ES 6.0: Coming soon and breaking changes
Discussion topics related to mobile applications for ZoneMinder
asker
Post by asker » Sat Aug 15, 2020 4:43 pm
Folks, ES 6.0 will be out soon.
Please read https://medium.com/zmninja/es-6-0-and-l ... c91b5b7137
If you want, you can update to master and start preparing. Specifically, don't just upgrade and expect things to work. Please read the post above.
Please don't ask me questions via PM. Feel free to post in the forums or Github
Re: ES 6.0: Coming soon and breaking changes
Post by Magic919 » Sun Aug 16, 2020 6:07 am
The ride might be a bit bumpy, but it’s a great journey. Thanks for all your work on this.
Post by Magic919 » Fri Sep 04, 2020 3:02 pm
I presume some others have done the upgrade already. Did mine today.
Only thing of note is the config migration script doesn't discriminate, so all instances of the word 'models' will become 'detection_sequence', even if if it's the path on the filesystem. 'weights' and 'object_weights' will do the same and need some pruning. I also got duplicates cpu_max_* parts of the configs. It's a good starting point and the logs will point you in the right direction.
Thanks.
asker
Post by asker » Fri Sep 04, 2020 6:24 pm
good catch. I pushed a change in config_upgrade.py to fix this indiscriminate change. If you have a copy of the old config, just run
python ./hook/config_upgrade.py -c ./old.ini -o new.ini
My guess about duplicate entries is that will only happen if you previously added those attributes on your own.
Let me know what you see.
Post by Magic919 » Sat Sep 05, 2020 1:50 pm
That's cleaned it up, cheers.
I think the duplications must have been me running the install twice. I do this as my zm install uses /usr/local/bin (if I don't change install.sh). Would be very handy if it read and matched the path from zm.conf.
asker
Post by asker » Sat Sep 05, 2020 3:10 pm
Ok good. If you run the install twice (i.e. migrate once and install using the migrated config), the 2nd time it should tell you "nothing to migrate" (I hope).
Post by Magic919 » Sun Sep 06, 2020 11:04 am
Try this
zmeventnotification/hook/config_upgrade.py -c zmeventnotification/hook/objectconfig.ini -o test.ini
I think I must have got the new configs, but no version number and that leads to duplicates when I try it -
cpu_max_processes=3
cpu_max_lock_wait=120
cpu_max_processes=3
face_detection_framework=dlib
face_recognition_framework=dlib
asker
Post by asker » Sun Sep 06, 2020 11:48 am
That's odd. It should always add a "version=" element after updating, if it doesn't exist.
Could you email me your original ini file before upgrade? pliablepixels at gmail.
Post by Magic919 » Sun Sep 06, 2020 12:19 pm
I don’t think it’s anything to do with my config. I think it did the upgrade, backed up my ini file and wrote a new one, but with no version. Then it ran the config upgrade on that.
Ideally there shouldn’t be any copies of the new version config that don’t have a version line, but that one I previously referenced is such a file.
asker
Post by asker » Sun Sep 06, 2020 12:43 pm
When it upgrades a pre config file it should add a version= line in [general]. If it did not, there would be no way for it to upgrade to the next version. When I upgrade my old config, I see version in the migrated file.
Post by Magic919 » Mon Sep 07, 2020 6:53 am
I've just run this upgrade on one of my spare servers (unconfigured zme) and it creates migrated-objectconfig.ini in the directory it's run from and that has the duplicates.
asker
Post by asker » Mon Sep 07, 2020 10:46 am
1. Which version did you upgrade from
2. Did the original have version?
3. Did the migrated one have version?
4. Duplicates of which keys? Did the original have them?
asker
Post by asker » Mon Sep 07, 2020 12:00 pm
Okay, the template objectconfig.ini in master did not have a version attribute. I just updated it. That means if you download master, it should not upgrade that ini and say "nothing to upgrade" now.
Post by Magic919 » Mon Sep 07, 2020 12:21 pm
That's the one in the repo under hook/ presumably.
When I re-run the command on it that I did earlier in this thread
I now get
Current version of objectconfig.ini is 1.0
Nothing to migrate
Perfect.
Thanks for all your effort on this and ZMNinja.
asker
Post by asker » Mon Sep 07, 2020 9:54 pm
No problem. Thanks for proactively reporting your experiences.
