Dahua IPC-HDBW4431R-AS
reubenwrotethis
Post by reubenwrotethis »
Hi all,
I've been tearing my hair out for the past few days trying to get my first stream running with no success. I have a Dahua IPC-HDBW4431R-AS, I've been trying to follow all the combinations on this page (https://wiki.zoneminder.com/Dahua) but nothing. I have Zoneminder v1.30.0 running under Ubuntu 16.04 LTS (GNU/Linux 4.4.6-1-pve x86_64), it is a LXC container on my server, but I don't know if this is the issue.
Depending on my settings depends on the error message I get. This is current errors using remote source: ffmpeg:
2016-12-16 07:03:57.890170 zmdc 1475 INF 'zmc -m 1' starting at 16/12/15 20:33:57, pid = 7708 zmdc.pl
2016-12-16 07:03:57.826490 zmdc 7708 INF 'zmc -m 1' started at 16/12/15 20:33:57 zmdc.pl
2016-12-16 07:03:53.374440 zmwatch 1523 INF Restarting capture daemon for Front-Entrance, shared data not valid zmwatch.pl
2016-12-16 07:03:43.369900 zmdc 1475 INF 'zmc -m 1' exited, signal 14 zmdc.pl
2016-12-16 07:03:42.974320 zmdc 1475 INF 'zmc -m 1' sending stop to pid 7702 at 16/12/15 20:33:42 zmdc.pl
2016-12-16 07:03:35.356560 zmwatch 1523 INF Restarting capture daemon for Front-Entrance, shared data not valid zmwatch.pl
I'm not sure if the error is with my camera settings or zoneminder. The camera is supposed to have ONVIF but if I try adding this way zoneminder seems to recognize it, but after entering username and password it gives back status 255.
If I use VLC I can see the stream the following ways:
rtsp://admin:admin@192.168.1.80
rtsp://admin:admin@192.168.1.80:554/live
rtsp://admin:admin@192.168.1.80:554/cam/realmonitor?channel=1&subtype=0
In zomeminder I use the following settings:
SourceType:ffmpeg
All FPS leave blank
Source Path: rtsp://admin:admin@192.168.1.80:554/cam/realmonitor?channel=1&subtype=0
Remote Method: RTP/RTSP
Options:
Target Colour Space: 32bit colour
Capture Width: 2592
Capture Height: 1520
Everything else default.
I've also tried it with source type: remote
Remote Protocol: RTSP
Remote Host Name: admin:admin@192.168.1.80
Remote Host Port: 554
Remote Host Path: /cam/realmonitor?channel=1&subtype=0
Capture Width: 2592
Any suggestions?
Re: Dahua IPC-HDBW4431R-AS
The ffmpeg source type is what you should be using.
Where did the odd 2592x1520 resolution come from? That resolution was not stated in the wiki you linked.
The value you use has to match what the camera is sending, down to the exact pixel. Use vlc to tell you what the resolution should be.
Also, check how much space you've got in your ramdisk:
df -h /dev/shm
You will need several hundred MB free to support that high of a resolution.
Try the other choices for Remote Method, particularly unicast.
If you are still experiencing issues, then please post a larger portion of your logs. What we really need to see is everything that happens, from the moment you start zoneminder, up until just after errors start appearing.... and don't try to open the live view while you are collecting this data.
reubenwrotethis
Thanks for the reply. I had the resolution from what the camera gave, I changed the camera setting to 1920x1080 (and updated in Zoneminder) but still not much luck.
~$ df -h /dev/shm
Filesystem Size Used Avail Use% Mounted on
none 497M 1.8M 495M 1% /run/shm
Should I allocate some more RAM?
I stopped Zoneminder, cleared the log, then started it again and here is the result, does this have offer any more insight?
