Android push notifications not working
Discussion topics related to mobile applications for ZoneMinder
mboze
Post by mboze » Wed Feb 19, 2020 12:16 pm
I have a problem with push notifications on Android device.
I did a fresh install of Debian 10, latest ZM, ES, etc...
I checked the board for a similar problem, and found this thread:
viewtopic.php?t=29019
I checked my logs and everything seems OK:
Feb 19, 2020 11:54:40 AM INFO EventSever: Initializing Websocket with URL wss://xxxx:9000
Feb 19, 2020 11:54:40 AM DEBUG EventSever: Using native websockets...
Feb 19, 2020 11:54:40 AM DEBUG Transitioning state to: app.log with param {}
Feb 19, 2020 11:54:40 AM DEBUG CACHE: found for key: cached_timezone with expiry of:86400s
Feb 19, 2020 11:54:40 AM DEBUG CACHE: cached value for key:cached_timezone is good as 258 <86400
Feb 19, 2020 11:54:40 AM DEBUG Timezone API response is:Europe/Paris
Feb 19, 2020 11:54:40 AM DEBUG Real value of PRIVACY is:0
Feb 19, 2020 11:54:40 AM DEBUG EventSever: WebSocket open called with:{"webSocketId":"039d119e-942f-484a-9f1c-0d5bf92058c4","code":101}
Feb 19, 2020 11:54:40 AM INFO EventSever: openHandshake: Websocket open, sending Auth
Feb 19, 2020 11:54:40 AM DEBUG EventSever: sendMessage: received->{"event":"auth","data":{"user":"admin",<password removed>,"monlist":"1","intlist":"0"}}
Feb 19, 2020 11:54:40 AM DEBUG EventServer: ok to send message
Feb 19, 2020 11:54:40 AM DEBUG EventSever: Initializing FCM push
Feb 19, 2020 11:54:40 AM INFO EventSever: Setting up push registration
Feb 19, 2020 11:54:41 AM DEBUG EventSever: Push Notification registration ID received: {"registrationId":"XXXX","registrationType":"FCM"}
but still nothing on my device (Xiaomi Mi 9)
I modified the push notifications settings on zmninja App on my Phone (all boxes to "on") still nothing
I'm lost :/ :P
Can someone help me? :)
thank you
asker
Re: Android push notifications not working
Post by asker » Wed Feb 19, 2020 5:32 pm
Post logs of the event server when an event occurs.
mboze
Post by mboze » Thu Feb 20, 2020 8:59 am
20/02/2020 09:56:11.811246 zmeventnotification[637].INF [main:836] [PARENT: New event 42 reported for Monitor:1 (Name:cour) Motion All]
20/02/2020 09:56:11.814310 zmeventnotification[637].INF [main:836] [PARENT: There are 1 new Events to process]
20/02/2020 09:56:11.831337 zmeventnotification[756].INF [main:836] [PARENT: Forked process:756 to handle alarm eid:42]
20/02/2020 09:56:11.836910 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 Invoking hook on event start:'/var/lib/zmeventnotification/bin/zm_event_start.sh' 42 1 "cour" "Motion All" "/var/cache/zoneminder/events/1/2020-02-20/42"]
20/02/2020 09:56:16.806402 zmeventnotification[637].INF [main:836] [PARENT: There are 1 active child forks...]
20/02/2020 09:56:16.811370 zmeventnotification[637].INF [main:836] [PARENT: There are 0 new Events to process]
20/02/2020 09:56:21.805263 zmeventnotification[637].INF [main:836] [PARENT: There are 1 active child forks...]
20/02/2020 09:56:21.809641 zmeventnotification[637].INF [main:836] [PARENT: There are 0 new Events to process]
20/02/2020 09:56:26.685315 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 hook start returned with text: json:[] exit:1]
20/02/2020 09:56:26.688575 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 Event 42 for Monitor 1 has finished]
20/02/2020 09:56:26.806205 zmeventnotification[637].INF [main:836] [PARENT: There are 1 active child forks...]
20/02/2020 09:56:26.809396 zmeventnotification[637].INF [main:836] [PARENT: There are 0 new Events to process]
20/02/2020 09:56:28.691368 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 Matching alarm to connection rules...]
20/02/2020 09:56:28.696600 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 Checking alarm rules for token ending in:...Bxc5SUbW1X]
20/02/2020 09:56:28.699012 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 Monitor 1 event: should send out as 309.280100107193 is >= interval of 0]
20/02/2020 09:56:30.709297 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 Invoking hook on event end:'/var/lib/zmeventnotification/bin/zm_event_end.sh' 42 1 "cour" "Motion: All" "/var/cache/zoneminder/events/1/2020-02-20/42"]
20/02/2020 09:56:30.720725 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 hook end returned with text:Motion: All json:[] exit:0]
20/02/2020 09:56:31.809209 zmeventnotification[637].INF [main:836] [PARENT: There are 1 active child forks...]
20/02/2020 09:56:31.813369 zmeventnotification[637].INF [main:836] [PARENT: There are 0 new Events to process]
20/02/2020 09:56:32.724022 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 Not sending event end alarm, as we did not send a start alarm for this, or start hook processing failed]
20/02/2020 09:56:36.728073 zmeventnotification[756].INF [main:836] [|----> FORK:cour (1), eid:42 Ending process:756 to handle alarms]
20/02/2020 09:56:36.806723 zmeventnotification[637].INF [main:836] [PARENT: There are 0 active child forks...]
20/02/2020 09:56:36.809983 zmeventnotification[637].INF [main:836] [PARENT: There are 0 new Events to process]
mboze
Post by mboze » Thu Feb 20, 2020 1:28 pm
OK, I got it :D
I modified tokens.txt and replaced at the end disabled by enabled
and now, everthing is OK
Sorry for the inconvenience
asker
Post by asker » Thu Feb 20, 2020 1:32 pm
OK, I got it :D
You should also do this through zmNinja otherwise it may get disabled again. zmNinja->Menu->Settings->Event server settings. Make sure the monitors are enabled.
mboze
Post by mboze » Thu Feb 20, 2020 1:54 pm
I was too hurry, tokens.txt fall back to disabled...
edit:
[/quote]
[/quote]
didn't see your reply
ok, I'll check this, thx
