Event Notification detect.py Segfault
Discussion topics related to mobile applications for ZoneMinder
n8091977
Post by n8091977 » Wed Aug 14, 2019 3:03 pm
I have installed Zoneminder 1.32.3 from clean install.
I have managed to get Event Notification working and pushes to my phone are working as expected. I have now got this running as a daemon.
I then moved onto Machine Learning Hooks and now have 2 issues:
- I have a Segfault that I am trying to debug
Aug 14 15:51:18 cctv kernel: [ 137.144893] detect.py[1527]: segfault at 2260 ip 0000000000002260 sp 00007ffd83dca228 error 14 in python3.5[400000+3aa000]
- Second issue is I can not get the debug logs working correctly for _zmesdetect
Not really sure where to go from here without been able to get debugging working, everything else looks great.
asker
Re: Event Notification detect.py Segfault
Post by asker » Thu Aug 15, 2019 3:48 pm
This generally means you have some form of library conflict - maybe OpenCV (or maybe you are mixing python paths?)
n8091977
Post by n8091977 » Fri Aug 16, 2019 6:20 pm
Thanks for the hint, it was a combination of Python paths and a load of dependencies. Installing manually and reading the output has made for a successful install.
I just have one last issue that zmeventnotification can't write back to zoneminder to show the object it identified. Permissions seem fine.
Aug 16 18:56:54 cctv /detect.py[27595]: ERR [zmesdetect_m5] [Could not write image to ZoneMinder as eventpath not present]
Aug 16 18:56:54 cctv /detect.py[27595]: INF [zmesdetect_m5] [Prediction string:[a] detected:person:79% ]
Aug 16 18:56:54 cctv zmeventnotification[27567]: INF [For Monitor:5 event:597, hook script returned with text:[a] detected:person:79% exit:0]
Aug 16 18:56:54 cctv zmeventnotification[27567]: INF [Matching alarm to connection rules...]
Aug 16 18:56:54 cctv zmeventnotification[27567]: INF [Checking alarm rules for token ending in:...6H5-wAyMQC]
Aug 16 18:56:54 cctv zmeventnotification[27567]: INF [should NOT send alarm as Monitor 5 is excluded]
Aug 16 18:56:54 cctv zmeventnotification[27567]: INF [Checking alarm rules for token ending in:...jNrCutWqEj]
Aug 16 18:56:54 cctv zmeventnotification[27567]: INF [Monitor 5 event: last time not found, so should send]
Aug 16 18:56:54 cctv zmeventnotification[27567]: INF [Sending notification over FCM]
asker
Post by asker » Fri Aug 16, 2019 9:59 pm
Glad you got it working.
The reason that is not working is you are on ZM 1.32.3. It requires 1.33.x (see comments)
n8091977
Post by n8091977 » Sat Aug 17, 2019 8:05 am
Sorry should have said I had upgraded to 1.33.14
n8091977
Post by n8091977 » Sat Aug 17, 2019 6:07 pm
All working now, had to set hook_pass_image_path variable.
What an awesome addition to zoneminder that I've been using for 6 years!
asker
Post by asker » Sun Aug 18, 2019 8:19 pm
Glad you like it!