Date/Time
Component Server PID Level Message File Line
2016-12-16 17:26:41.697310 zmdc 18362 INF 'zmtelemetry.pl' started at 16/12/16 06:56:41 zmdc.pl
2016-12-16 17:26:41.682890 zmdc 18296 INF 'zmtelemetry.pl' starting at 16/12/16 06:56:41, pid = 18362 zmdc.pl
2016-12-16 17:26:40.928570 zmdc 18296 INF 'zmupdate.pl -c' starting at 16/12/16 06:56:40, pid = 18348 zmdc.pl
2016-12-16 17:26:40.928410 zmdc 18348 INF 'zmupdate.pl -c' started at 16/12/16 06:56:40 zmdc.pl
2016-12-16 17:26:40.920540 zmwatch 18343 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-12-16 17:26:40.919010 zmwatch 18343 INF Watchdog starting zmwatch.pl
2016-12-16 17:26:40.854020 zmdc 18343 INF 'zmwatch.pl' started at 16/12/16 06:56:40 zmdc.pl
2016-12-16 17:26:40.854010 zmdc 18296 INF 'zmwatch.pl' starting at 16/12/16 06:56:40, pid = 18343 zmdc.pl
2016-12-16 17:26:39.268460 zmc_m1 18326 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-12-16 17:26:39.263677 zmc_m1 18326 INF Priming capture from rtsp://admin:admin@192.168.1.80:554/cam/realmonitor?channel=1&subtype=0 zm_ffmpeg_camera.cpp 104
2016-12-16 17:26:39.259087 zmc_m1 18326 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-12-16 17:26:32.918770 zmfilter 18328 INF Scanning for events zmfilter.pl
2016-12-16 17:26:23.856650 zmdc 18334 INF 'zmaudit.pl -c' started at 16/12/16 06:56:23 zmdc.pl
2016-12-16 17:26:23.856430 zmdc 18296 INF 'zmaudit.pl -c' starting at 16/12/16 06:56:23, pid = 18334 zmdc.pl
2016-12-16 17:26:23.782740 zmdc 18328 INF 'zmfilter.pl' started at 16/12/16 06:56:23 zmdc.pl
2016-12-16 17:26:23.782730 zmdc 18296 INF 'zmfilter.pl' starting at 16/12/16 06:56:23, pid = 18328 zmdc.pl
2016-12-16 17:26:23.736240 zmdc 18326 INF 'zmc -m 1' started at 16/12/16 06:56:23 zmdc.pl
2016-12-16 17:26:23.736240 zmdc 18296 INF 'zmc -m 1' starting at 16/12/16 06:56:23, pid = 18326 zmdc.pl
2016-12-16 17:26:23.732970 zmdc 18296 INF Starting pending process, zmc -m 1 zmdc.pl
2016-12-16 17:26:23.730640 zmdc 18296 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-12-16 17:26:23.707250 zmdc 18296 INF 'zmc -m 1' starting at 16/12/16 06:56:23, pid = 18322 zmdc.pl
2016-12-16 17:26:23.707250 zmdc 18322 INF 'zmc -m 1' started at 16/12/16 06:56:23 zmdc.pl
2016-12-16 17:26:23.633060 zmpkg 18274 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-12-16 17:26:20.631050 zmdc 18296 INF Server starting at 16/12/16 06:56:20 zmdc.pl
2016-12-16 17:26:20.490050 zmpkg 18274 INF Command: start zmpkg.pl
2016-12-16 17:26:20.487480 zmpkg 18274 INF Sanity checking States table... zmpkg.pl
2016-12-16 17:26:20.383930 zmsystemctl 18262 INF Redirecting command through systemctl zmsystemctl.pl
2016-12-16 17:26:20.194080 zmpkg 18256 INF Command: start zmpkg.pl
2016-12-16 17:26:20.093950 zmpkg 18256 INF Sanity checking States table... zmpkg.pl
2016-12-16 17:26:05.684250 zmdc 17952 INF Server shutdown at 16/12/16 06:56:05 zmdc.pl
2016-12-16 17:25:55.660120 zmdc 17952 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-12-16 17:25:55.657270 zmdc 17952 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-12-16 17:25:55.655120 zmdc 17952 INF 'zmtelemetry.pl' sending stop to pid 18004 at 16/12/16 06:55:55 zmdc.pl
2016-12-16 17:25:55.652890 zmdc 17952 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-12-16 17:25:55.650590 zmdc 17952 INF 'zmfilter.pl' sending stop to pid 17983 at 16/12/16 06:55:55 zmdc.pl
2016-12-16 17:25:55.648180 zmdc 17952 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-12-16 17:25:55.646030 zmdc 17952 INF 'zmwatch.pl' sending stop to pid 17993 at 16/12/16 06:55:55 zmdc.pl
2016-12-16 17:25:55.643810 zmdc 17952 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-12-16 17:25:55.641490 zmdc 17952 INF 'zmaudit.pl -c' sending stop to pid 17988 at 16/12/16 06:55:55 zmdc.pl
2016-12-16 17:25:55.639170 zmdc 17952 INF 'zmupdate.pl -c' sending stop to pid 17998 at 16/12/16 06:55:55 zmdc.pl
2016-12-16 17:25:55.498140 zmpkg 18198 INF Command: stop zmpkg.pl
