Avoiding the NO STRICT_TRANS_TABLES requirement?
bodom
Post by bodom » Thu Feb 15, 2018 4:57 am
Hi there!
I have installed this software and it looks very interesting; anyway, I can't use it because I am facing the error described in this post: viewtopic.php?t=24943
Unfortunately, I cannot change the global sql_mode of the server, because other apps are also running on it.
Since setting the SQL mode after connection is just a matter of running a single query, I suppose there is another way to have zm set its own SQL mode at runtime. How can I achieve that?
Thank you!
Re: Aviding the NO STRICT_TRANS_TABLES requirement?
Post by bbunge » Thu Feb 15, 2018 10:29 pm
Actually you need to set
sql_mode=NO_ENGINE_SUBSTITUTION
bodom
Re: Avoiding the NO STRICT_TRANS_TABLES requirement?
Post by bodom » Thu Feb 15, 2018 10:34 pm
I can't.
Any different solution?
Post by bbunge » Fri Feb 16, 2018 2:05 am
Switch to Mariadb. Or go back to an earlier MySQL, 5.5 I think.
bodom
Post by bodom » Fri Feb 16, 2018 2:16 am
I can't change the DBMS or its globals settings, because many other apps are running on it.
Is there any solution that involves changing ZoneMinder configuration instead?
This seems to be a quite common scenario: I don't think everyone runs ZoneMinder on a dedicated server.
Post by bbunge » Fri Feb 16, 2018 2:35 am
Virtual box?
While I am not an advocate for it it may be possible to use Docker. I seem to remember the database also runs in Docker.
Post by knight-of-ni » Fri Feb 16, 2018 12:44 pm
Refer to the sql documentation to set sql_mode per session:
https://dev.mysql.com/doc/refman/5.7/en/sql-mode.html
This shows you how to set the variable at the start of each session transparently:
https://dba.stackexchange.com/questions ... given-user
My friend Google is really smart! :D
bodom
Post by bodom » Fri Feb 16, 2018 2:45 pm
Does your smart Google friend also explains how to apply that to ZoneMinder's session?
Because setting the variable for my own console session seems quite useless to me...
Post by knight-of-ni » Fri Feb 16, 2018 4:25 pm
Try reading what I linked for you and you will find your answer.
bodom
Post by bodom » Sat Feb 17, 2018 3:46 pm
So, for others who may be unable to quickly understand the answer, the solution involves hacking mysql's login script.
Edit your mysqld.conf and add this inside the [mysqld] section:
init_connect = 'SET @@sql_mode = CASE CURRENT_USER() WHEN \'zmuser@localhost\' THEN \'NO_ENGINE_SUBSTITUTION\' ELSE @@sql_mode END;'
(adjust it accordingly to you zoneminder username and merge any previous script, if any)
That's weird indeed, but it works.
Thank you. Solved.
