How to use your external camera's motion detection with ZM
puneet
Post by puneet » Fri Aug 05, 2016 5:59 am
Hi Support,
How To setup on zomeminder recording only when motion is detected. we need to use the motion detection built in the camera to save CPU
Please help
Thanks & Puneet sharma
puneet
Re: How to use your external camera's motion detection with ZM
Post by puneet » Fri Aug 05, 2016 6:26 am
i have zoneminder 1.29 on Centos 6.5
Can someone tell me the perticular steps its will really helpful for me
PacoLM
Post by PacoLM » Fri Aug 05, 2016 10:06 am
There's a fantastic option in the forum called "Search", I recommend you to use it before asking for help.
Hope it helps,
PacoLM
mini-ITX system (6 IPCams - Ubuntu14.04 - ZM1.31.1)
puneet
Post by puneet » Fri Aug 05, 2016 10:49 am
@ PacoLM i searched but didnt found any solution can you please help me.
Thanks a lot
tikismoke
Post by tikismoke » Fri Sep 02, 2016 6:32 pm
using nc and allowing the
ZM_OPT_TRIGGERS
ZoneMinder can interact with external systems which prompt or cancel alarms. This is done via the zmtrigger.pl script. This option indicates whether you want to use these external triggers. Most people will say no here.
dmroeder
Post by dmroeder » Thu Sep 08, 2016 9:52 pm
edit: Apparently I cannot read, I thought this was about triggering over a network. Post removed, my bad.
