Can I use Zoneminder on my existing Xubuntu day to day machine?
777funk
Post by 777funk » Thu Mar 31, 2016 9:07 pm
I would like to avoid having a separate machine, is it possible to run this on my day to day Xubuntu setup?
If not, would a Raspberry Pi work to monitor and record 3-5 cameras (Axis 210) worth of mjpegs?
Re: Can I use Zoneminder on my existing Xubuntu day to day machine?
Post by bbunge » Fri Apr 01, 2016 12:01 am
PacoLM
Post by PacoLM » Fri Apr 01, 2016 7:09 am
Well, Rpi + 5 Axis 210 cams... I do not see it, you may need a powerful device. It will work on your Xubuntu setup is you have at least 2Gigs of RAM, I will go for this option. My guess is that a device like a RPi does not have enough CPU power nor RAM to handle this configuration you are suggesting. Give it a try and post results.
PacoLM
mini-ITX system (6 IPCams - Ubuntu14.04 - ZM1.31.1)
777funk
Post by 777funk » Fri Apr 01, 2016 12:49 pm
So it looks like Xubuntu would be a go. Thanks! I will continue a new thread on the Pi. I like the idea of everything running on a 12V battery locally.
