surveillance pro
McTechSolutions
surveillance pro
Post by McTechSolutions »
Guys.
I have just spun up ZM and looking to migrate from Blue Iris. So far i am liking ZM and seems so far more straight forward than BI.
Anyway, I have connected surveillance pro to ZM and actually i like the app and will purchase it. However i am only running the single camera trial. Is surveillance pro just a viewer or is the ability to actually go back over the last hours recording?
Thanks in advance.
Re: surveillance pro
I don't know anything about surveillance pro, but you could look into zmNinja at your app store.
zmNinjapro can review events and control the cameras through zoneminder. there is a desktop version for free to check it out.
http://pliablepixels.github.io/
https://github.com/pliablepixels/zmNinja/releases
Moved to the mobile apps forum....
