Ok, it started acting up again last night. Looking at the logs generated when running the test shows this line in the "bad" run that is not present in the "good" run:
May 26 05:53:29 watchman mlapi[2305103]: May 26 2021 05:53:29.135784 [DBG 2] No polygons, adding full image polygon: {'name': 'full_image', 'value': [(0, 0), (1920, 0), (1920, 1080), (0, 1080)], 'pattern': None}
Which, of course, explains *what* is happening (it's looking at the full image, rather than using my ZM defined zones), but not why.
Of course, further down we see the effects of this. In the "good" run we get:
intersection: comparing object:truck,POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) to polygon:driveway-back,POLYGON ((0 602, 1193 562, 1522 833, 1371 1076, 0 1076, 0 602))
intersection: comparing object:truck,POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) to polygon:porch,POLYGON ((1370 707, 1813 521, 1916 574, 1916 615, 1857 750, 1850 759, 1833 785, 1829 752, 1732 656, 1601 809, 1520 830, 1370 707))
intersection: comparing object:truck,POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) to polygon:driveway-front,POLYGON ((2 183, 131 178, 131 161, 680 167, 1188 561, 333 588, 314 232, 0 236, 2 183))
intersection: comparing object:truck,POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) to polygon:fireweed,POLYGON ((1732 656, 1827 746, 1834 761, 1833 785, 1859 748, 1916 1076, 1375 1076, 1521 830, 1600 812, 1732 656))
intersection: comparing object:truck,POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) to polygon:yard,POLYGON ((1262 202, 1814 519, 1372 706, 676 168, 950 193, 1151 377, 1320 322, 1262 202))
intersection: comparing object:truck,POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) to polygon:front_bush1,POLYGON ((949 191, 1255 196, 1320 325, 1151 377, 949 191))
intersection: comparing object:truck,POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) to polygon:side_bushes,POLYGON ((1275 118, 1851 438, 1859 544, 1258 198, 1275 118))
object:truck at POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) does not fall into any polygons, removing...
We did not find any object matches in frame: alarm
Returning {'matched_data': {'boxes': [], 'error_boxes': [], 'labels': [], 'confidences': [], 'frame_id': None, 'model_names': [], 'image_dimensions': {'original': (1080, 1920), 'resized': (1080, 1920)}, 'image': None, 'polygons': [{'name': 'driveway-back', 'value': [(0, 602), (1193, 562), (1522, 833), (1371, 1076), (0, 1076)], 'pattern': None}, {'name': 'porch', 'value': [(1370, 707), (1813, 521), (1916, 574), (1916, 615), (1857, 750), (1850, 759), (1833, 785), (1829, 752), (1732, 656), (1601, 809), (1520, 830)], 'pattern': None}, {'name': 'driveway-front', 'value': [(2, 183), (131, 178), (131, 161), (680, 167), (1188, 561), (333, 588), (314, 232), (0, 236)], 'pattern': None}, {'name': 'fireweed', 'value': [(1732, 656), (1827, 746), (1834, 761), (1833, 785), (1859, 748), (1916, 1076), (1375, 1076), (1521, 830), (1600, 812)], 'pattern': None}, {'name': 'yard', 'value': [(1262, 202), (1814, 519), (1372, 706), (676, 168), (950, 193), (1151, 377), (1320, 322)], 'pattern': None}, {'name': 'front_bush1', 'value': [(949, 191), (1255, 196), (1320, 325), (1151, 377)], 'pattern': None}, {'name': 'side_bushes', 'value': [(1275, 118), (1851, 438), (1859, 544), (1258, 198)], 'pattern': None}]}, 'all_matches': []}
while in the bad run it shows (yes, I know my match pattern is bad, I'll need to fix that):
intersection: comparing object:truck,POLYGON ((-2 -1, 396 -1, 396 121, -2 121, -2 -1)) to polygon:full_image,POLYGON ((0 0, 1920 0, 1920 1080, 0 1080, 0 0))
Using global match pattern: ^(?!bird,bench)
full_image intersects object:truck[[(-2, -1), (396, -1), (396, 121), (-2, 121)]]
Returning {'matched_data': {'boxes': [[-2, -1, 396, 121]], 'error_boxes': [], 'labels': ['truck'], 'confidences': [0.5240153074264526], 'frame_id': 'alarm', 'model_names': ['yolo'], 'image_dimensions': {'original': (1080, 1920), 'resized': (1080, 1920)}, 'image': None, 'polygons': [{'name': 'full_image', 'value': [(0, 0), (1920, 0), (1920, 1080), (0, 1080)], 'pattern': None}]}, 'all_matches': [{'frame_id': 'alarm', 'boxes': [[-2, -1, 396, 121]], 'error_boxes': [], 'labels': ['truck'], 'confidences': [0.5240153074264526], 'detection_types': ['object'], 'model_names': ['yolo']}]}
Other than that, and some inconsequential differences (such as lock id's and timings, which would be expected), the two log sections are identical according to a diff. Looking back further, I find this sequence of entries that looks like it may be relevant. I don't see similar entries to the final three lines prior to the good runs:
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.502751 [DBG 1] Monitor ID 3 provided & matching config found in mlapi, ignoring objectconfig.ini
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.502818 [DBG 2] Overriding global ml_sequence with {
May 25 10:05:06 watchman mlapi[484977]: 'general': {
May 25 10:05:06 watchman mlapi[484977]: 'model_sequence...
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.502848 [DBG 2] Overriding global stream_sequence with {
May 25 10:05:06 watchman mlapi[484977]: 'frame_strategy': 'most_mode...
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.502871 [DBG 2] Overriding global object_detection_pattern with ^(?!bird,bench)...
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.502886 [DBG 2] Overriding global model_sequence with object,alpr,face...
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.502900 [DBG 2] Overriding global resize with no...
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.502915 [DBG 2] Only filtering polygon names that have Motion Porch
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.502992 [DBG 2] Original polygons being used: [{'name': 'driveway-back', 'value': [(0, 602), (1193, 562), (1522, 833), (1371, 1076), (0, 1076)], 'pattern': None}, {'n
May 25 10:05:06 watchman mlapi[484977]: May 25 2021 10:05:06.503549 [DBG 2] Final polygons being used: []
POSIT (forgive me if this is nuts): when I restart MLAPI and run the test per the command line shown in the initial post, there is no motion zone specified, so the "only_triggered_zm_zones" option isn't used, instead it simply uses all defined zones and works. Once MLAPI is triggered by an actual motion event, however, such as the above logged "Motion Porch", the "only_triggered_zm_zones" option kicks in, filtering the list of polygons down - but for some reason instead of being left with only the "Porch" polygon, I'm left with nothing, leading to the "No Polygons" issue. Additionally - and crucially - after this filtering "failure", the original zones are not restored unless I restart MLAPI, meaning that from that point on, all detections are done using the full image polygon.
Like I said, maybe that posit is completely nuts, if so please disregard it. But it *would* seem to be a logical explanation for the behavior I am seeing...
I still need to dig up the zmeventnotification logs (I may need to tweak logging levels or something to get them, as all I'm finding at the moment are ERR and above) and see if it has similar entries.
