Apache default configuration - directory listing
alexo
Post by alexo » Wed Feb 01, 2017 8:47 am
I recently installed 1.29.0 on Debian Jessie (8.7). The default apache config file has the following:
  php_flag register_globals off
  <IfModule mod_dir.c>
    DirectoryIndex index.php
  </IfModule>
</Directory>
Now without login to ZM, I'm able to browse and view events folders :(
When I disable directory listing, it seems that ZM is working fine.
What feature/functionality requires the directory Indexing? Can I disable it?
How can I further secure the default install?
Thanks for your time.
Re: Apache default configuration - directory listing
Post by bbunge » Wed Feb 01, 2017 2:07 pm
Interesting... Just tried it on Debian 9 and Ubuntu 16.04 with http://ipaddress/zm/events and got the directory listing, too.
Will look into this...
bb
SteveGilvarry
Post by SteveGilvarry » Wed Feb 01, 2017 7:29 pm
Remove it.
And put server behind VPN, and cameras on separate subnet with no internet access.
Production Zoneminder 1.35.x
More Dev VM's than I care to count.
MJN
Post by MJN » Tue Feb 14, 2017 6:58 pm
I use Basic Authentication (inside HTTPS) to secure the whole ZM tree.
Post by bbunge » Tue Feb 14, 2017 8:45 pm
As posted in the 1.30.x area
Here is a "fix" to block the directory browsing. I must admit it is partly my fault..
For Ubuntu
Undo my "Fix to allow API to work" (back to the original configuration)
nano /etc/apache2/apache2.conf
Change All to None in two places as shown below
<Directory /usr/share>
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/>
AllowOverride None
Require all granted
</Directory>
Ctrl+o Enter to save
CTRL+x to exit
Edit zoneminder.conf
Add a - before Indexes and a + before FollowSymLinks
Make sure the following is at the bottom of the file
AllowOverride All
</Directory>
CTRL+x to exit
Restart Apache
service apache2 reload
http://ip-addr/zm/events should now give you a Forbidden 403 error
Users browsing this forum: No registered users and 6 guests
