Blue screen after reboot/reset of RTSP/ONVIF camera
mrbill
Post by mrbill »
I installed a new RTSP camera - a wanscam hw0029. Works fine - works great, except after I reboot it, sometimes ZM doesn't seem to re-connect to the stream and gives a blue screen. I can resolve this quite easily by disabling and re-enabling the camera under the function menu and un-checking 'enabled' (then save), then checking it agian, and saving.
Is this a known issue in 1.29 and perhaps resolved in later versions? I loath to upgrade because of all the setup etc, and what I have now 'just works' fine.
