No browser streaming
isisyodin
Post by isisyodin »
After upgrading from 1.28.1 to 1.29.0 I have lost the ability to stream or view events on my browser (Safari). However, in zmNinja I can view everything perfectly. Any ideas of what needs to get fixed?
The logs report the following errors:
2016-01-07 16:29:10.173338	web_php		5004	ERR	socket_sendto( /var/run/zm/zms-120706s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-01-07 16:29:08.471058	zma_m3		4857	INF	FrontPanoramic: 12000 - Analysing at 12.05 fps	zm_monitor.cpp	1287
2016-01-07 16:29:03.172226	web_js		5004	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-120706s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-01-07 16:29:03.151522	web_php		5004	ERR	socket_sendto( /var/run/zm/zms-120706s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-01-07 16:28:56.149465	web_js		5004	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-120706s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-01-07 16:28:56.127985	web_php		5004	ERR	socket_sendto( /var/run/zm/zms-120706s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
https://photos.google.com/photo/AF1QipO ... Eqz8Tubzxu
cheers
Re: No browser streaming
Did you upgrade the database? Did you edit the paths?
See: https://wiki.zoneminder.com/Common_Issu ... PA_version
Your PATH_ZMS under Options is incorrect.
If you tell us what distro you are using and how you installed zoneminder, we might be able to tell you what it should be.
Alternatively, if zmninja has a PATH_ZMS variable then just copy that value since it works.
