Page 1 of 2
ZmNinja recently stopped working after android update (Chrome issue)
Posted: Fri Jun 30, 2017 2:44 pm
by MJN
(edited by asker - subject line changed to state its a Chrome issue after update, so people can come here if they face the same problem)
Judging by ZmNinja's FAQ I fear this issue may quite rightly be met by the developer with thoughts of 'here we go again!' so I thought I'd post here to share what my situation is in case I am still missing something obvious despite the FAQ pointers.
ZmNinja has worked well for me for a long time however recently (some time in the last few weeks?) whilst I can connect to my server, displayer the list of events etc, I cannot view any video - I am instead greeted with the red-question-mark-in-a-camera image.
The FAQ suggests this is likely an API issue however I am seeing what I am taking to be a positive indication that these are okay from <server>/api/host/getVersion.json:
{"version":"1.30.4","apiversion":"1.0"}
The FAQ also mentions following the distro's upgrade instructions correctly but I am using Isaac Connor's PPA (ZM version 1.30.4-xenial1 for Ubuntu 16.04) and the original installation was done along these instructions. Neither provides information regarding upgrading as far as I can tell.
Finally the FAQ makes reference to php5-apc however this (well, php-apc) is installed but I don't recall ever doing anything with/to it - do I need to?
Does anyone have any ideas what might be amiss?
Re: ZmNinja recently stopped working
Posted: Sat Jul 01, 2017 3:10 am
by rockedge
I believe your problem with the API is that your Apache server needs to be configured so that the module php-apcu is enabled.
If you think the module is there and enabled then restart Apache and try zmNinja again. This could work for you.
Posted: Sat Jul 01, 2017 12:04 pm
by MJN
Do you know how I can enable the php-apcu module?
I tried phpenmod apcu bu to no avail - this could well be the wrong way to do it though. I can also confirm I do have a /etc/php/7.0/apache2/conf.d/20-apcu.ini file (containing extension=apcu.so) which I think means the module would be loaded?
Posted: Sat Jul 01, 2017 2:02 pm
by asker
(I've moved your original post to the mobile app forum, as it had a response, and deleted the second one you posted)
You haven't provided any logs, so its hard to tell.
Questions:
1. Which zmNinja version & for which OS?
There could be several reasons:
1. As rockedge mentioned above, it might be a 1.30.4 upgrade issue, related to `php-ac` - I haven't upgraded to 1.30.4 yet, so can't help you with specifics, but folks in this forum can
2. If you are on Android and your Chrome recently got updated to Chrome 59 or more and you are using basic authentication, image view will break - Chrome added a bug and that broke this function - they are apparently going to fix this in the next release (this was recently discovered by a zmN user)
Logs:
1. Check zmNinja logs in the app when you are trying to access images
2. Check ZM and apache error logs at that time too - this often gives clues
Posted: Sat Jul 01, 2017 5:19 pm
by MJN
Thanks for your input Asker, and of course cleaning up after me in the forum!
I am using zmNinja v1.2.41 on Android. My logs for the same time period - attempting a montage view on zmNinja - are as follows:
zmNinja log (with debug enabled):
Jul 1, 2017 05:58 PM DEBUG MontageCtrl: onpause called
Jul 1, 2017 05:58 PM INFO Cancelling zmAutologin timer
Jul 1, 2017 05:58 PM INFO user exited app
Jul 1, 2017 05:58 PM INFO ROOT APP: Stopping network pull...
Jul 1, 2017 05:58 PM INFO ROOT APP:App is going into background
Jul 1, 2017 05:58 PM DEBUG Modal is closed, so toggling or exiting
Jul 1, 2017 05:58 PM DEBUG doing the jiggle and dance...
Jul 1, 2017 05:58 PM DEBUG All images loaded
Jul 1, 2017 05:58 PM DEBUG ~~loaded image is loaded for file:///android_asset/www/img/novideo.png
Jul 1, 2017 05:58 PM INFO Whoops!! Monitors have changed. I'm resetting layouts, sorry!
Jul 1, 2017 05:58 PM INFO Monitors that are active and not DOM hidden: 8 while grid has 7
Jul 1, 2017 05:58 PM INFO found a packery layout
Jul 1, 2017 05:58 PM INFO Stream authentication construction: &user=admin<password removed>
Jul 1, 2017 05:58 PM INFO DataModel: Found simple stream auth mode (user=)
Jul 1, 2017 05:58 PM INFO DataModel: Did not find a stream auth key, looking for user=
Jul 1, 2017 05:58 PM DEBUG DataModel: Getting auth from https://<server>/index.php?view=watch&mid=2&connkey=499579 with mid=2
Jul 1, 2017 05:58 PM INFO Inside Montage Ctrl:We found 9 monitors
Jul 1, 2017 05:58 PM DEBUG skipping image refresh, packery is still loading
Jul 1, 2017 05:58 PM DEBUG bandwidth: highbw montage refresh set to: 2
Jul 1, 2017 05:58 PM DEBUG Setting image mode to snapshot, will change to image when packery is all done
Jul 1, 2017 05:58 PM DEBUG DataModel: Setting MID:10 to show
Jul 1, 2017 05:58 PM DEBUG DataModel: Setting MID:9 to show
Jul 1, 2017 05:58 PM DEBUG DataModel: Setting MID:6 to show
