InValid TimeZone
philip_d
InValid TimeZone
Post by philip_d » Tue Apr 26, 2016 4:46 am
Hi, Everyone,
Is there anybody that can help me regarding 1.29 version.Below is the error when I connect on the browser. I changed already the timezone but still the same.I'm using Unbuntu LTS16.04 Server
ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone
PacoLM
Re: InValid TimeZone
Post by PacoLM » Tue Apr 26, 2016 6:27 am
There are a couple of php.ini files. Check if you have edited the correct one by searching them using the command:
find / -name php.ini
Regards,
PacoLM
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
philip_d
Post by philip_d » Tue Apr 26, 2016 7:21 am
I tried to change all the settings (timezone) of php.ini but the problem still the same.
OS : Unbuntu LTS 16.04
Zoneminder : 1.29
SteveGilvarry
Post by SteveGilvarry » Tue Apr 26, 2016 8:24 am
So assuming you have a standard 16.04 install of PHP, run this and post the results please.
cat /etc/php/7.0/apache2/php.ini | grep 'date.timezone ='
Production Zoneminder 1.35.x
More Dev VM's than I care to count.
philip_d
Post by philip_d » Tue Apr 26, 2016 8:37 am
Below it appear when I run your command.
date.timezone = Asia/Muscat
SteveGilvarry
Post by SteveGilvarry » Tue Apr 26, 2016 9:18 am
Looks good, just making sure no ; in front and is a valid timezone.
Restarted apache? service apache2 reload
After that you are going to have to investigate your PHP setup using phpinfo(), mainly looking for exactly which php.ini file your install is using.
philip_d
Post by philip_d » Tue Apr 26, 2016 12:36 pm
Hi Steve,
do you have the link for installation for this Zoneminder 1.29 on Unbuntu LTS 16.04? I tried to change all the timezone in each php but still the same.
SteveGilvarry
Post by SteveGilvarry » Tue Apr 26, 2016 1:38 pm
bjb1959
Post by bjb1959 » Fri Jun 24, 2016 1:29 pm
SteveGilvarry wrote:Looks good, just making sure no ; in front and is a valid timezone.
I have the same problem. I did not have this issue with 15.10. I have 3 php.ini files. all have been set identically. the one my system uses is located in the cli subfolder (/etc/php/7.0/cli) I have restarted apache using sudo service apache2 restart but still the issue remains. any ideas? :?
[Date]
date.timezone = America/Chicago
SteveGilvarry
Post by SteveGilvarry » Sat Jun 25, 2016 8:48 am
Are you using nginx? Because my fresh 16.04 build is using /etc/php/7.0/apache2/php.ini.
I would be checking where it is coming from using a phpinfo() test page, as your string is correct.
bjb1959
Post by bjb1959 » Mon Jun 27, 2016 1:46 pm
I am using apache not nginx. I already used phpinfo() which is what shows /etc/php/7.0/cli/php.ini as the one being used although I have modified all 3 php.ini files just in case.
SteveGilvarry
Post by SteveGilvarry » Tue Jun 28, 2016 1:00 am
I can't help but think something is wrong with your apache. CLI is PHP command line, not the apache PHP module. Check that you have libapache2-mod-php7.0 installed and apache has the module enabled.
Post by rockedge » Wed Jun 29, 2016 4:22 am
Try to restart the MySQL server. This timezone problem I keep running across and have not quite found the cause...but restarting the mysql server after the errors occurred fixed it.. By me it is the causing problems viewing events.
bjb1959
Post by bjb1959 » Fri Jul 08, 2016 2:55 pm
SteveGilvarry wrote:I can't help but think something is wrong with your apache. CLI is PHP command line, not the apache PHP module. Check that you have libapache2-mod-php7.0 installed and apache has the module enabled.
I do have that installed and enabled. I just tried installing from scratch again using the guide and get same issue. never had this with 15.10 so not sure what the problem is but apparently I just can't use zoneminder any longer.
bjb1959
Post by bjb1959 » Fri Jul 08, 2016 4:01 pm
ok, I found a workaround. still don't know what the actual problem is but I commented out the check line in the index.php in /usr/share/zoneminder folder by adding the 3 sets of // and then the { just below it. now I can get to the web interface. still no idea what in that line is the problem but at least I have access.
// Check time zone is set
// if (!ini_get('date.timezone') || !date_default_timezone_set(ini_get('date.timezone'))) {
// date_default_timezone_set('UTC');
// Fatal( "ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone" );
