Camera SV3C in Zoneminder
Rothan
Post by Rothan »
I am trying to setup Zoneminder with the following camera
Camera
SV3C SV-B01-1080P-POE
Server version unRAIDServer-6.2.4-x86_64
Container Zoneminder-1_29 - https://github.com/aptalca/docker-zoneminder/tree/v1.29
Followed instructions for setting up ffmpeg.
I can connect to the camera with Monitor Client. SV3c software and with Xeoma no issues.
Tracked down that rtsp://admin: works for streaming in VLC.
I can't get a picture in Zoneminder at all been trying for a few days.
One Amazon.com review states they got it working in Zoneminder no problem.
Settings used
Source Type: ffmpeg
Source Path: rtsp://admin:
Any help would be appreciated.
rapture177
Re: Camera SV3C in Zoneminder
Post by rapture177 »
Did you figure this out? I'm having the exact same issue.
rapture177
I figured it out. Source type = ffmpeg. source path = rtsp://<username>:<userpass>@<IP>/11
I used this site https://www.ispyconnect.com/man.aspx?n=HD+IPC to find it. Just used the generator for the "1080p" model.
After I saved the first time, and open the monitor it doesn't load until I close and reopen the monitor. Weird.
Pure L
Post by Pure L »
I did:
rtsp://<IP>:554/12
It's worth noting that I'm getting wicked smearing. Not sure what's that from.
EDIT:
Per this issue:
https://github.com/ZoneMinder/ZoneMinder/issues/323
... I'm trying this:
rtsp://<IP>:554/12?tcp
I just added '?tcp' to the query string and things seem somewhat better.
Fingers crossed...
EDIT AGAIN:
Doesn't really help. Damn.
SlowScan
Post by SlowScan »
I used fixed IP and no authentication (cams can't reach Internet) so, rtsp://192.168.x.xx/11. Source Type set to Ffmpeg. Remote Method set to RTP/RTSP. Cam throttled to 5 fps at the cam. Maximum FPS set to 7 fps.
That particular cam is out of service at the moment pending relocation, but I had no smearing issues.
