Grandstream GXV3504 - Source path?
BobLaske
Post by BobLaske » Fri Oct 13, 2017 3:58 am
When using the grandstream GXV3504, do I have to add one monitor for each channel or am I missing something?
I'm totally new to zoneminder and learning about it. For now, I've created four different monitors, each using rtsp://192.168.1.227/x but wondered if there is something I am missing, maybe the ability to switch between cameras in one monitor?
It seems that grouping is the way to do this but not 100% sure and still reading documentation but though I'd ask.
Thanks for any help.
snake
Re: Grandstream GXV3504 - Source path?
Post by snake » Sat Oct 14, 2017 7:38 pm
For the source path, you can find GXV3504 covered in the wiki hardware compatibility list. You mention you are using the RTSP stream, but there is also an MJPEG stream. I don't recommend the GXV3504. I've had a number of these fail. Try searching online for better name brand used video encoders. They can be obtained cheaply (<100 or <50 dollars).
Four different monitors is correct.
Switching between cameras in one monitor... That's not something I have dealt with. The GXV I don't believe has this functionality, nor am I aware of any such in ZM.
BobLaske
Post by BobLaske » Sun Oct 15, 2017 12:01 am
I just happened to have purchased the Gransdtream for test using ZM but yes, I'll be looking at others.
I don't recall seeing anything but rtsp paths. Maybe I missed something.
In terms of the individual cameras, now it makes sense so I appreciate your input on this.
Thanks.