2016-12-16 17:25:55.495380 zmpkg 18198 INF Sanity checking States table... zmpkg.pl
2016-12-16 17:25:55.391730 zmsystemctl 18185 INF Redirecting command through systemctl zmsystemctl.pl
2016-12-16 17:25:55.295910 zmpkg 18179 INF Command: stop zmpkg.pl
2016-12-16 17:25:55.286580 zmpkg 18179 INF Sanity checking States table... zmpkg.pl
2016-12-16 17:25:48.518910 zmdc 17952 INF 'zmc -m 1' crashed, signal 8 zmdc.pl
2016-12-16 17:25:48.373450 zmdc 17952 WAR 'zmc -m 1' has not stopped at 16/12/16 06:55:48. Sending KILL to pid 18056 zmdc.pl
2016-12-16 17:25:42.408386 zmc_m1 18056 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-12-16 17:25:42.368010 zmdc 17952 INF 'zmc -m 1' sending stop to pid 18056 at 16/12/16 06:55:42 zmdc.pl
2016-12-16 17:24:57.982010 zmwatch 17993 INF Restarting capture daemon for Front-Entrance, time since last capture 14 seconds (1481871297-1481871283) zmwatch.pl
2016-12-16 17:23:22.243984 zmc_m1 18056 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-12-16 17:23:22.242954 zmc_m1 18056 INF Priming capture from rtsp://admin:admin@192.168.1.80:554/cam/realmonitor?channel=1&subtype=0 zm_ffmpeg_camera.cpp 104
2016-12-16 17:23:22.241768 zmc_m1 18056 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-12-16 17:23:22.091010 zmdc 18056 INF 'zmc -m 1' started at 16/12/16 06:53:22 zmdc.pl
2016-12-16 17:23:22.091000 zmdc 17952 INF 'zmc -m 1' starting at 16/12/16 06:53:22, pid = 18056 zmdc.pl
2016-12-16 17:23:22.080070 zmdc 17952 INF Starting pending process, zmc -m 1 zmdc.pl
2016-12-16 17:23:17.971970 zmdc 17952 INF 'zmc -m 1' crashed, signal 8 zmdc.pl
2016-12-16 17:23:17.807120 zmdc 17952 WAR 'zmc -m 1' has not stopped at 16/12/16 06:53:17. Sending KILL to pid 17981 zmdc.pl
2016-12-16 17:23:11.822309 zmc_m1 17981 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-12-16 17:23:11.507820 zmdc 17952 INF 'zmc -m 1' sending stop to pid 17981 at 16/12/16 06:53:11 zmdc.pl
2016-12-16 17:22:58.185760 zmwatch 17993 INF Restarting capture daemon for Front-Entrance, time since last capture 6 seconds (1481871177-1481871171) zmwatch.pl
2016-12-16 17:22:51.707503 zmc_m1 17981 INF Successfully reopened stream. zm_ffmpeg_camera.cpp 134
2016-12-16 17:22:37.343840 zmc_m1 18036 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-12-16 17:22:36.437510 zmc_m1 17981 ERR Unable to read packet from stream 0: error -541478725 "End of file". zm_ffmpeg_camera.cpp 167
2016-12-16 17:22:36.042510 zmc_m1 17981 INF av_read_frame returned "End of file". Reopening stream. zm_ffmpeg_camera.cpp 163
2016-12-16 17:16:51.997210 zmdc 18004 INF 'zmtelemetry.pl' started at 16/12/16 06:46:51 zmdc.pl
2016-12-16 17:16:51.926690 zmdc 17952 INF 'zmtelemetry.pl' starting at 16/12/16 06:46:51, pid = 18004 zmdc.pl
2016-12-16 17:16:47.939490 zmwatch 17993 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-12-16 17:16:47.936150 zmwatch 17993 INF Watchdog starting zmwatch.pl
2016-12-16 17:16:45.747650 zmdc 17998 INF 'zmupdate.pl -c' started at 16/12/16 06:46:45 zmdc.pl
2016-12-16 17:16:45.678988 zmc_m1 17981 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-12-16 17:16:45.675276 zmc_m1 17981 INF Priming capture from rtsp://admin:admin@192.168.1.80:554/cam/realmonitor?channel=1&subtype=0 zm_ffmpeg_camera.cpp 104
2016-12-16 17:16:45.672537 zmc_m1 17981 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-12-16 17:16:45.585750 zmdc 17952 INF 'zmupdate.pl -c' starting at 16/12/16 06:46:45, pid = 17998 zmdc.pl
2016-12-16 17:16:44.253230 zmfilter 17983 INF Scanning for events zmfilter.pl
2016-12-16 17:16:42.555990 zmdc 17952 INF 'zmwatch.pl' starting at 16/12/16 06:46:41, pid = 17993 zmdc.pl
2016-12-16 17:16:42.284300 zmdc 17993 INF 'zmwatch.pl' started at 16/12/16 06:46:41 zmdc.pl
2016-12-16 17:16:32.754230 zmdc 17988 INF 'zmaudit.pl -c' started at 16/12/16 06:46:32 zmdc.pl
2016-12-16 17:16:32.754140 zmdc 17952 INF 'zmaudit.pl -c' starting at 16/12/16 06:46:32, pid = 17988 zmdc.pl
