Except it's working fine here. I can enter the parameters, exactly as you've shown them, into a new monitor without any issue.
So before you scream "omg bug", let's get some real data, rather than make general statements this or that isn't working.
Start by providing screenshots of your monitor config. If it isn't accepting a particular configuration then show us a screen shot of that.
Show us the contents of your zoneminder log. We need to see the entire, unedited log contents, from the moment you start zoneminder up until you see errors appear or you see "Capturing at XXX" messages. Do NOT try to open the monitor during this test.
Assemble the full stream url by hand (e.g.
http://user:pass@192.168.1.6/video.cgi), paste it into Firefox, and verify you indeed get a stream. Once you get a stream in your browser, verify the resolution is 640x480 as it has to match, exactly, what you enter into ZoneMinder.
Also, please confirm exactly what make and model camera you have. The title says DCS2050L, but you mention DCS5020L in the body of you message.
Let's talk about the PTZ control after the video works. If the script was indeed written for zoneminder 1.25, it needs to be modified to work with the latest ZoneMinder.
Ok first thanks for replying I appreciate the support! Love the product! Using your comments will address each in turn a step at a time. Comments in line below.
1) Start by providing screenshots of your monitor config.
My camera is a:
D-Link-
DCS5020L:
General Tab:
- GeneralTab.png (41.76 KiB) Viewed 5891 times
Source Tab:
- SourcreTab.png (34.32 KiB) Viewed 5891 times
Here is the error I get when I save the configuration:
- zm-dcs5020L.png (6.58 KiB) Viewed 5891 times
I'm forced to remove the “admin:test123@" before saving. So I had to save just "192.168.1.6” without giving me the above error. As a result I'm gettting "Failed authentication" on the error logs
OMG its working I'm able to save it right now. While preparing these screenshots I was able to save the configuration. So now that I’m totally embarrassed here with egg on my face I of course now have images.
Computers will infuriate, and invariably, without regard discriminate, embarrass, and in general make a lier and ass out of you. Knniggett there is no explaining it except that, you of course you said, "it was working for you”, and now in putting this all together saving the screen shoots I was in fact able to save the configuration with the “admin:test123@192.168.1.6" value for Remote Host Name, and wallah - It worked I started getting images. But I’m glad I did in fact previously save the error I was getting to prove that I was getting this error. I do not know why I was suddenly able to save it. Before I tried it numerous times except to get the error. I know you are thinking the error is between the screen and the back of my seat, but I swearer it was not working.. why write this post in the first place?
Here is the ZM log it shows the errors up to saving the monitor configurations, and capture thereafter,
System Log
Updated: Fri 12th Aug, 2:45pm State: alarm Total: 1064701 Available: 1064701 Displaying: 200
Filter log - Component
Server PID Level File Line
Date/Time
Component Server PID Level Message File Line
2016-08-12 14:44:53.004741 zmc_m3 32467 INF Camera-FI9831P-3M3: 46000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:44:52.122271 zma_m1 7244 INF Camera-FI9805P-1M1: 444000 - Analysing at 9.26 fps zm_monitor.cpp 1287
2016-08-12 14:44:51.617865 zma_m3 7280 INF Camera-FI9831P-3M3: 1456000 - Analysing at 25.00 fps zm_monitor.cpp 1287
2016-08-12 14:44:32.201297 zma_m6 472 INF Camera-DCS5020L-5M6: 9000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:44:32.103280 zmc_m6 468 INF Camera-DCS5020L-5M6: 9000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:44:30.769449 zmc_m1 32476 INF Camera-FI9805P-1M1: 17000 - Capturing at 9.71 fps zm_monitor.cpp 3116
2016-08-12 14:44:20.035757 zmc_m5 19321 INF Camera-FI9821W-4M5: 442000 - Capturing at 8.26 fps zm_monitor.cpp 3116
2016-08-12 14:44:19.908100 zmc_m3 32467 INF Camera-FI9831P-3M3: 45000 - Capturing at 28.57 fps zm_monitor.cpp 3116
2016-08-12 14:44:11.221605 zma_m3 7280 INF Camera-FI9831P-3M3: 1455000 - Analysing at 25.00 fps zm_monitor.cpp 1287
