zmeventserver forced web event message is stuck
Discussion topics related to mobile applications for ZoneMinder
Jay
Post by Jay » Tue Jul 24, 2018 10:17 pm
So, I manually started recording the other day on my zoneminder web interface. I received the zmevent notification like I should have with “Forced Web” in the notification. The issue that I am having now is that EVERY event now states “Forced Web”, even if it was a motion event that triggered it.
I’m assuming I need to look in the zmeventserver file for the section that labels the notification and see what is failing. Otherwise, does anyone have any suggestions?
No, I didn’t put my logs in here. I honestly haven’t had time to fool with this yet. I am just wondering if someone has ran across this before.
Thanks!
Jay
Re: zmeventserver forced web event message is stuck
Post by Jay » Mon Jul 30, 2018 5:18 pm
So, long and short, after going through the code, looking at what was stored on Google's side, the local MySql server, I came to the conclusion after restarting the server that restarting ZoneMinder fixes the issue. HAH I haven't had time to look into what is actually causing the issue, but ZoneMinder is storing the event correctly. It has something to do with the translation between Google and the event server. Something must be getting cached and not updating.
asker
Post by asker » Tue Jul 31, 2018 2:15 pm
Which part of the code did you go through? What was your analysis?
1. This part of the code reads the value of a "shared memory" field called alarm_cause.
2. This part of the code assigns a value that zmeventserver uses depending on whether trigger cause or alarm cause is set.
What might be happening is,
1. Even if ZM is working fine, the "alarm_cause" is not reset. If so, its a problem in ZM's code of that part
2. The 2nd line where I try to align them is wrong.
Run zmeventserver in manual mode and print the values of both on console.
Jay
Post by Jay » Tue Jul 31, 2018 2:27 pm
Honestly, I really didn't look hard enough to analyze the code. Don't get me wrong, I am by no means saying anything about the code. When I was looking through it, it was around 0100 in the morning so, I was tired. I didn't get a chance to compare the code that ZoneMinder uses to put labels on the events on the web interface to the code that the zmeventserver uses to send the notifications. I honestly fell asleep at the desk while looking. I was going to see if that code that is used on the web interface is asking for the same information that is being sent with the notification. I ended up having to reset ZoneMinder to make the new location for ffmpeg to take affect and noticed that it was working again. I will see if I can duplicate the issue as soon as possible. I am sure that you, as well as many others, are in the same boat as I am and have little time to program outside of your career. Thanks for replying.
asker
Post by asker » Tue Jul 31, 2018 3:11 pm
Oh, I think I misrepresented my tone. I meant to encourage you to post your findings.
The two lines I pointed to may be the problem areas which may need fixing.
Jay
Post by Jay » Tue Jul 31, 2018 3:17 pm
That is the bad thing about forums... I took you wrong. Sorry! I know a LOT of programmers that get upset when you talk about their code. LOL