2016-12-16 17:16:32.679320 zmdc 17983 INF 'zmfilter.pl' started at 16/12/16 06:46:32 zmdc.pl
2016-12-16 17:16:32.679310 zmdc 17952 INF 'zmfilter.pl' starting at 16/12/16 06:46:32, pid = 17983 zmdc.pl
2016-12-16 17:16:32.630340 zmdc 17981 INF 'zmc -m 1' started at 16/12/16 06:46:32 zmdc.pl
2016-12-16 17:16:32.630320 zmdc 17952 INF 'zmc -m 1' starting at 16/12/16 06:46:32, pid = 17981 zmdc.pl
2016-12-16 17:16:32.628150 zmdc 17952 INF Starting pending process, zmc -m 1 zmdc.pl
2016-12-16 17:16:32.626840 zmdc 17952 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-12-16 17:16:32.605730 zmdc 17952 INF 'zmc -m 1' starting at 16/12/16 06:46:32, pid = 17978 zmdc.pl
2016-12-16 17:16:32.605690 zmdc 17978 INF 'zmc -m 1' started at 16/12/16 06:46:32 zmdc.pl
2016-12-16 17:16:32.441310 zmpkg 17930 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-12-16 17:16:29.439310 zmdc 17952 INF Server starting at 16/12/16 06:46:29 zmdc.pl
2016-12-16 17:16:29.300230 zmpkg 17930 INF Command: start zmpkg.pl
2016-12-16 17:16:29.292590 zmpkg 17930 INF Sanity checking States table... zmpkg.pl
2016-12-16 17:16:29.054710 zmdc 17759 INF Server shutdown at 16/12/16 06:46:29 zmdc.pl
2016-12-16 17:16:19.030430 zmdc 17759 INF 'zmc -m 1' exited normally zmdc.pl
2016-12-16 17:16:18.996220 zmdc 17759 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-12-16 17:16:18.993420 zmdc 17759 INF 'zmc -m 1' sending stop to pid 17788 at 16/12/16 06:46:18 zmdc.pl
2016-12-16 17:16:18.990740 zmdc 17759 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-12-16 17:16:18.987100 zmdc 17759 INF 'zmtelemetry.pl' sending stop to pid 17821 at 16/12/16 06:46:18 zmdc.pl
2016-12-16 17:16:18.983370 zmdc 17759 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-12-16 17:16:18.979650 zmdc 17759 INF 'zmwatch.pl' sending stop to pid 17799 at 16/12/16 06:46:18 zmdc.pl
2016-12-16 17:16:18.977900 zmdc 17759 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
Thank you posting your full log. The relevant log entry is this one:
Was this with the RTP/RTSP remote method? If so, try the unicast method instead, and see what changes in your log files.
reubenwrotethis wrote:Thanks for the reply. I had the resolution from what the camera gave, I changed the camera setting to 1920x1080 (and updated in Zoneminder) but still not much luck.
From your statement, I'm not sure you've done this quite right. This can matter. If you mean you got the resolution from the manual, the side of the box, or even the resolution shown in the camera firmware then that is not reliable enough. Open the stream with VLC player, and look at the stream properties to know for certain what the resolution should be. Some cameras advertise a certain resolution, but the actual stream resolution turns out to be different. ZoneMinder won't work unless you get it exactly right.
reubenwrotethis wrote: ~$ df -h /dev/shm
The short answer is yes, increase your memory to at least 2GB ram. That will cause /dev/shm to increase to ~1GB automatically and make your life a lot easier.
The next step will be to turn on debugging options under the logging tab.
Also, regarding the resolution, technically as long as you specify larger than what the camera sends, it should still work. The image will be upscaled though.
reubenwrotethis
Thanks for the help so far, appreciate it. The resolution is correct according to VLC.
Increased my RAM as instructed now:
df -h /dev/shm
tmpfs 16G 396M 16G 3% /dev/shm
I tried BlueIris and got it working in that in 30 seconds! The settings from BlueIris are:
Address: http://192.168.1.80
User/Pass:admin/admin
Make: Generic
Model: RTSP H.264/H.265/MJPG/MPEG4
Media/Video/RTSP Port: 554
Discovery/ONVIF Port: 80
Path: /cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
It also got the 1920x1280 resolution
When I tried in ZoneMinder ONVIF it managed to get the settings this time (maybe I typed the password in wrong before).
