Event notification
Re: Event notification
Logs say version 4.7 but also restarting in 10800 seconds perhaps I grabbed the wrong one?
No that’s fine. That is 3 hrs. Does it restart? You can just change the restart value in the config file and check.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
No it didn’t, but I will have a close look at the logs tomorrow and let you. I was getting some smearing so I just manually restarted it
Ok it is restarting every three hours, but oddly it seems to be restarting after a notification is sent as well. So when nothing was triggering alarms all night every three hours, and since daylight after notifications were sent. 12 times since I started monitoring around 7:00 pm yesterday to 10:00 this morning
I can’t think of why it would restart at each notification. I’d like to see debug logs.
ES docs
zmNinja docs
ES docs
zmNinja docs
Do you want logs other than zmeventnotification.log. And do I post them here?
Just event notification. But debug logs please of when it restarts at each notification. You can email them to pliablepixels at gmail.
ES docs
zmNinja docs
ES docs
zmNinja docs
So I just re-read the section on setting up logging and didn't have it setup correctly, if I notice it happening again I will be able to send a debug log. I could of just been seeing duplicates from the console log.
Sounds good. I was about to post on to enable debug logs please also make sure you only have one ES running.
ES docs
zmNinja docs
ES docs
zmNinja docs
