Page 1 of 1
Debian filename versioning error
Posted: Sat Feb 06, 2016 2:28 pm
by MJN
I have just upgraded ZoneMinder from v1.28.100 to v1.29.0 following the instructions here and noticed that whilst the zoneminder/version file correctly showed v1.29.0 the built packages seemed to be still using the old version numbers:
# ls -l zoneminder_*
-rw-r--r-- 1 root root     1309 Feb  6 13:59 zoneminder_1.28.0-wheezy.dsc
-rw-r--r-- 1 root root     1655 Feb  6 14:02 zoneminder_1.28.0-wheezy_i386.changes
-rw-r--r-- 1 root root  2525894 Feb  6 14:02 zoneminder_1.28.0-wheezy_i386.deb
-rw-r--r-- 1 root root 58894551 Feb  6 13:59 zoneminder_1.28.0-wheezy.tar.gz
Subsequent installation of the .deb above using dpkg -i did however reveal that v1.29.0 does indeed get installed.
Edit: I may have spoken too soon. Whilst my ZM install is showing as v1.29.0 I see there is no /api/ folder installed despite being in the source. I clearly need to delve a little deeper into this...