2016-08-12 14:44:08.399738 zma_m2 7258 INF Camera-FI9805P-2M2: 478000 - Analysing at 9.80 fps zm_monitor.cpp 1287
2016-08-12 14:44:03.784242 zmc_m2 32463 INF Camera-FI9805P-2M2: 17000 - Capturing at 9.90 fps zm_monitor.cpp 3116
2016-08-12 14:43:58.929215 zma_m6 472 INF Camera-DCS5020L-5M6: 8000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:43:58.834611 zmc_m6 468 INF Camera-DCS5020L-5M6: 8000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:43:44.428293 zmc_m3 32467 INF Camera-FI9831P-3M3: 44000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:43:31.068737 zma_m3 7280 INF Camera-FI9831P-3M3: 1454000 - Analysing at 28.57 fps zm_monitor.cpp 1287
2016-08-12 14:43:25.673045 zma_m6 472 INF Camera-DCS5020L-5M6: 7000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:43:25.575617 zmc_m6 468 INF Camera-DCS5020L-5M6: 7000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:43:17.705106 zma_m5 7692 INF Camera-FI9821W-4M5: 1073000 - Analysing at 8.33 fps zm_monitor.cpp 1287
2016-08-12 14:43:11.128311 zmc_m3 32467 INF Camera-FI9831P-3M3: 43000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:43:04.433780 zma_m1 7244 INF Camera-FI9805P-1M1: 443000 - Analysing at 9.43 fps zm_monitor.cpp 1287
2016-08-12 14:42:56.802282 zma_m3 7280 INF Camera-FI9831P-3M3: 1453000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:42:52.406557 zma_m6 472 INF Camera-DCS5020L-5M6: 6000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:42:52.319134 zmc_m6 468 INF Camera-DCS5020L-5M6: 6000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:42:47.447973 zmc_m1 32476 INF Camera-FI9805P-1M1: 16000 - Capturing at 10.00 fps zm_monitor.cpp 3116
2016-08-12 14:42:37.982437 zmc_m3 32467 INF Camera-FI9831P-3M3: 42000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:42:26.385545 zma_m2 7258 INF Camera-FI9805P-2M2: 477000 - Analysing at 10.00 fps zm_monitor.cpp 1287
2016-08-12 14:42:25.625463 zms 484 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:42:22.767869 zmc_m2 32463 INF Camera-FI9805P-2M2: 16000 - Capturing at 10.10 fps zm_monitor.cpp 3116
2016-08-12 14:42:22.547985 zma_m3 7280 INF Camera-FI9831P-3M3: 1452000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:42:19.254536 zmc_m5 19321 INF Camera-FI9821W-4M5: 441000 - Capturing at 8.33 fps zm_monitor.cpp 3116
2016-08-12 14:42:19.142980 zma_m6 472 INF Camera-DCS5020L-5M6: 5000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:42:19.050467 zmc_m6 468 INF Camera-DCS5020L-5M6: 5000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:42:04.519777 zmc_m3 32467 INF Camera-FI9831P-3M3: 41000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:42:00.250267 zma_m1 7244 INF Camera-FI9805P-1M1: 442356 - Closing event 565, alarm end zm_monitor.cpp 1707
2016-08-12 14:42:00.195065 zma_m1 7244 INF Camera-FI9805P-1M1: 442356 - Left alarm state (565) - 90(39) images zm_monitor.cpp 1702
2016-08-12 14:41:58.024925 zma_m1 7244 INF Camera-FI9805P-1M1: 442331 - Gone into alert state zm_monitor.cpp 1695
2016-08-12 14:41:57.676455 zma_m1 7244 INF Camera-FI9805P-1M1: 442329 - Gone back into alarm state zm_monitor.cpp 1686
2016-08-12 14:41:57.468731 zma_m1 7244 INF Camera-FI9805P-1M1: 442328 - Gone into alert state zm_monitor.cpp 1695
2016-08-12 14:41:48.280687 zma_m3 7280 INF Camera-FI9831P-3M3: 1451000 - Analysing at 28.57 fps zm_monitor.cpp 1287
2016-08-12 14:41:48.202376 zma_m1 7244 INF Camera-FI9805P-1M1: 442291 - Opening new event 565, alarm start zm_monitor.cpp 1651
2016-08-12 14:41:48.071150 zma_m1 7244 INF Camera-FI9805P-1M1: 442291 - Gone into alarm state zm_monitor.cpp 1605
2016-08-12 14:41:45.871525 zma_m6 472 INF Camera-DCS5020L-5M6: 4000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:41:45.779319 zmc_m6 468 INF Camera-DCS5020L-5M6: 4000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:41:31.232274 zmc_m3 32467 INF Camera-FI9831P-3M3: 40000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:41:18.922200 zma_m1 7244 INF Camera-FI9805P-1M1: 442000 - Analysing at 9.62 fps zm_monitor.cpp 1287
2016-08-12 14:41:17.992776 zma_m5 7692 INF Camera-FI9821W-4M5: 1072000 - Analysing at 8.40 fps zm_monitor.cpp 1287
2016-08-12 14:41:13.482537 zma_m3 7280 INF Camera-FI9831P-3M3: 1450000 - Analysing at 27.78 fps zm_monitor.cpp 1287
