Machine Learning powered object detection support in event notification server
Discussion topics related to mobile applications for ZoneMinder
asker
Post by asker » Wed Oct 03, 2018 7:04 pm
I just released 1.5 of the event notification server that lets you insert custom hook scripts before alarms are sent out. I've also provided a near realtime example of how people detection can be achieved for events that are detected by ZM and before the notification gets sent out to you.
Brief description: here
Longer description: here
Sample:
asker
Re: hook support in event notification server (sample person detection hook added)
Post by asker » Sat Oct 06, 2018 10:11 pm
I've now added 2 different detectors:
a) the first one is fast and uses HOG. Image was above
b) A second one that uses DNN and YoloV3 and is slower but more accurate. Like so:
And also:
asker
Post by asker » Wed Oct 10, 2018 12:51 pm
I just fixed an important bug last night.
As it turns out if alarms are generated the same time as another monitor dies, the alarm doesn't get caught.
Please make sure you are on version 2.0 and updated on Oct 10, 2018 (US tz) (I made some changes without bumping the version)
asker
Post by asker » Tue Oct 16, 2018 4:51 pm
The detection text is now written into the ZM DB as well and there is a new commit to master today, so your console will look like this:
nrbell
Post by nrbell » Fri Nov 16, 2018 8:08 pm
Thanks so much for implementing this! I just set this up last night and it works great.
asker
Post by asker » Sat Nov 24, 2018 12:56 am
Nice! I'm always happy to see users get this working successfully.
asker
Post by asker » Sun Nov 25, 2018 12:54 am
The next version of zmNinja will allow an option to only view events that have detected objects.
asker
Post by asker » Mon Dec 24, 2018 1:30 pm
The updated scripts now support the following:
- "bestmatch" as a value for "FID" -> This will try to analyze the first alarmed frame for objects and if it fails, it will analyze the frame with the highest score. Both these comparisons will be done in the same run instance, so the model won't have to be loaded twice (faster than manually calling the script twice as model load is slow).
- better installation instructions
https://github.com/pliablepixels/zmeven ... ok_example
Users browsing this forum: No registered users and 11 guests
