I think I found a good reason for no Montage video......
dtruesdale
Post by dtruesdale »
Ok since 1.28 I have had cycle streams but no montage......welp I think I just cracked the egg.
Here it goes in cycle I get this url for video:
http://172.16.8.180/cgi-bin/nph-zms?mod ... 1470627636
Now the 172.16.8.180 is the ip of the server. So we get streaming.
On the Montage monitors we get this:
http://172.16.8.150/cgi-bin/nph-zms?mod ... 1470627703
Now the 172.16.8.150 is the ip of the remote box with the cameras attached. Should it not be the 172.16.8.180 for the server which is retrieving the said video?
I have had this issue in 1.28, 1.29 and 1.30, also when going into montage I get this warning in the logs:
Adjusting to minimum width when getting popup size for tag 'cycle' - getPopupSize()
Also to be clear this is not an upgrade but a fresh install. The 1.28 to 1.29 was an upgrade.
Any ideas here?
dtruesdale
Re: I think I found a good reason for no Montage video......
Figured it out, don't set server......................in the monitor settings. Fixed
