Reduce Memory consumption
philip_d
Post by philip_d » Mon May 02, 2016 5:26 am
Dear All,
How can I reduce the memory consumption of camera like other commercial software in Zoneminder. Approximately I have 25-39 cameras in one location which upon my testing Zoneminder is crashing signal due to lack of memory.
mikb
Re: Reduce Memory consumption
Post by mikb » Mon May 02, 2016 4:28 pm
Use fewer cameras. Use lower resolution. Use lower frame rates and shorter circular buffers (pre-roll/pre-event buffer).
I don't think you can "beat the system". It takes as much memory as it takes, for the load you have chosen to create.
Maybe split the cameras up into 2/3 zones across more than one computer,all running Zoneminder?
ZMBrian
Post by ZMBrian » Mon May 02, 2016 5:30 pm
Under Options > Images, maybe you could try reducing JPEG_FILE_QUALITY and/or JPEG_ALARM_FILE_QUALITY? JPEG_FILE_QUALITY will set the compression percentage for non-alarmed frames which will probably be the bulk of your recording. I'm new to this too, but found that changing these two parameters help me squeeze out a little better memory consumption.
Brian
