zoneminder service start error
Posted: Wed Aug 31, 2016 2:45 am
hello,
starting service from the the web interface and getting this error. not sure what conditions this zm directory would get deleted. but it has several times. reboot? so this error shows up until i manually start service once.
when starting from web interface there is an issue accessing the /var/run/zm directory as it is not there.
the zoneminder service script start function creates this /var/run/zm directory with appropriate permissions.
to repeat error:
stop zoneminder
delete the /var/run/zm
start zm from the web interface
view the error in log
this install is on ubuntu 14 using the distro from the installation instructions https://zoneminder.readthedocs.io/en/st ... buntu-14-x
2016-08-30 19:38:37.857940 zmpkg 9019 FAT Can't create missing temporary directory '/var/run/zm': Permission denied zmpkg.pl
2016-08-30 19:38:37.750840 zmpkg 9019 INF Command: start zmpkg.pl
2016-08-30 19:38:37.747310 zmpkg 9019 INF Sanity checking States table... zmpkg.pl
2016-08-30 19:38:09.253890 zmdc 8776 INF Server shutdown at 16/08/30 19:38:09 zmdc.pl
sudo service zoneminder start
stop zoneminder