2016-08-12 14:41:12.599627 zma_m6 472 INF Camera-DCS5020L-5M6: 3000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:41:12.514756 zmc_m6 468 INF Camera-DCS5020L-5M6: 3000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:41:07.525719 zmc_m1 32476 INF Camera-FI9805P-1M1: 15000 - Capturing at 10.00 fps zm_monitor.cpp 3116
2016-08-12 14:41:06.990692 web_php 27174 ERR /usr/bin/zmcontrol.pl --panstep=21 --command=moveRelRight --id=6=> /usr/share/zoneminder/www/includes/functions.php 1993
2016-08-12 14:41:06.926320 zmcontrol 510 FAT Can't load ZoneMinder::Control::DCS5020L zmcontrol.pl
2016-08-12 14:41:06.882840 zmcontrol 510 INF Starting control server 6/DCS5020L zmcontrol.pl
2016-08-12 14:40:58.076117 zmc_m3 32467 INF Camera-FI9831P-3M3: 39000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:40:50.094176 zma_m1 7244 INF Camera-FI9805P-1M1: 441708 - Closing event 564, alarm end zm_monitor.cpp 1707
2016-08-12 14:40:50.031825 zma_m1 7244 INF Camera-FI9805P-1M1: 441708 - Left alarm state (564) - 84(34) images zm_monitor.cpp 1702
2016-08-12 14:40:47.158404 zma_m1 7244 INF Camera-FI9805P-1M1: 441683 - Gone into alert state zm_monitor.cpp 1695
2016-08-12 14:40:46.099049 zma_m2 7258 INF Camera-FI9805P-2M2: 476000 - Analysing at 9.90 fps zm_monitor.cpp 1287
2016-08-12 14:40:43.792946 zmc_m2 32463 INF Camera-FI9805P-2M2: 15000 - Capturing at 9.90 fps zm_monitor.cpp 3116
2016-08-12 14:40:39.364260 zma_m6 472 INF Camera-DCS5020L-5M6: 2000 - Analysing at 30.30 fps zm_monitor.cpp 1287
2016-08-12 14:40:39.264469 zmc_m6 468 INF Camera-DCS5020L-5M6: 2000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:40:39.202123 zma_m1 7244 INF Camera-FI9805P-1M1: 441649 - Opening new event 564, alarm start zm_monitor.cpp 1651
2016-08-12 14:40:39.108718 zma_m1 7244 INF Camera-FI9805P-1M1: 441649 - Gone into alarm state zm_monitor.cpp 1605
2016-08-12 14:40:37.079631 zma_m3 7280 INF Camera-FI9831P-3M3: 1449000 - Analysing at 28.57 fps zm_monitor.cpp 1287
2016-08-12 14:40:24.627874 zmc_m3 32467 INF Camera-FI9831P-3M3: 38000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:40:19.423791 zmc_m5 19321 INF Camera-FI9821W-4M5: 440000 - Capturing at 8.33 fps zm_monitor.cpp 3116
2016-08-12 14:40:06.108916 zma_m6 472 INF Camera-DCS5020L-5M6: 1000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:40:05.990766 zmc_m6 468 INF Camera-DCS5020L-5M6: 1000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:40:02.561549 zma_m3 7280 INF Camera-FI9831P-3M3: 1448000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:39:51.318698 zmc_m3 32467 INF Camera-FI9831P-3M3: 37000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:39:34.228141 zma_m1 7244 INF Camera-FI9805P-1M1: 441000 - Analysing at 10.00 fps zm_monitor.cpp 1287
2016-08-12 14:39:33.000359 zma_m6 472 INF In mode 3/1, warming up zma.cpp 142
2016-08-12 14:39:32.814180 zmdc 7199 INF 'zma -m 6' starting at 16/08/12 14:39:32, pid = 472 zmdc.pl
2016-08-12 14:39:32.811870 zmdc 472 INF 'zma -m 6' started at 16/08/12 14:39:32 zmdc.pl
2016-08-12 14:39:32.635538 zmc_m6 468 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-12 14:39:32.406510 zmdc 468 INF 'zmc -m 6' started at 16/08/12 14:39:32 zmdc.pl
2016-08-12 14:39:32.404920 zmdc 7199 INF 'zmc -m 6' starting at 16/08/12 14:39:32, pid = 468 zmdc.pl
2016-08-12 14:39:32.104970 zmdc 7199 INF 'zmc -m 6' exited normally zmdc.pl
2016-08-12 14:39:32.048682 zmc_m6 386 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:39:32.006840 zmc_m6 386 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-08-12 14:39:31.940138 zmc_m6 386 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-08-12 14:39:31.875756 zmc_m6 386 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:39:31.779270 zmdc 7199 INF 'zmc -m 6' sending stop to pid 386 at 16/08/12 14:39:31 zmdc.pl
2016-08-12 14:39:31.508340 zmdc 7199 INF 'zma -m 6' exited normally zmdc.pl
2016-08-12 14:39:31.464158 zma_m6 389 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:39:31.421720 zmdc 7199 INF 'zma -m 6' sending stop to pid 389 at 16/08/12 14:39:31 zmdc.pl
2016-08-12 14:39:31.054710 zmdc 7199 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2016-08-12 14:39:28.602307 zma_m3 7280 INF Camera-FI9831P-3M3: 1447000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:39:27.612330 zmc_m1 32476 INF Camera-FI9805P-1M1: 14000 - Capturing at 10.00 fps zm_monitor.cpp 3116