FFMPEG
rtsp://admin:admin@192.168.1.80:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
RTP/Multicast
32 bit colour
1920x1280
The latest logs with the ONVIF settings are below. I think I've turned on the more detailed logging, but not 100% sure
Date/Time
2016-12-20 17:32:49.257520 zmdc 3356 INF 'zmc -m 1' started at 16/12/20 07:02:49 zmdc.pl
2016-12-20 17:32:49.231800 zmdc 3276 INF 'zmc -m 1' starting at 16/12/20 07:02:49, pid = 3356 zmdc.pl
2016-12-20 17:32:49.105150 zmwatch 3322 INF Restarting capture daemon for Dahua, shared data not valid zmwatch.pl
2016-12-20 17:32:39.101360 zmdc 3276 INF 'zmc -m 1' exited, signal 14 zmdc.pl
2016-12-20 17:32:38.818530 zmdc 3276 INF 'zmc -m 1' sending stop to pid 3350 at 16/12/20 07:02:38 zmdc.pl
2016-12-20 17:32:30.525340 zmwatch 3322 INF Restarting capture daemon for Dahua, shared data not valid zmwatch.pl
2016-12-20 17:32:30.046880 zmdc 3350 INF 'zmc -m 1' started at 16/12/20 07:02:30 zmdc.pl
2016-12-20 17:32:30.046880 zmdc 3276 INF 'zmc -m 1' starting at 16/12/20 07:02:30, pid = 3350 zmdc.pl
2016-12-20 17:32:30.035570 zmdc 3276 INF Starting pending process, zmc -m 1 zmdc.pl
2016-12-20 17:32:20.463410 zmdc 3276 INF 'zmc -m 1' exited, signal 14 zmdc.pl
2016-12-20 17:32:20.110460 zmdc 3276 INF 'zmc -m 1' sending stop to pid 3332 at 16/12/20 07:02:20 zmdc.pl
2016-12-20 17:32:09.457670 zmwatch 3322 INF Restarting capture daemon for Dahua, shared data not valid zmwatch.pl
2016-12-20 17:31:43.232060 zmdc 3276 INF 'zmtelemetry.pl' starting at 16/12/20 07:01:43, pid = 3335 zmdc.pl
2016-12-20 17:31:43.212760 zmdc 3335 INF 'zmtelemetry.pl' started at 16/12/20 07:01:43 zmdc.pl
2016-12-20 17:31:41.963770 zmdc 3276 INF 'zmc -m 1' starting at 16/12/20 07:01:41, pid = 3332 zmdc.pl
2016-12-20 17:31:41.915990 zmdc 3332 INF 'zmc -m 1' started at 16/12/20 07:01:41 zmdc.pl
2016-12-20 17:31:41.086640 zmdc 3276 INF Starting pending process, zmc -m 1 zmdc.pl
2016-12-20 17:31:38.962570 zmwatch 3322 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-12-20 17:31:38.960000 zmwatch 3322 INF Watchdog starting zmwatch.pl
2016-12-20 17:31:38.477770 zmdc 3327 INF 'zmupdate.pl -c' started at 16/12/20 07:01:38 zmdc.pl
2016-12-20 17:31:38.434310 zmdc 3276 INF 'zmupdate.pl -c' starting at 16/12/20 07:01:38, pid = 3327 zmdc.pl
2016-12-20 17:31:36.960140 zmdc 3276 ERR 'zmc -m 1' exited abnormally, exit status 11 zmdc.pl
2016-12-20 17:31:36.611842 zmc_m1 3306 INF addr2line -e /usr/bin/zmc 0x55fb3e2c1608 0x7f6eb61903d0 0x7f6eb5067c54 0x7f6eb51491b3 0x7f6eb50674d8 0x7f6eb506766b 0x7f6eb51504c8 0x7f6eb5150e56 0x7f6eb5153350 0x7f6eb517eba7 0x55fb3e305da9 0x55fb3e308b62 0x55fb3e25d6d6 0x7f6eb2882830 0x55fb3e25e749 zm_signal.cpp 110
2016-12-20 17:31:36.607631 zmc_m1 3306 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 109
2016-12-20 17:31:36.604606 zmc_m1 3306 ERR Backtrace 14: /usr/bin/zmc(_start+0x29) [0x55fb3e25e749] zm_signal.cpp 102
2016-12-20 17:31:36.601558 zmc_m1 3306 ERR Backtrace 13: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7f6eb2882830] zm_signal.cpp 102
2016-12-20 17:31:36.598010 zmc_m1 3306 ERR Backtrace 12: /usr/bin/zmc(main+0x406) [0x55fb3e25d6d6] zm_signal.cpp 102
2016-12-20 17:31:36.594015 zmc_m1 3306 ERR Backtrace 11: /usr/bin/zmc(_ZN12FfmpegCamera12PrimeCaptureEv+0x82) [0x55fb3e308b62] zm_signal.cpp 102
2016-12-20 17:31:36.591694 zmc_m1 3306 ERR Backtrace 10: /usr/bin/zmc(_ZN12FfmpegCamera10OpenFfmpegEv+0x569) [0x55fb3e305da9] zm_signal.cpp 102
