zmeventnotification.pl: connect: Connection refused
Discussion topics related to mobile applications for ZoneMinder
Kilonga
Post by Kilonga » Tue Jun 23, 2020 2:28 pm
I have zoneminder working propertly and wanted to use zmNinja with it with notifications. I followed the instructions to install and configure zmeventnotification and when running it I get the following error and cannot find what is causing it:
06/23/2020 10:24:57.032589 zmeventnotification[11503].INF [main:881] [PARENT: using config file: /etc/zm/zmeventnotification.ini]
06/23/2020 10:24:57.049419 zmeventnotification[11503].INF [main:881] [PARENT: using secrets file: /etc/zm/secrets.ini]
06/23/2020 10:24:57.187602 zmeventnotification[11503].INF [main:881] [PARENT: Push enabled via FCM]
06/23/2020 10:24:57.218382 zmeventnotification[11503].INF [main:881] [PARENT: MQTT Enabled]
06/23/2020 10:24:57.275316 zmeventnotification[11503].INF [main:881] [PARENT: |------- Starting ES version: 5.13 ---------|]
Can't ignore signal CHLD, forcing to default.
06/23/2020 10:24:57.406541 zmeventnotification[11503].INF [main:881] [PARENT: Event Notification daemon v 5.13 starting]
06/23/2020 10:24:57.417083 zmeventnotification[11503].INF [main:881] [PARENT: Initializing MQTT connection...]
06/23/2020 10:24:57.454017 zmeventnotification[11503].INF [main:881] [PARENT: Re-loading monitors]
06/23/2020 10:24:57.492540 zmeventnotification[11503].INF [main:881] [PARENT: Secure WS(WSS) is enabled...]
06/23/2020 10:24:57.527984 zmeventnotification[11503].INF [main:881] [PARENT: Web Socket Event Server listening on port 9000]
/usr/bin/zmeventnotification.pl: connect: Connection refused
This is the output of "--check-config"
06/23/2020 10:27:25.420532 zmeventnotification[11667].INF [main:881] [PARENT: using config file: /etc/zm/zmeventnotification.ini]
06/23/2020 10:27:25.437743 zmeventnotification[11667].INF [main:881] [PARENT: using secrets file: /etc/zm/secrets.ini]
Configuration (read /etc/zm/zmeventnotification.ini):
Secrets file.......................... /etc/zm/secrets.ini
Base data path........................ /var/lib/zmeventnotification
Restart interval (secs)............... (undefined)
Use admin interface .................. yes
Admin interface password.............. (defined)
Admin interface persistence file ..... /var/lib/zmeventnotification/misc/escontrol_interface.dat
Port ................................. 9000
Address .............................. 0.0.0.0
Event check interval ................. 5
Monitor reload interval .............. 300
Skipped monitors...................... (undefined)
Auth enabled ......................... yes
Auth timeout ......................... 20
Use API Push.......................... no
API Push Script....................... (undefined)
Use FCM .............................. yes
FCM Date Format....................... %I:%M %p, %d-%b
FCM API key .......................... (defined)
Token file ........................... /var/lib/zmeventnotification/push/tokens.txt
Use MQTT ............................. yes
MQTT Server .......................... 127.0.0.1
MQTT Username ........................ mqtt_zm
MQTT Password ........................ (defined)
MQTT Retain .......................... no
MQTT Tick Interval ................... 15
SSL enabled .......................... yes
SSL cert file ........................ /etc/letsencrypt/rsa-live/kilonga.net/cert.pem
SSL key file ......................... /etc/letsencrypt/rsa-live/kilonga.net/privkey.pem
Verbose .............................. no
ES Debug level.........................2
Read alarm cause ..................... yes
Tag alarm event id ................... yes
Use custom notification sound ........ no
Send event end notification............yes
Use Hooks............................. yes
Hook Script on Event Start ........... '/var/lib/zmeventnotification/bin/zm_event_start.sh'
Hook Script on Event End.............. '/var/lib/zmeventnotification/bin/zm_event_end.sh'
Hook Skipped monitors................. (undefined)
Notify on Event Start (hook success).. all
Notify on Event Start (hook fail)..... none
Notify on Event End (hook success).... fcm,web,api
Notify on Event End (hook fail)....... none
Notify End only if Start success...... yes
Use Hook Description.................. yes
Keep frame match type................. yes
Store Frame in ZM......................yes
Picture URL .......................... https://kilonga.net/zm/index.php?view=image&eid=EVENTID&fid=objdetect&width=600
Include picture....................... yes
Picture username ..................... admin
Picture password ..................... (defined)
I would appreciate any help you can provide.