2016-08-12 14:39:18.122196 zmc_m3 32467 INF Camera-FI9831P-3M3: 36000 - Capturing at 29.41 fps zm_monitor.cpp 3116
2016-08-12 14:39:18.043443 zma_m5 7692 INF Camera-FI9821W-4M5: 1071000 - Analysing at 8.33 fps zm_monitor.cpp 1287
2016-08-12 14:39:05.260413 zma_m2 7258 INF Camera-FI9805P-2M2: 475000 - Analysing at 10.00 fps zm_monitor.cpp 1287
2016-08-12 14:39:02.946760 zmc_m2 32463 INF Camera-FI9805P-2M2: 14000 - Capturing at 10.10 fps zm_monitor.cpp 3116
2016-08-12 14:39:02.270410 zma_m6 389 INF Camera-DCS5020L-5M6: 1000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:39:01.629768 zmc_m6 386 INF Camera-DCS5020L-5M6: 1000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:38:54.502546 zma_m3 7280 INF Camera-FI9831P-3M3: 1446000 - Analysing at 29.41 fps zm_monitor.cpp 1287
2016-08-12 14:38:44.712434 zmc_m3 32467 INF Camera-FI9831P-3M3: 35000 - Capturing at 30.30 fps zm_monitor.cpp 3116
2016-08-12 14:38:29.527395 zma_m6 389 INF In mode 3/1, warming up zma.cpp 142
2016-08-12 14:38:28.482032 zma_m6 389 WAR Waiting for capture daemon zm_monitor.cpp 503
2016-08-12 14:38:28.363650 zmc_m6 386 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-12 14:38:28.322880 zmdc 389 INF 'zma -m 6' started at 16/08/12 14:38:28 zmdc.pl
2016-08-12 14:38:28.321320 zmdc 7199 INF 'zma -m 6' starting at 16/08/12 14:38:28, pid = 389 zmdc.pl
2016-08-12 14:38:28.263190 zmdc 7199 INF Starting pending process, zma -m 6 zmdc.pl
2016-08-12 14:38:28.121250 zmdc 7199 ERR 'zma -m 6' exited abnormally, exit status 255 zmdc.pl
2016-08-12 14:38:28.037650 zmdc 7199 INF 'zmc -m 6' starting at 16/08/12 14:38:28, pid = 386 zmdc.pl
2016-08-12 14:38:28.012620 zmdc 386 INF 'zmc -m 6' started at 16/08/12 14:38:28 zmdc.pl
2016-08-12 14:38:27.955941 zma_m6 383 ERR Shared data not initialised by capture daemon for monitor Camera-DCS5020L-5M6 zm_monitor.cpp 442
2016-08-12 14:38:27.905460 zmdc 7199 INF Starting pending process, zmc -m 6 zmdc.pl
2016-08-12 14:38:27.729980 zmdc 383 INF 'zma -m 6' started at 16/08/12 14:38:27 zmdc.pl
2016-08-12 14:38:27.727660 zmdc 7199 INF 'zma -m 6' starting at 16/08/12 14:38:27, pid = 383 zmdc.pl
2016-08-12 14:38:27.685450 zmdc 7199 INF 'zmc -m 6' exited normally zmdc.pl
2016-08-12 14:38:27.614349 zmc_m6 376 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:27.577013 zmc_m6 376 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-08-12 14:38:27.543587 zmc_m6 376 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-08-12 14:38:27.510173 zmc_m6 376 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:38:27.439270 zmdc 7199 INF 'zmc -m 6' sending stop to pid 376 at 16/08/12 14:38:27 zmdc.pl
2016-08-12 14:38:27.123302 zmc_m6 376 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-08-12 14:38:26.991570 zmwatch 7319 INF Restarting capture daemon for Camera-DCS5020L-5M6, shared data not valid zmwatch.pl
2016-08-12 14:38:26.930560 zmdc 376 INF 'zmc -m 6' started at 16/08/12 14:38:26 zmdc.pl
2016-08-12 14:38:26.928710 zmdc 7199 INF 'zmc -m 6' starting at 16/08/12 14:38:26, pid = 376 zmdc.pl
2016-08-12 14:38:26.649410 zmdc 7199 INF 'zmc -m 6' exited normally zmdc.pl
2016-08-12 14:38:26.541663 zmc_m6 22978 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:38:26.532995 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:26.464540 zmdc 7199 INF 'zmc -m 6' sending stop to pid 22978 at 16/08/12 14:38:26 zmdc.pl
2016-08-12 14:38:26.458005 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:26.420924 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:26.341004 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:26.300524 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:26.181187 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:26.142830 zmdc 7199 INF 'zma -m 6' exited normally zmdc.pl
2016-08-12 14:38:26.133532 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:26.055783 zma_m6 22982 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-08-12 14:38:26.016106 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.932610 zmdc 7199 INF 'zma -m 6' sending stop to pid 22982 at 16/08/12 14:38:25 zmdc.pl
