Ubuntu 16.04 Release with Zoneminder 1.29.0
Pedulla
Re: Ubuntu 16.04 Release with Zoneminder 1.29.0
Post by Pedulla » Tue May 03, 2016 1:19 am
bbunge wrote: If you run Zoneminder long enough with lots of events, you will have to tune the MySQL, or Mariadb, settings.
bb
Can someone please quantify "lots" of events?
1,000; 10,000; 100,000...
Pedulla
Post by Pedulla » Tue May 03, 2016 2:56 am
Bam!
Nailed it first time through with the Mariadb install.
Nice work!
SteveGilvarry
Post by SteveGilvarry » Tue May 03, 2016 6:48 am
@sigge And if all installed as per bbunge, then as per MJN, enable php in apache, using MJN's command, or maybe this
sudo a2enmod php7.0
Production Zoneminder 1.35.x
More Dev VM's than I care to count.
Sigge
Post by Sigge » Tue May 03, 2016 11:25 am
I "purged" all the packages including mysql. Just kept apache2. Then reinstalled them all.
Now it works!
Just have to make my camera work.....
caseyj
Post by caseyj » Tue May 03, 2016 12:23 pm
Can someone do this
with Ubuntu 16.04 Server Release ? :oops: :oops:
Post by bbunge » Tue May 03, 2016 4:22 pm
caseyj wrote:Can someone do this
Wait for it. Am still working on upgrade procedures, which work sometimes, fighting for a warranty claim on my Maytag heat pump, and other "life" issues.
bb
caseyj
Post by caseyj » Wed May 04, 2016 4:55 am
Wait for it
Sure. Thanks so much for your effort !
Zsolt
Post by Zsolt » Mon May 23, 2016 9:05 pm
Hi guys,
I'm stuck here:
sudo mysql -uroot -p < /usr/share/zoneminder/db/zm_create.sql
result:
ERROR 1819 (HY000) at line 562: Your password does not satisfy the current policy requirements
although my settings are:
mysql> SHOW VARIABLES LIKE 'validate_password%';
| Variable_name                        | Value |
| validate_password_dictionary_file    |       |
| validate_password_length             | 8     |
| validate_password_mixed_case_count   | 1     |
| validate_password_number_count       | 1     |
| validate_password_policy             | LOW   |
| validate_password_special_char_count | 1     |
6 rows in set (0.03 sec)
any help is appreciated.
Post by bbunge » Mon May 23, 2016 11:56 pm
Do not use sudo
Zsolt
Post by Zsolt » Tue May 24, 2016 8:53 am
same result
kamera@dvr:~$ mysql -uroot -p < /usr/share/zoneminder/db/zm_create.sql
Enter password:
MJN
Post by MJN » Tue May 24, 2016 9:04 am
You could always change the password ('zmpass') to something that satisfies the minimum requirements listed. You will have to make sure it is reflected in /etc/zm.conf too.
Zsolt
Post by Zsolt » Tue May 24, 2016 9:32 am
The message above is related to zmuser or root?
I think it's root. The root password contains upper case, lover case, numbers and special characters.
Post by bbunge » Tue May 24, 2016 11:36 am
Use the password you set up with mysql or mariadb
MJN
Post by MJN » Tue May 24, 2016 1:39 pm
Apologies I didn't spot that it was the MySQL root user. Disregard my suggestion! (or simplify the root password if acceptable from a security perspective).
Zsolt
Post by Zsolt » Tue May 24, 2016 5:07 pm
Nothing helped. Wiped everything and started from scratch.
Followed this tutorial -> https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way but now apache2 won't start.
service apache2 reload
returns
Job for apache2.service failed because the control process exited with error code. See "systemctl status apache2.service" and "journalctl -xe" for details.
root@dvr:/home/kamera# systemctl status apache2.service
● apache2.service - LSB: Apache2 web server
   Loaded: loaded (/etc/init.d/apache2; bad; vendor preset: enabled)
  Drop-In: /lib/systemd/system/apache2.service.d
           └─apache2-systemd.conf
   Active: active (running) (Result: exit-code) since Tue 2016-05-24 19:43:11 EEST; 22min ago
     Docs: man:systemd-sysv-generator(8)
  Process: 567 ExecReload=/etc/init.d/apache2 reload (code=exited, status=1/FAILURE)
   CGroup: /system.slice/apache2.service
           ├─27441 /usr/sbin/apache2 -k start
           ├─27444 /usr/sbin/apache2 -k start
           ├─27445 /usr/sbin/apache2 -k start
           └─27446 /usr/sbin/apache2 -k start
May 24 20:05:02 dvr apache2[567]:  * Reloading Apache httpd web server apache2
May 24 20:05:02 dvr apache2[567]:  * The apache2 configtest failed. Not doing anything.
May 24 20:05:02 dvr apache2[567]: Output of config test was:
May 24 20:05:02 dvr apache2[567]: AH00526: Syntax error on line 11 of /etc/apache2/conf-enabled/zoneminder.conf:
May 24 20:05:02 dvr apache2[567]: Invalid command 'php_flag', perhaps misspelled or defined by a module not included in the server configuration
May 24 20:05:02 dvr apache2[567]: Action 'configtest' failed.
May 24 20:05:02 dvr apache2[567]: The Apache error log may have more information.
May 24 20:05:02 dvr systemd[1]: apache2.service: Control process exited, code=exited status=1
May 24 20:05:02 dvr systemd[1]: Reload failed for LSB: Apache2 web server.
my zoneminder.conf
root@dvr:/home/kamera# cat /etc/apache2/conf-enabled/zoneminder.conf
    AllowOverride All
    Require all granted
</Directory>
  php_flag register_globals off
  <IfModule mod_dir.c>
    DirectoryIndex index.php
  </IfModule>
</Directory>
Users browsing this forum: No registered users and 5 guests
