json'
cj = cookielib.CookieJar()
opener = urllib2.build_opener(urllib2.HTTPCookieProcessor(cj))
r = opener.open(url1)
content = r.read()
api = opener.open(apiurl)
apicontent = api.read()
fennec
Post by fennec »
SteveGilvarry wrote:I think the new flags on the cookie are preventing you from passing the cookie around between two requests, I tried cookielib and it works for me. But not a bug, just client side cookie handling complexity.
username='admin'
password='admin'
monit='1'
date='20170212'
heur='06'
content = r.read()
Thanks it's works :D :D