2016-12-20 17:31:36.585767 zmc_m1 3306 ERR Backtrace 9: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(avformat_open_input+0x1f7) [0x7f6eb517eba7] zm_signal.cpp 102
2016-12-20 17:31:36.579910 zmc_m1 3306 ERR Backtrace 8: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x13d350) [0x7f6eb5153350] zm_signal.cpp 102
2016-12-20 17:31:36.577638 zmc_m1 3306 ERR Backtrace 7: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x13ae56) [0x7f6eb5150e56] zm_signal.cpp 102
2016-12-20 17:31:36.575145 zmc_m1 3306 ERR Backtrace 6: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x13a4c8) [0x7f6eb51504c8] zm_signal.cpp 102
2016-12-20 17:31:36.570605 zmc_m1 3306 ERR Backtrace 5: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(ffurl_open+0x6b) [0x7f6eb506766b] zm_signal.cpp 102
2016-12-20 17:31:36.566448 zmc_m1 3306 ERR Backtrace 4: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x514d8) [0x7f6eb50674d8] zm_signal.cpp 102
2016-12-20 17:31:36.562054 zmc_m1 3306 ERR Backtrace 3: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x1331b3) [0x7f6eb51491b3] zm_signal.cpp 102
2016-12-20 17:31:36.557660 zmc_m1 3306 ERR Backtrace 2: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x51c54) [0x7f6eb5067c54] zm_signal.cpp 102
2016-12-20 17:31:36.518275 zmc_m1 3306 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x113d0) [0x7f6eb61903d0] zm_signal.cpp 102
2016-12-20 17:31:36.510219 zmc_m1 3306 ERR Backtrace 0: /usr/bin/zmc(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x55fb3e2c1608] zm_signal.cpp 102
2016-12-20 17:31:36.471335 zmc_m1 3306 ERR Signal address is 0x8, from 0x7f6eb5067c54 zm_signal.cpp 81
2016-12-20 17:31:36.442507 zmc_m1 3306 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 50
2016-12-20 17:31:36.400780 zmdc 3276 INF 'zmwatch.pl' starting at 16/12/20 07:01:36, pid = 3322 zmdc.pl
2016-12-20 17:31:36.273070 zmdc 3322 INF 'zmwatch.pl' started at 16/12/20 07:01:36 zmdc.pl
2016-12-20 17:31:35.966476 zmc_m1 3306 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-12-20 17:31:35.964970 zmc_m1 3306 INF Priming capture from rtsp://admin:admin@192.168.1.80:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif zm_ffmpeg_camera.cpp 104
2016-12-20 17:31:35.963105 zmc_m1 3306 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-12-20 17:31:32.623850 zmfilter 3309 INF Scanning for events zmfilter.pl
2016-12-20 17:31:27.812190 zmdc 3276 INF 'zmaudit.pl -c' starting at 16/12/20 07:01:27, pid = 3314 zmdc.pl
2016-12-20 17:31:27.804670 zmdc 3314 INF 'zmaudit.pl -c' started at 16/12/20 07:01:27 zmdc.pl
2016-12-20 17:31:27.480410 zmdc 3309 INF 'zmfilter.pl' started at 16/12/20 07:01:27 zmdc.pl
2016-12-20 17:31:27.480400 zmdc 3276 INF 'zmfilter.pl' starting at 16/12/20 07:01:27, pid = 3309 zmdc.pl
2016-12-20 17:31:27.426720 zmdc 3306 INF 'zmc -m 1' started at 16/12/20 07:01:27 zmdc.pl
2016-12-20 17:31:27.426720 zmdc 3276 INF 'zmc -m 1' starting at 16/12/20 07:01:27, pid = 3306 zmdc.pl
2016-12-20 17:31:27.424250 zmdc 3276 INF Starting pending process, zmc -m 1 zmdc.pl
2016-12-20 17:31:27.422890 zmdc 3276 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-12-20 17:31:27.403680 zmdc 3302 INF 'zmc -m 1' started at 16/12/20 07:01:27 zmdc.pl
2016-12-20 17:31:27.403680 zmdc 3276 INF 'zmc -m 1' starting at 16/12/20 07:01:27, pid = 3302 zmdc.pl
2016-12-20 17:31:27.328990 zmpkg 3254 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-12-20 17:31:24.326770 zmdc 3276 INF Server starting at 16/12/20 07:01:24 zmdc.pl
