Any free app for android for ZM 1.32?
Discussion topics related to mobile applications for ZoneMinder
tra
Post by tra » Thu Oct 04, 2018 1:21 pm
Is there any free mobile app for android? zmView stopped working for me after upgrading to 1.32.
Then I removed it to reinstall, but I can not find it any more from Google Play.
Can be very simple, I just use it sometimes, not often for checking what's going on and also tuning camera for example when it is located very high, climbing on ladder with phone is much easier than with laptop ;)
asker
Re: Any free app for android for ZM 1.32?
Post by asker » Thu Oct 04, 2018 7:44 pm
You may want to reach out to the zmview developers. Their app is still in the IOS store.
rangerbob
Post by rangerbob » Sun May 05, 2019 3:06 pm
in IPcam Viewer .. or any app program that supports generic settings
IP cam Viewer and the similar android apps have a
Make: Generic URL
and Model
Generic URL (e.g. http://x.com/image.jpg
I entered
http://XXX.XXX.XXX.XXX:80/zm/cgi-bin/nph-zms?width=960px&height=540px&scale=50&mode=jpeg&maxfps=5&monitor=1&user=USERNAMEHERE&pass=PASSWORDHERE
Then entered the user and password again at the fields and it seems to work.
Plus with the URL I can force it to use less frames per second (maxfps=5)
I just opened a cam up and copied the image url with firefox and removed the ending to add my user pass at the end you can decode the url
rangerbob
Post by rangerbob » Sun May 05, 2019 3:10 pm
You could also just post it as a single image
Here is a example from a 1.32 build
http://XXX.XXX.XXX.XXX:80/zm/cgi-bin/nph-zms?&mode=single&monitor=1&user=USERNAMEHERE&pass=PASSWORDHERE
