I've been having a bizarre issue with ZMNinja for Windows. I have one monitor MICCAM05 that won't snap to grid. They also keep getting disabled every time I navigate away from the Montage view. If I enable them, I can view the monitor without issue. I can expand the monitor, but when I close the expanded view to go back to Montage, the monitor is disabled again. Logs are attached.
Monitor won't snap to grid
Re: Monitor won't snap to grid
Update: This only affects ZMNinja for Windows, My Android instance works as expected, no issues with MICCAM05 being disabled constantly.
I switch between about 5 Windows computers regularly, all running ZMNinja, all experience the same issue with MICCAM05
Was this monitor added after you configured your windows client? If so running wizard again will fix it. It’s a bug in 1.6.008. If not it’s something else.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
That fixed it. Thanks!