Thanks!
asker
Re: zmeventnotification.pl: connect: Connection refused
Post by asker » Tue Jun 23, 2020 6:01 pm
1. make sure multiple instances of the server are not running
2. To start with, don't run it as a daemon, run it manually
3. Enable debug logs for the ES so I get to see debug logs of what is happening when you run it (also make sure you are running it with -u www-data)
Kilonga
Post by Kilonga » Wed Jun 24, 2020 2:39 am
I made sure no other processes are running. No longer running it as daemon. I am still getting the same error. I ran it with -u www-data and logs enabled and this is what I get:
# sudo -u www-data /usr/bin/zmeventnotification.pl
06/23/2020 22:35:52.614206 zmeventnotification[57773].INF [main:881] [PARENT: using config file: /etc/zm/zmeventnotification.ini]
06/23/2020 22:35:52.656851 zmeventnotification[57773].INF [main:881] [PARENT: using secrets file: /etc/zm/secrets.ini]
CONSOLE DBG-2:2020-06-23,22:35:52 PARENT: Got secret token !ZMES_PICTURE_URL
CONSOLE DBG-2:2020-06-23,22:35:52 PARENT: Got secret token !ZM_USER
CONSOLE DBG-2:2020-06-23,22:35:52 PARENT: Got secret token !ZM_PASSWORD
CONSOLE DBG-3:2020-06-23,22:35:52 PARENT: config string substitution: {{base_data_path}} is '/var/lib/zmeventnotification'
Verbose .............................. yes
ES Debug level.........................5
CONSOLE INF:2020-06-23,22:35:52 PARENT: Push enabled via FCM
06/23/2020 22:35:52.833220 zmeventnotification[57773].INF [main:881] [PARENT: Push enabled via FCM]
CONSOLE INF:2020-06-23,22:35:52 PARENT: MQTT Enabled
06/23/2020 22:35:52.849251 zmeventnotification[57773].INF [main:881] [PARENT: MQTT Enabled]
CONSOLE INF:2020-06-23,22:35:52 PARENT: |------- Starting ES version: 5.13 ---------|
06/23/2020 22:35:52.874248 zmeventnotification[57773].INF [main:881] [PARENT: |------- Starting ES version: 5.13 ---------|]
CONSOLE DBG-1:2020-06-23,22:35:52 PARENT: Started with: perl:/usr/bin/perl and command:/usr/bin/zmeventnotification.pl
CONSOLE DBG-1:2020-06-23,22:35:53 PARENT: ES invoked manually. Will handle restarts ourselves
CONSOLE DBG-2:2020-06-23,22:35:53 PARENT: Parent<--Child pipe ready
CONSOLE INF:2020-06-23,22:35:53 PARENT: Event Notification daemon v 5.13 starting
06/23/2020 22:35:53.024811 zmeventnotification[57773].INF [main:881] [PARENT: Event Notification daemon v 5.13 starting]
CONSOLE DBG-1:2020-06-23,22:35:53 PARENT: Initializing FCM tokens...
CONSOLE INF:2020-06-23,22:35:53 PARENT: Initializing MQTT connection...
06/23/2020 22:35:53.045610 zmeventnotification[57773].INF [main:881] [PARENT: Initializing MQTT connection...]
CONSOLE DBG-1:2020-06-23,22:35:53 PARENT: Intialized MQTT with auth
CONSOLE DBG-1:2020-06-23,22:35:53 PARENT: Total event client connections: 1
CONSOLE DBG-1:2020-06-23,22:35:53 PARENT: -->checkNewEvents: Connection 1: ID-> IP->(none) Token->:... Plat: Push:
CONSOLE INF:2020-06-23,22:35:53 PARENT: Re-loading monitors
06/23/2020 22:35:53.072532 zmeventnotification[57773].INF [main:881] [PARENT: Re-loading monitors]
CONSOLE DBG-1:2020-06-23,22:35:53 PARENT: Loading Driveway
CONSOLE DBG-1:2020-06-23,22:35:53 PARENT: Loading Kitchen
CONSOLE DBG-1:2020-06-23,22:35:53 PARENT: ESCONTROL_INTERFACE: Saving admin interfaces to /var/lib/zmeventnotification/misc/escontrol_interface.dat
CONSOLE DBG-2:2020-06-23,22:35:53 PARENT: checkEvents() new events found=0
CONSOLE DBG-2:2020-06-23,22:35:53 PARENT: About to start listening to socket
CONSOLE INF:2020-06-23,22:35:53 PARENT: Secure WS(WSS) is enabled...