2016-08-12 14:38:25.861250 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.696239 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.658440 zmdc 7199 WAR Can't find process with command of 'zmtrack.pl -m 6' zmdc.pl
2016-08-12 14:38:25.653230 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.570998 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.530574 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.462339 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.428939 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.354118 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.245431 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:25.169724 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:25.069658 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.977201 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.845295 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.747931 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.701993 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.634584 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.601065 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.529378 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.490443 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.408995 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.373152 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.293295 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.250656 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.189492 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.126729 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:24.049631 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:24.008815 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.932683 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.893423 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.789660 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.717225 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.640123 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.595844 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.513625 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.476450 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.396689 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.357911 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.279736 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.196758 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.121151 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:23.081383 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:23.004175 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.965336 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.887201 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.851090 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.720237 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.689609 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.619745 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.584704 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.519451 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.479052 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.410822 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.377472 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.310528 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.278549 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.210217 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.177326 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.109928 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:22.077305 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:22.009614 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:21.977185 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:21.909323 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:21.877256 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
2016-08-12 14:38:21.779779 zmc_m6 22978 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-08-12 14:38:21.726743 zmc_m6 22978 ERR Failed authentication: zm_remote_camera_http.cpp 741
I will have to make two post to cover this one topic as I'm having issues uploading images, Please see 2 of 2 below
