I use a very old noname USB webcam (VGA quality only) as simple security camera, the automatic camera settings are not working on Linux (At least I couldn't get them to work). I created a day / night script which is setting them manually, it works perfectly fine but ZM seems to override those settings from time to time to the ones which are set in ZM.
OS: Ubuntu 16 Server LTS
Camera: ID 0c45:612c Microdia PC Camera (SN9C110) <- Using default (Limited) Ubuntu driver, couldn't find a better one
How can I disable the settings override by ZM and make sure those values will be only set by my script? I think it happens each time the log says "Hue control not supported" but I'm not even logged into the ACP at those times.
cam_day.sh
cam_night.shv4l2-ctl -d /dev/video0 -c gain_automatic=0
v4l2-ctl -d /dev/video0 -c brightness=85
v4l2-ctl -d /dev/video0 -c contrast=15
v4l2-ctl -d /dev/video0 -c saturation=22
v4l2-ctl -d /dev/video0 -c gamma=20
v4l2-ctl -d /dev/video0 -c sharpness=100
The other issue I got is that the API isn't working, it says that mod_rewrite isn't properly configured/enabled but it actually is. This isn't important though cause I don't need the API currently.v4l2-ctl -d /dev/video0 -c gain_automatic=0
v4l2-ctl -d /dev/video0 -c brightness=250
v4l2-ctl -d /dev/video0 -c contrast=30
v4l2-ctl -d /dev/video0 -c saturation=18
v4l2-ctl -d /dev/video0 -c gamma=40
Picture of my recent logs:
