With eyetoy ps2
rtamag
With eyetoy ps2
Post by rtamag » Wed Mar 30, 2016 11:14 pm
can you explain me all steps to install zoneminder with ps2 eye toy ?
i have installed but in browser i do not any imagem.
where i can see log errors ?
lsusb return device 004 sony
and this instructions do not return any error:
sudo /etc/init.d/zoneminder restart
sudo /etc/init.d/apache2 restart
best regards
Ricardo
rtamag
Re: With eyetoy ps2
Post by rtamag » Thu Mar 31, 2016 8:33 am
i forgot tell i'm install in Raspberry Pi 3
PacoLM
Re: With eyetoy ps2
Post by PacoLM » Thu Mar 31, 2016 8:57 pm
The search option of the forum could help you...
mini-ITX system (6 IPCams - Ubuntu14.04 - ZM1.31.1)
Nerre
Re: With eyetoy ps2
Post by Nerre » Fri Apr 01, 2016 7:10 am
The first step would be to get the camera working. Once the camera is working you can start looking at zoneminder, however since zoneminder relies on the kernel to provide a driver for the camera there is no use messing with zoneminder until the camera works with for example VLC. (VLC can play video from a video device.)
PacoLM
Re: With eyetoy ps2
Post by PacoLM » Fri Apr 01, 2016 7:18 am
And maybe google is useful too...
http://ubuntuforums.org/showthread.php?t=272328&page=17
You have to add a monitor as local (usually /dev/video0) https://major.io/2015/02/07/using-zonem ... 70-webcam/
You may need to set your camera settings, the default palette , etc
This is a good option too... http://defectio.blogspot.com.es/2012/09 ... inder.html
Hope it helps,
PacoLM