2016-12-20 17:31:24.186170 zmpkg 3254 INF Command: start zmpkg.pl
2016-12-20 17:31:24.184350 zmpkg 3254 INF Sanity checking States table... zmpkg.pl
2016-12-20 17:31:24.087930 zmsystemctl 3242 INF Redirecting command through systemctl zmsystemctl.pl
2016-12-20 17:31:23.981970 zmpkg 3236 INF Command: start zmpkg.pl
2016-12-20 17:31:23.973200 zmpkg 3236 INF Sanity checking States table... zmpkg.pl
2016-12-20 17:31:03.749230 zmdc 930 INF Server shutdown at 16/12/20 07:01:03 zmdc.pl
2016-12-20 17:30:53.726270 zmdc 930 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-12-20 17:30:53.724780 zmdc 930 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-12-20 17:30:53.723670 zmdc 930 INF 'zmaudit.pl -c' sending stop to pid 966 at 16/12/20 07:00:53 zmdc.pl
2016-12-20 17:30:53.722380 zmdc 930 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-12-20 17:30:53.721180 zmdc 930 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-12-20 17:30:53.719040 zmdc 930 INF 'zmtelemetry.pl' sending stop to pid 984 at 16/12/20 07:00:53 zmdc.pl
2016-12-20 17:30:53.716880 zmdc 930 INF 'zmupdate.pl -c' sending stop to pid 978 at 16/12/20 07:00:53 zmdc.pl
2016-12-20 17:30:53.714670 zmdc 930 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-12-20 17:30:53.712430 zmdc 930 INF 'zmwatch.pl' sending stop to pid 972 at 16/12/20 07:00:53 zmdc.pl
2016-12-20 17:30:53.709930 zmdc 930 INF 'zmfilter.pl' sending stop to pid 961 at 16/12/20 07:00:53 zmdc.pl
2016-12-20 17:30:52.562640 zmpkg 3173 INF Command: stop zmpkg.pl
2016-12-20 17:30:52.559760 zmpkg 3173 INF Sanity checking States table... zmpkg.pl
2016-12-20 17:30:52.464810 zmsystemctl 3101 INF Redirecting command through systemctl zmsystemctl.pl
2016-12-20 17:30:52.314830 zmpkg 3095 INF Command: stop zmpkg.pl
2016-12-20 17:30:52.312040 zmpkg 3095 INF Sanity checking States table... zmpkg.pl
2016-12-20 17:28:51.886880 zmdc 930 ERR 'zmc -m 1' exited abnormally, exit status 11 zmdc.pl
2016-12-20 17:28:51.875620 zmc_m1 3085 INF addr2line -e /usr/bin/zmc 0x5559bfec0608 0x7fa5554fe3d0 0x7fa5543d5c54 0x7fa5544b71b3 0x7fa5543d54d8 0x7fa5543d566b 0x7fa5544be4c8 0x7fa5544bee56 0x7fa5544c1350 0x7fa5544ecba7 0x5559bff04da9 0x5559bff07b62 0x5559bfe5c6d6 0x7fa551bf0830 0x5559bfe5d749 zm_signal.cpp 110
2016-12-20 17:28:51.873521 zmc_m1 3085 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 109
2016-12-20 17:28:51.871343 zmc_m1 3085 ERR Backtrace 14: /usr/bin/zmc(_start+0x29) [0x5559bfe5d749] zm_signal.cpp 102
2016-12-20 17:28:51.869239 zmc_m1 3085 ERR Backtrace 13: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fa551bf0830] zm_signal.cpp 102
2016-12-20 17:28:51.867133 zmc_m1 3085 ERR Backtrace 12: /usr/bin/zmc(main+0x406) [0x5559bfe5c6d6] zm_signal.cpp 102
2016-12-20 17:28:51.864985 zmc_m1 3085 ERR Backtrace 11: /usr/bin/zmc(_ZN12FfmpegCamera12PrimeCaptureEv+0x82) [0x5559bff07b62] zm_signal.cpp 102
2016-12-20 17:28:51.862763 zmc_m1 3085 ERR Backtrace 10: /usr/bin/zmc(_ZN12FfmpegCamera10OpenFfmpegEv+0x569) [0x5559bff04da9] zm_signal.cpp 102
2016-12-20 17:28:51.860533 zmc_m1 3085 ERR Backtrace 9: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(avformat_open_input+0x1f7) [0x7fa5544ecba7] zm_signal.cpp 102
2016-12-20 17:28:51.858251 zmc_m1 3085 ERR Backtrace 8: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x13d350) [0x7fa5544c1350] zm_signal.cpp 102
2016-12-20 17:28:51.855956 zmc_m1 3085 ERR Backtrace 7: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x13ae56) [0x7fa5544bee56] zm_signal.cpp 102