06/23/2020 22:35:53.116799 zmeventnotification[57773].INF [main:881] [PARENT: Secure WS(WSS) is enabled...]
CONSOLE INF:2020-06-23,22:35:53 PARENT: Web Socket Event Server listening on port 9000
06/23/2020 22:35:53.134928 zmeventnotification[57773].INF [main:881] [PARENT: Web Socket Event Server listening on port 9000]
CONSOLE DBG-2:2020-06-23,22:35:58 PARENT: ---------->Tick START<--------------
CONSOLE DBG-3:2020-06-23,22:35:58 PARENT: After tick: TOTAL: 1,  ES_CONTROL: 1, FCM+WEB: 0, FCM: 0, WEB: 0, MQTT:1, invalid WEB: 0, PENDING: 0
CONSOLE DBG-2:2020-06-23,22:35:58 PARENT: There are 0 active child forks...
CONSOLE DBG-2:2020-06-23,22:35:58 PARENT: checkEvents() new events found=0
CONSOLE DBG-2:2020-06-23,22:35:58 PARENT: There are 0 new Events to process
CONSOLE DBG-2:2020-06-23,22:35:58 PARENT: ---------->Tick END<--------------
CONSOLE DBG-2:2020-06-23,22:36:03 PARENT: ---------->Tick START<--------------
CONSOLE DBG-3:2020-06-23,22:36:03 PARENT: After tick: TOTAL: 1,  ES_CONTROL: 1, FCM+WEB: 0, FCM: 0, WEB: 0, MQTT:1, invalid WEB: 0, PENDING: 0
CONSOLE DBG-2:2020-06-23,22:36:03 PARENT: There are 0 active child forks...
CONSOLE DBG-2:2020-06-23,22:36:03 PARENT: checkEvents() new events found=0
CONSOLE DBG-2:2020-06-23,22:36:03 PARENT: There are 0 new Events to process
CONSOLE DBG-2:2020-06-23,22:36:03 PARENT: ---------->Tick END<--------------
CONSOLE DBG-2:2020-06-23,22:36:08 PARENT: ---------->Tick START<--------------
CONSOLE DBG-2:2020-06-23,22:36:08 PARENT: MQTT tick interval (15 sec) elapsed.
CONSOLE DBG-3:2020-06-23,22:36:08 PARENT: After tick: TOTAL: 1,  ES_CONTROL: 1, FCM+WEB: 0, FCM: 0, WEB: 0, MQTT:1, invalid WEB: 0, PENDING: 0
CONSOLE DBG-2:2020-06-23,22:36:08 PARENT: There are 0 active child forks...
CONSOLE DBG-2:2020-06-23,22:36:08 PARENT: checkEvents() new events found=0
CONSOLE DBG-2:2020-06-23,22:36:08 PARENT: There are 0 new Events to process
CONSOLE DBG-2:2020-06-23,22:36:08 PARENT: ---------->Tick END<--------------
CONSOLE DBG-2:2020-06-23,22:36:13 PARENT: ---------->Tick START<--------------
CONSOLE DBG-3:2020-06-23,22:36:13 PARENT: After tick: TOTAL: 1,  ES_CONTROL: 1, FCM+WEB: 0, FCM: 0, WEB: 0, MQTT:1, invalid WEB: 0, PENDING: 0
CONSOLE DBG-2:2020-06-23,22:36:13 PARENT: There are 0 active child forks...
CONSOLE DBG-2:2020-06-23,22:36:13 PARENT: checkEvents() new events found=0
CONSOLE DBG-2:2020-06-23,22:36:13 PARENT: There are 0 new Events to process
CONSOLE DBG-2:2020-06-23,22:36:13 PARENT: ---------->Tick END<--------------
Kilonga
Post by Kilonga » Wed Jun 24, 2020 3:06 am
It seems mosquitto had crashed and it couldn't connect. I restarted it and it now seems to work (at least I don't get any more errors). How do I do a quick test to prove it is working?
Kilonga
Post by Kilonga » Wed Jun 24, 2020 11:03 am
Got it to work. It was missing a few python modules. So far I love ZoneMinder and zmNinja.
