I upgrading my router with the same ports open as before but I no longer get object detected and therefore no notifications. I see these errors in my log and a lot of end events that are ignored because there was no start event. Zoneminder, ZMNijna works as before, so if the router change caused this what could it be?
==> /var/log/zm/zmesdetect_m8.log <==
'_open', req)
File "/usr/lib/python3.6/urllib/request.py", line 504, in _call_chain
result = func(*args)
File "/usr/lib/python3.6/urllib/request.py", line 1368, in https_open
context=self._context, check_hostname=self._check_hostname)
File "/usr/lib/python3.6/urllib/request.py", line 1327, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 110] Connection timed out>
08/08/20 12:02:47 zmesdetect_m8[13389] INF detect.py:60 [---------| app version: 5.13.3 |------------]
end events but no start events
Re: end events but no start events
This error means the ES is no longer able to reach the ZM url to download images. Check firewalls or routes.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
You are right on, I needed to add the local IP address to the hosts file, why the old router didn’t need this and the new one does I have know clue