2016-12-20 17:28:51.853716 zmc_m1 3085 ERR Backtrace 6: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x13a4c8) [0x7fa5544be4c8] zm_signal.cpp 102
2016-12-20 17:28:51.851546 zmc_m1 3085 ERR Backtrace 5: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(ffurl_open+0x6b) [0x7fa5543d566b] zm_signal.cpp 102
2016-12-20 17:28:51.849396 zmc_m1 3085 ERR Backtrace 4: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x514d8) [0x7fa5543d54d8] zm_signal.cpp 102
2016-12-20 17:28:51.847130 zmc_m1 3085 ERR Backtrace 3: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x1331b3) [0x7fa5544b71b3] zm_signal.cpp 102
2016-12-20 17:28:51.844923 zmc_m1 3085 ERR Backtrace 2: /usr/lib/x86_64-linux-gnu/libavformat-ffmpeg.so.56(+0x51c54) [0x7fa5543d5c54] zm_signal.cpp 102
2016-12-20 17:28:51.842636 zmc_m1 3085 ERR Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x113d0) [0x7fa5554fe3d0] zm_signal.cpp 102
2016-12-20 17:28:51.840340 zmc_m1 3085 ERR Backtrace 0: /usr/bin/zmc(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5559bfec0608] zm_signal.cpp 102
2016-12-20 17:28:51.837916 zmc_m1 3085 ERR Signal address is 0x8, from 0x7fa5543d5c54 zm_signal.cpp 81
2016-12-20 17:28:51.826901 zmc_m1 3085 ERR Got signal 11 (Segmentation fault), crashing zm_signal.cpp 50
2016-12-20 17:28:51.568128 zmc_m1 3085 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-12-20 17:28:51.565949 zmc_m1 3085 INF Priming capture from rtsp://admin:admin@192.168.1.80:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif zm_ffmpeg_camera.cpp 104
2016-12-20 17:28:51.471001 zmc_m1 3085 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-12-20 17:28:51.169170 zmdc 3085 INF 'zmc -m 1' started at 16/12/20 06:58:51 zmdc.pl
2016-12-20 17:28:51.169170 zmdc 930 INF 'zmc -m 1' starting at 16/12/20 06:58:51, pid = 3085 zmdc.pl
2016-12-20 17:28:51.072430 zmdc 930 INF Starting pending process, zmc -m 1 zmdc.pl
2016-12-20 17:26:19.720911 web_php 3016 ERR socket_sendto( /var/run/zm/zms-774651s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-12-20 17:18:51.596620 zmdc 930 ERR 'zmc -m 1' exited abnormally, exit status 11 zmdc.pl
2016-12-20 17:18:51.585455 zmc_m1 3052 INF addr2line -e /usr/bin/zmc 0x561454307608 0x7fe307cab3d0 0x7fe306b82c54 0x7fe306c641b3 0x7fe306b824d8 0x7fe306b8266b 0x7fe306c6b4c8 0x7fe306c6be56 0x7fe306c6e350 0x7fe306c99ba7 0x56145434bda9 0x56145434eb62 0x5614542a36d6 0x7fe30439d830 0x5614542a4749 zm_signal.cpp 110
2016-12-20 17:18:51.583203 zmc_m1 3052 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 109
2016-12-20 17:18:51.580993 zmc_m1 3052 ERR Backtrace 14: /usr/bin/zmc(_start+0x29) [0x5614542a4749] zm_signal.cpp 102
2016-12-20 17:18:51.578843 zmc_m1 3052 ERR Backtrace 13: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0) [0x7fe30439d830] zm_signal.cpp 102
alex_peri
Post by alex_peri »
Hi reubenwrotethis,
Did you get any luck with this in ZM?
Does the PTZ work in ZM?
Best
bobylapointe69300
Post by bobylapointe69300 »
alex_peri wrote: Mon Jan 08, 2018 10:04 pm Hi reubenwrotethis,
Best
I posted a PTZ control file here: viewtopic.php?f=9&t=27000 but IPC-HDBW4431R-AS has no PTZ feature.
0x7265646265617264
Post by 0x7265646265617264 »
Related to this, I just did an overhaul on the Dahua wiki page (https://wiki.zoneminder.com/Dahua) as well as creating a redirect from "Alhua" and a few other tweaks. As of now, there's also a dedicated section to the non-audio variant of this device: https://wiki.zoneminder.com/Dahua#IPC-HDBW4431R-ZS
