CIPCAM1080OD no Picture ..
Brick
Post by Brick » Fri Sep 23, 2016 9:05 am
System:
Ubuntu 15.10 64 Bit
ZoneMinder 1.30.
CIPCAM1080OD
Settings:
Source: Remote
Function: Monitor
Acitve: yes
Analysis fps: 10
max fps: 20
alarm fps: 20
Protocol: RTSP
Method: RTP/RTSP
Hostname: visu:visu@192.168.178.49
Port: 554
Hostpath: /live/ch1
tried also:
Source: Ffmpeg
Path: rtsp://visu:visu@192.168.178.49:80/live/ch1
Method: RTP/RTSP
didn't match...
can't see any Picture.
Here is some log:
2016-09-23 11:04:28.486923 web_php 2383 ERR socket_sendto( /var/run/zm/zms-363087s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-09-23 11:04:05.886409 zmc_m1 2684 INF Hof: 1000 - Capturing at 24.39 fps zm_monitor.cpp 3116
2016-09-23 11:04:04.810129 web_php 2650 ERR socket_sendto( /var/run/zm/zms-881697s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-09-23 11:03:24.216420 zmdc 1080 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2016-09-23 11:03:24.091492 zmc_m1 2684 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-09-23 11:03:24.090150 zmc_m1 2684 INF Priming capture from rtsp://visu:visu@192.168.178.49:80/live/ch1 zm_ffmpeg_camera.cpp 104
2016-09-23 11:03:24.085685 zmc_m1 2684 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-09-23 11:03:23.981170 zmdc 1080 INF 'zmc -m 1' starting at 16/09/23 11:03:23, pid = 2684 zmdc.pl
2016-09-23 11:03:23.979780 zmdc 2684 INF 'zmc -m 1' started at 16/09/23 11:03:23 zmdc.pl
2016-09-23 11:03:23.789380 zmdc 1080 INF 'zmc -m 1' crashed, signal 8 zmdc.pl
2016-09-23 11:03:23.784650 zmdc 1080 WAR 'zmc -m 1' has not stopped at 16/09/23 11:03:23. Sending KILL to pid 2668 zmdc.pl
2016-09-23 11:03:17.783079 zmc_m1 2668 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-09-23 11:03:17.780620 zmdc 1080 INF 'zmc -m 1' sending stop to pid 2668 at 16/09/23 11:03:17 zmdc.pl
2016-09-23 11:03:17.579820 zmdc 1080 WAR Can't find process with command of 'zma -m 1' zmdc.pl
does anybody has a hint, whats the Problem could be ?
Cheers Martin
Re: CIPCAM1080OD no Picture ..
Post by knight-of-ni » Fri Sep 23, 2016 11:48 am
Following the installation documentation avoids this issue.
See my reply here:
viewtopic.php?f=36&t=25308
You should also read the help text for the max fps & alarm fps fields. The values you have entered are invalid.
Brick
Post by Brick » Fri Sep 23, 2016 2:00 pm
@knnniggett
thanks a lot... the hint with the path_zms was the correct one. Didn't find that in the "how to"
i used for my installation.
Cheers Martin
Post by knight-of-ni » Fri Sep 23, 2016 8:44 pm
This exact issue is reported in the forums at least once a week. We know it well.
All Ubuntu users should follow the appropriate easy-way instructions found in the wiki.
In your case, here are the installation instructions which should be followed:
Scroll to the bottom and you will see the step stating to set your PATH_ZMS, complete with a warning in bold stating your video will not work if you don't set this.
