I just want to confirm something
I am assuming that the skin in ZM example: "dark" has no efect on the mobile app
I want to edit my skin.css in ZM to open up some of the text areas wider than is allowed now in the monitor setup window.
Is the app using it own skin for a mobile device ?
Jimmy
Mobile ZM Skin
Mobile ZM Skin
Linux Mint 21 Cinnamon Mariadb 10.6.x using Master 1.37.x latest always
Re: Mobile ZM Skin
If by "app" you mean zmNinja, then it's completely unrelated to the web portal of ZM. zmNinja only uses ZM APIs and implements its own UI and application logic.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Re: Mobile ZM Skin
zmNinja Yes
Ok great
Thank You
Jimmy
Ok great
Thank You
Jimmy
