I learned 2 things... Even if your virtual environment hosts your NAS directly and you have a 10GB connection between the hosts, NAS mounted via NFS capable of 200MBps sustained write isn't fast enough for ZM. I needed to create a VMDK (virtual disk - that happens to be stored on said NAS) and it worked ok... I tried before with just an NFS mount and its wasn't fast enough, resulted in a bunch of ring buffer overflows.
Now to my current issue. Immediately after login, I get this in the error log. It doesn't seem to cause any issues and everything works, but it does place an ERR in the log, which cause the log link to go red, meaning I usually check it to ensure that the system is performing optimally.
Anyone have any ideas?
ERR Uncaught SecurityError: Blocked a frame with origin "https://my.domain.tld" from accessing a cross-origin frame. https://my.domain.tld/zm/skins/classic/js/skin.js 167
