Page 1 of 1
IoS replacement for Tiny Cam Pro?
Posted: Thu Aug 22, 2019 2:05 pm
by pgrunwald
I just moved from Android to IoS. Running 5 cameras on a Debian Server with 1.32.3, I was happy with Tiny Cam Pro (paid version) on Android. What is a good equivalent on IoS?
Thanks,
Paul
Re: IoS replacement for Tiny Cam Pro?
Posted: Thu Aug 22, 2019 2:23 pm
by asker
TinyCam pro works directly with cameras (in addition to routing through ZM).
If you are looking for a replacement app look around in this forum. There are two apps, really, at this stage:
a) zmNinja (I am the author)
b) Surveillance Pro
zmNinja doesn't work directly with cameras. It only works with ZM.
No idea about Surveillance Pro
Posted: Thu Aug 22, 2019 2:36 pm
by pgrunwald
Thanks, I would not mind trying ZmNinja but I'm at 1.32.3 atm. Is there a trial or test? I don't mind paying if it works.
Posted: Thu Aug 22, 2019 3:52 pm
by asker
Posted: Thu Aug 22, 2019 5:01 pm
by pgrunwald
Thank you - The windows desktop version seems to be working. I will try and build the IoS version as I'm running the 13 beta.
