The stream never shows in ZM. It does appear to be connecting to the camera per the logs, and when I set to record and checked the events folder, there are images there showing what the camera sees.
I originally thought my path_zms may have been the issue, but that does not appear to be the case as the readme for centos6 does not mention the need to change the path_zms.
Any ideas what I could have done wrong here? Thanks in advance!! Close to pulling my hair out. I hate breaking down and making a forum post but I just can't figure this out.
[root@johnston-server ~]# tail -f /var/log/messages
Oct 22 12:30:41 johnston-server zmpkg[15525]: INF [Single server configuration detected. Starting up services.]
Oct 22 12:30:42 johnston-server zmdc[15541]: INF ['zmc -m 5' starting at 16/10/22 12:30:42, pid = 15570]
Oct 22 12:30:42 johnston-server zmdc[15570]: INF ['zmc -m 5' started at 16/10/22 12:30:42]
Oct 22 12:30:42 johnston-server zmdc[15541]: ERR ['zmc -m 5' exited abnormally, exit status 255]
Oct 22 12:30:42 johnston-server zmdc[15541]: INF [Starting pending process, zmc -m 5]
Oct 22 12:30:42 johnston-server zmdc[15541]: INF ['zmc -m 5' starting at 16/10/22 12:30:42, pid = 15576]
Oct 22 12:30:42 johnston-server zmdc[15576]: INF ['zmc -m 5' started at 16/10/22 12:30:42]
Oct 22 12:30:42 johnston-server zmc_m5[15576]: INF [Starting Capture version 1.30.0]
Oct 22 12:30:42 johnston-server zmc_m5[15576]: INF [Priming capture from rtsp://192.168.1.225:554/12]
Oct 22 12:30:42 johnston-server zmc_m5[15576]: WAR [Unable to parse ffmpeg option 0 '', expecting key=value]
Oct 22 12:31:49 johnston-server zmc_m5[15576]: INF [Front Door: 1000 - Capturing at 14.93 fps]
Oct 22 12:32:56 johnston-server zmc_m5[15576]: INF [Front Door: 2000 - Capturing at 14.93 fps]
Oct 22 12:34:02 johnston-server zmc_m5[15576]: INF [Front Door: 3000 - Capturing at 15.15 fps]
Oct 22 12:35:09 johnston-server zmc_m5[15576]: INF [Front Door: 4000 - Capturing at 14.93 fps]
Oct 22 12:36:16 johnston-server zmc_m5[15576]: INF [Front Door: 5000 - Capturing at 14.93 fps]
Oct 22 12:37:23 johnston-server zmc_m5[15576]: INF [Front Door: 6000 - Capturing at 14.93 fps]
Oct 22 12:38:30 johnston-server zmc_m5[15576]: INF [Front Door: 7000 - Capturing at 14.93 fps]
Oct 22 12:38:55 johnston-server zms[15766]: ERR [Unable to authenticate user]
Oct 22 12:38:55 johnston-server zms[15769]: ERR [Unable to authenticate user]
Oct 22 12:38:55 johnston-server zms[15772]: ERR [Unable to authenticate user]
Oct 22 12:39:00 johnston-server zms[15775]: ERR [Unable to authenticate user]
Oct 22 12:39:01 johnston-server zms[15778]: ERR [Unable to authenticate user]
Oct 22 12:39:36 johnston-server zmc_m5[15576]: INF [Front Door: 8000 - Capturing at 15.15 fps]
Oct 22 12:40:43 johnston-server zmc_m5[15576]: INF [Front Door: 9000 - Capturing at 14.93 fps]
Oct 22 12:41:50 johnston-server zmc_m5[15576]: INF [Front Door: 10000 - Capturing at 14.93 fps]
Oct 22 12:42:57 johnston-server zmc_m5[15576]: INF [Front Door: 11000 - Capturing at 14.93 fps]
Oct 22 12:44:03 johnston-server zmc_m5[15576]: INF [Front Door: 12000 - Capturing at 15.15 fps]
Oct 22 12:45:10 johnston-server zmc_m5[15576]: INF [Front Door: 13000 - Capturing at 14.93 fps]
Oct 22 12:46:17 johnston-server zmc_m5[15576]: INF [Front Door: 14000 - Capturing at 14.93 fps]
Oct 22 12:46:23 johnston-server zms[16041]: ERR [Unable to authenticate user]
Oct 22 12:46:23 johnston-server zms[16044]: ERR [Unable to authenticate user]
Oct 22 12:46:28 johnston-server web_php[5313]: ERR [socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory]
Oct 22 12:46:28 johnston-server web_php[5313]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory - checkStreamForErrors()]
Oct 22 12:46:28 johnston-server zms[16049]: ERR [Unable to authenticate user]
Oct 22 12:46:35 johnston-server web_php[5313]: ERR [socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory]
Oct 22 12:46:35 johnston-server web_php[5313]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory - checkStreamForErrors()]
Oct 22 12:46:35 johnston-server zms[16055]: ERR [Unable to authenticate user]
Oct 22 12:46:42 johnston-server web_php[5313]: ERR [socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory]
Oct 22 12:46:42 johnston-server web_php[5313]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory - checkStreamForErrors()]
Oct 22 12:46:42 johnston-server zms[16061]: ERR [Unable to authenticate user]
Oct 22 12:46:49 johnston-server web_php[5313]: ERR [socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory]
Oct 22 12:46:49 johnston-server web_php[5313]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory - checkStreamForErrors()]
Oct 22 12:46:49 johnston-server zms[16067]: ERR [Unable to authenticate user]
Oct 22 12:46:56 johnston-server web_php[5313]: ERR [socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory]
Oct 22 12:46:56 johnston-server web_php[5313]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory - checkStreamForErrors()]
Oct 22 12:46:56 johnston-server zms[16072]: ERR [Unable to authenticate user]
Oct 22 12:47:03 johnston-server web_php[5313]: ERR [socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory]
Oct 22 12:47:03 johnston-server web_php[5313]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/lib/zoneminder/sock/zms-764665s.sock ) failed: No such file or directory - checkStreamForErrors()]
Oct 22 12:47:03 johnston-server zms[16077]: ERR [Unable to authenticate user]
Oct 22 12:47:24 johnston-server zmc_m5[15576]: INF [Front Door: 15000 - Capturing at 14.93 fps]
Oct 22 12:48:30 johnston-server zmc_m5[15576]: INF [Front Door: 16000 - Capturing at 15.15 fps]
