I installed ZM version 1.30 on Ubuntu 14.04, seems to be working OK. I added 3 cameras, but see nothing when I click on them. Also all events are "o". I tried "monitor" and "modect" modes.
When I click "Log", I see though a lot of events like these:
camera1: 13000 - Analysing at 15.87 fps zm_monitor.cpp 1287
camera2: 13000 - Analysing at 15.87 fps zm_monitor.cpp 1287
camera3: 8000 - Analysing at 10.00 fps zm_monitor.cpp 1287
camera1: 50000 - Capturing at 15.87 fps zm_monitor.cpp 3116
etc...
So, can't figure out, what is wrong here...
see nothing in Zoneminder
Re: see nothing in Zoneminder
Whan you click on the camera name (far left), do you see an image?
I had same problem but in 16.04. Under config-->Paths-->PATH_ZMS I had to change the value to /zm/cgi-bin/nph-zms. Give it a try.
Thank you for replies, yes, setting PATH_ZMS really helps, there are pictures and events now!
