SOLVED: API/cake issues: Error: ZoneminderController could not be found.
Posted: Fri Dec 02, 2016 12:27 am
Hello I'm using the zoneminder package from Arch Linux AUR. v1.30
Everything else appears to be working however when trying to get the api working upon going to the "http://mylocaliphere/zoneminder/api/" url I get the following:
I'm guessing maybe this is related to a alias issue? Here is what I have:
As said everything else seems to be working. I have three IP cameras which can stream, record, and detect motion perfectly. I just cannot work with the API. Of note I did upgrade from v.1.29 recently however I did not use the api before so I have no idea if it worked with the current config then either.
Thank you.
Any help or hints?"Missing Controller
Error: Create the class ZoneminderController below in file: app/Controller/ZoneminderController.php"
# /etc/httpd/conf/extra/httpd-zoneminder.conf
# Config for zoneminder web app
Alias /zm "/srv/http/zoneminder"
<Directory "/srv/http/zoneminder">
Options -Indexes +MultiViews +FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
# Provide PHP directory and file access, see http://php.net/manual/en/ini.core.php#ini.open-basedir
php_admin_value open_basedir "/tmp/:/etc/zm.conf:/srv/http/zoneminder/:/var/cache/zoneminder/:/var/lib/zoneminder/:/var/log/zoneminder/"
</Directory>
ScriptAlias /cgi-bin "/srv/http/cgi-bin"
<Directory "/srv/http/cgi-bin">
AllowOverride None
Options +ExecCGI +FollowSymLinks
Order allow,deny
Allow from all
</Directory>
<Directory /srv/http/zoneminder/api>
AllowOverride All
</Directory>
Thank you.
