ZMNinja 1.3.003 IOS Three Green Dots
Discussion topics related to mobile applications for ZoneMinder
Post by Magic919 » Sun Jun 03, 2018 8:01 pm
Since today’s update on IOS I get three green dots instead of images. I can throw away the app and relaunch and it works. I can go into settings, make no changes and hit save and also get images back.
I’m on zm 1.30.4 and haven’t made changes there.
Any ideas?
asker
Re: ZMNinja 1.3 IOS Three Green Dots
Post by asker » Sun Jun 03, 2018 9:02 pm
1. Did you happen to email me as well? Someone else emailed me about it
2. Do you use auth?
3. After you go to settings and save and get the images back, do they go away again when you restart?
asker
Post by asker » Sun Jun 03, 2018 9:32 pm
Okay, found an error:
1. If you don't have auth enabled in ZM
2. But you have auth enabled in zmNinja
this problem occurs.
I'll be pushing a fix, but in the mean time, if 1 is true for you, remove auth in zmNinja and try
Post by Magic919 » Mon Jun 04, 2018 6:18 am
2. Do you use auth?
Yes.
No.
Yes.
Post by Magic919 » Mon Jun 04, 2018 6:19 am
I don't have ZM auth or basic auth selected in zmNinja on any of the devices.
asker
Re: ZMNinja 1.3.003 IOS Three Green Dots
Post by asker » Mon Jun 04, 2018 10:29 am
Please give 1.3.004 a try.
Post by Magic919 » Mon Jun 04, 2018 12:48 pm
First launch it works.
Open it again and get 3 dots.
Throw away, then it works.
Save unchanged settings and it also works.
asker
Post by asker » Mon Jun 04, 2018 12:49 pm
Thanks - I'm not sure I understood the throw away part.
Does 1.3.004 fix all issues or is there still something that doesn't work?
Post by Magic919 » Mon Jun 04, 2018 1:30 pm
Throw it away is how to close the app on an IOS device.
It's as broken as before, but now works on first launch and then breaks on second open. This is just the reverse of before.
asker
Post by asker » Mon Jun 04, 2018 1:34 pm
Can you download a desktop version at https://github.com/pliablepixels/zmNinja/releases and see if the same behavior persists on desktop versions too?
Post by Magic919 » Mon Jun 04, 2018 2:01 pm
I'll give that a go when I get home and let you know.
Post by Magic919 » Tue Jun 05, 2018 11:08 am
The Mac desktop client is fine and works perfecly.
Have replied to your email.
asker
Post by asker » Tue Jun 05, 2018 1:48 pm
Problem found and fixed. Will push an update soon.
Post by Magic919 » Tue Jun 05, 2018 2:19 pm
Can't fault your speed of reponse! Thanks
asker
Post by asker » Wed Jun 06, 2018 12:16 am
Please let me know if 1.3.005 fixes the issue
