PTZ with onvif
jedi
Re: PTZ with onvif
Post by jedi » Tue Apr 21, 2020 5:06 pm
I had problems setting up PTZ control onvif camera purchased on Ali. Onvif view was fine without problems, however ptz control did not work.
Camera: IPD-E3CY02-BS
And I want to share a solution so that it can be of help to others.
The solution turned out to be quite simple and it does not require to script changes:
Control type: Netcat ONVIF
Control device: SubStream <--or MainStream is worked too
Control address: admin:adminpass@192.168.1.111:8999/onvif/ptz_service
After changing, a zoneminder reboot is required
...:8999/onvif/ptz_service - I learned this address using the packet sniffer from "Onvif Device Manager"
Have а nice day
jeremyenos
Re: PTZ with onvif
Post by jeremyenos » Tue Apr 21, 2020 9:42 pm
A quite critical detail I burned a lot of time overlooking! thx.
jeremyenos
Re: PTZ with onvif
Post by jeremyenos » Tue Apr 21, 2020 9:46 pm
Ok- I found 2 issues and got it to work.
1) I wasn't restarting the docker instance- apparently that netcat.pm is read in only at start time! Doh.
2) I looked in the ONVIF documentation, and it mentioned that to do a stop, just send the same command for movement with a x and y both set to 0 instead of a number. That worked for the autostop and stop sequences as far as I can tell.
Now, if only I could get presets to work. (and be limited to just a few- displaying 64 preset options in ZMNinja gets a little obnoxious.
ronw
Re: PTZ with onvif
Post by ronw » Wed Apr 22, 2020 7:09 pm
Jeremy, How did you implement the 0,0 command? I have the same issue and am struggling with it.
kysdaddy
Re: PTZ with onvif
Post by kysdaddy » Mon Jul 13, 2020 1:42 pm
Did you ever get this figured out? I am having identical issues
thefuzz4
Re: PTZ with onvif
Post by thefuzz4 » Mon Aug 03, 2020 11:51 pm
Did anyone figure out getting presets to work?
jeremyenos
Re: PTZ with onvif
Post by jeremyenos » Thu Jan 14, 2021 6:59 am
Much apologies to neglected questions- somehow I missed any notification of them.
I've re-installed since, and I'm now using version 1.34.22 (I forgot the previous version, but it was older). Anyway, I set an auto stop timeout = 1, put the control address in as before, and this time it worked. At least w/ my newer S3VC camera. (my older ones were fried by lightning)
I'll repost the following question in the appropriate version branch, but since it's related, figured I'd mention here as well.
I'm now experimenting and failing with a different Chinese brand camera that seems crazy obscure... Tyvance? It looks just like YoLuke, but it's a little better featured, the firmware is slightly better, and app is slightly different. But I have had zero success getting PTZ to work at all with Zoneminder.
btw- I run dlandon's Zoneminder docker image, if it matters. But with the previous Zoneminder version and this one, I have never had the "Probe ONVIF" function detect any cameras. I have no idea why, but I feel like that is where I should be focusing my efforts. I have already tried putting in the URL that I discovered with ONVIF DM and a wireshark sniffer. No luck there either.
ONVIF Device Manager, Tinycam, etc... all seem to detect these cameras effortlessly and PTZ works w/o issue. I wish Zoneminder worked as well. I can't seem to find a starting point to even debug it. The command line tool returns nothing either.
So here I am in the forum again.
LeoTLT
Re: PTZ with onvif
Post by LeoTLT » Wed Mar 17, 2021 9:33 am
Greetings to all! Guys, help start a PTZ on such a camera. I can't do it.
UPD:
Immediately I apologize for my English - this is all google translator.)) (You have the latest version of ZoneMinder installed, v1.34.23) - my server. Cameras in the production of automatic doors. There are almost 100 of them in the installation.
I managed to get this PTZ camera in the following steps. Hope it comes in handy for someone here!
I only fixed this parameter in the original Netcat.pm file:
I had - my $ cmd = 'onvif / PTZ';
Fixed on - my $ cmd = 'onvif / ptz_service';
And control settings as in the screenshot that I attached.
Thanks to all! Because I took all the ideas from this topic.
Everything works in both ZM and ZMninjapro.
2021-03-17 20-46-28.png (58.5 KiB) Viewed 2615 times
I invite everyone to the group https://t.me/zoneminder for joint discussion, help and exchange of experience.
L4UR3NS
Re: PTZ with onvif
Post by L4UR3NS » Mon Apr 19, 2021 11:48 pm
Hi all.
I was having some trouble getting PTZ to work but since I managed to pull it off I thought I'd share my findings.
The camera's I have a 25 EUR chinese cams (see attachment).
Using the default Netcat.pm file with the following settings:
Control Type: Netcat ONVIF
Control Device: Profile_1
Control Address: admin:12345@IPADDRESS:80/onvif/ptz_service
Auto Stop Timeout: 0,10
Hope this will help someone.
hornetster
Re: PTZ with onvif
Post by hornetster » Thu May 06, 2021 11:11 am
Yes!
Thanks to all the genii here.
I have an el cheapo SriCam SP012, and have been battling with this for a while, but have just succeeded!
Settings are:
Control Address: admin:12345@IPADDRESS:5000/onvif/ptz_service
Brilliant!
OpensuseLeap15.2/PLASMA
Ubuntu20.04/XFCE4
ZoneminderV1.34.26
Users browsing this forum: No registered users and 6 guests
