Localhost not found in Servers Table. Fedora 23 zmrepo
linforpros
Post by linforpros » Tue Feb 16, 2016 7:19 pm
Zoneminder's logs show the following info. It is difficult to figure out where to clear it.
2016-02-16 12:56:40.386501 undef 1761 INF No Server ID or Name specified in config. Not using Multi-Server Mode.	zm_config.cpp	139
My attempt to resolve the issue was to run zmupdate.pl -f but it did not help. The command ran without errors.
Adding "localhost" to /etc/zm/zm.conf
# Host of this machine
ZM_SERVER_HOST=localhost
does not help but produces errors:
ERR ZM_SERVER_HOST set to localhost in config, but not found in Servers table
Adding hostname and server name via the web errors out with:
[code]SQL-ERR 'SQLSTATE[42S22]: Column not found: 1054 Unknown column 'Hostname' in 'field list'', statement was 'INSERT INTO Servers set Name = 'Serv1.29', Hostname = 'localhost''
[/code]
DATE/TIME
COMPONENT	SERVER	PID	LEVEL	MESSAGE	FILE	LINE
2016-02-16 13:15:57.764137	web_php		1711	ERR	ZM_SERVER_HOST set to localhost in config, but not found in Servers table.	/usr/share/zoneminder/www/includes/config.php	183
Zoneminder was installed from zmrepo on fedora 23 in ver 1.29.0-2, and then updated via dnf upgrade to ver 1.29.0-3.
Also important is that streaming from cameras stops working if I leave "localhost" in zm.conf file.
Is there a way to fix this?
best regards
LinforPros
PacoLM
Re: Localhost not found in Servers Table. Fedora 23 zmrepo
Post by PacoLM » Wed Feb 17, 2016 5:15 pm
Stop ZM and try to run "zmupdate.pl -f"
mini-ITX system (6 IPCams - Ubuntu14.04 - ZM1.31.1)
Post by knight-of-ni » Wed Feb 17, 2016 6:29 pm
This error means exactly what it says.
It is saying that you manually set ZM_SERVER_HOST in zm.conf to the value "localhost", but you have not put a corresponding value for the localhost entry under Options -> Server tab
I'm not sure why you decided to assign a value to ZM_SERVER_HOST, however.
The README instructions definitely did not say to do this:
https://github.com/ZoneMinder/ZoneMinde ... DME.Fedora
If you are trying to configure Multi-server, which is what this variable is for, then please follow the instructions here:
https://zoneminder.readthedocs.org/en/s ... erver.html
Post by knight-of-ni » Wed Feb 17, 2016 6:38 pm
Probably answers my question in the previous post regarding why you set ZM_SERVER_HOST.
This is not an error message, but an indication things are working fine (unless of course you really are trying to configure Multi-Server). Notice the "INF" means, "INFO" and not Warning or Error.
Post by knight-of-ni » Wed Feb 17, 2016 6:45 pm
I can't explain how this happened, but I can tell you how to fix this one.
Manually run this sql script:
mywl -uroot -p zm < /usr/share/zoneminder/db/zm_update-1.28.109.sql