Jul 1, 2017 05:58 PM DEBUG DataModel: Setting MID:5 to show
Jul 1, 2017 05:58 PM DEBUG DataModel: Setting MID:3 to show
Jul 1, 2017 05:58 PM DEBUG DataModel: Setting MID:1 to show
Jul 1, 2017 05:58 PM DEBUG DataModel: Setting MID:2 to show
Jul 1, 2017 05:58 PM DEBUG Loading hidden/unhidden status for profile:
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 12 will use fid for direct image access
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 10 will use fid for direct image access
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 9 will use fid for direct image access
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 6 will use fid for direct image access
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 4 will use fid for direct image access
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 5 will use fid for direct image access
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 3 will use fid for direct image access
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 1 will use fid for direct image access
Jul 1, 2017 05:58 PM DEBUG API 1.30.4: Monitor 2 will use fid for direct image access
Jul 1, 2017 05:58 PM INFO multi server list loaded{"servers":[]}
Jul 1, 2017 05:58 PM INFO Monitor load was successful, loaded 9 monitors
Jul 1, 2017 05:58 PM DEBUG Now trying to get multi-server data, if present
Jul 1, 2017 05:58 PM DEBUG Timezone API response is:Europe/London
Jul 1, 2017 05:58 PM INFO ZM_EVENT_IMAGE_DIGITS is 3
Jul 1, 2017 05:58 PM INFO getMonitors:Loading all monitors
Jul 1, 2017 05:58 PM DEBUG Transitioning state to: montage with param undefined
Jul 1, 2017 05:58 PM DEBUG logging state transition
Jul 1, 2017 05:58 PM INFO No Event Server configured, skipping refresh
Jul 1, 2017 05:58 PM INFO First invocation of TimeZone, asking server
Jul 1, 2017 05:58 PM DEBUG Config URL for digits is:https://<server>/api/configs/viewByName/ZM_EVENT_IMAGE_DIGITS.json
Jul 1, 2017 05:58 PM INFO Got API version: 1.30.4
Jul 1, 2017 05:58 PM INFO ZM has recaptcha disabled - good
Jul 1, 2017 05:58 PM DEBUG getAPIversion called
Jul 1, 2017 05:58 PM DEBUG PortalLogin: auth success
Jul 1, 2017 05:58 PM DEBUG Storing login time as Sat Jul 01 2017 17:58:29 GMT+0100
Jul 1, 2017 05:58 PM INFO Deferring auth key, as monitorId unknown
Jul 1, 2017 05:58 PM DEBUG auth-success emit:Successful
Jul 1, 2017 05:58 PM INFO zmAutologin successfully logged into Zoneminder
Jul 1, 2017 05:58 PM INFO Checking if reCaptcha is enabled in ZM...
Jul 1, 2017 05:58 PM INFO zmAutologin called
Jul 1, 2017 05:58 PM DEBUG Resetting zmCookie...
Jul 1, 2017 05:58 PM DEBUG PIN code entered is correct, or there is no PIN set
Jul 1, 2017 05:58 PM DEBUG unlock called with check PIN=false
Jul 1, 2017 05:58 PM INFO not checking for touchID
Jul 1, 2017 05:58 PM INFO User credentials are provided
Jul 1, 2017 05:58 PM DEBUG Inside Portal login Enter handler
Jul 1, 2017 05:58 PM DEBUG current version: 1.2.41 & available version 1.2.41
Jul 1, 2017 05:58 PM DEBUG Not changing bandwidth state, as auto change is not on
Jul 1, 2017 05:58 PM DEBUG getBandwidth() normalized it as: highbw
Jul 1, 2017 05:58 PM DEBUG Detected network type as: wifi
Jul 1, 2017 05:58 PM INFO Entering Portal Main
Jul 1, 2017 05:58 PM DEBUG Latest post dated 2017-02-25 13:54:24 but you read 2017-02-25 13:54:24
Jul 1, 2017 05:58 PM INFO >>>>>>>>>>>>>>> All init over, going to portal login
Jul 1, 2017 05:58 PM INFO >>>> Disabling strict SSL checking (turn off in Dev Options if you can't connect)
Jul 1, 2017 05:58 PM INFO DataModel init recovered this loginData as {"serverName":"Rugrat","username":"admin",<password removed>,"url":"https://<server>","apiurl":"https://<server>/api","eventServer":"wss://<server>","maxMontage":"10","streamingurl":"https://<server>/cgi-bin","maxFPS":"3","montageQuality":100,"singleImageQuality":"100","useSSL":true,"keepAwake":true,"isUseAuth":true,"isUseEventServer":false,"disablePush":false,"eventServerMonitors":"2,1,3,5,4,6,9,10,11","eventServerInterval":"0,0,0,0,0,0,0,0,0","refreshSec":"2","enableDebug":true,"usePin":true,"pinCode":"3576","canSwipeMonitors":true,"persistMontageOrder":true,"onTapScreen":"Montage","enableh264":true,"gapless":true,"montageOrder":"","montageHiddenOrder":"","montageArraySize":"0","graphSize":200,"minAlarmCount":"1","montageSize":"3","useNphZms":true,"packMontage":false,"exitOnSleep":true,"forceNetworkStop":false,"defaultPushSound":false,"enableBlog":false,"useNphZmsForEvents":true,"packeryPositions":"[{\"attr\":\"2\",\"size\":\"50\",\"display\":\"show\",\"x\":0},{\"attr\":\"1\",\"size\":\"50\",\"display\":\"show\",\"x\":0.49987760416666666},{\"attr\":\"3\",\"size\":\"50\",\"display\":\"show\",\"x\":0},{\"attr\":\"5\",\"size\":\"50\",\"display\":\"show\",\"x\":0.49987760416666666},{\"attr\":\"6\",\"size\":\"50\",\"display\":\"show\",\"x\":0},{\"attr\":\"9\",\"size\":\"50\",\"display\":\"show\",\"x\":0.49987760416666666},{\"attr\":\"10\",\"size\":\"50\",\"display\":\"show\",\"x\":0}]","packerySizes":"","use24hr":true,"timelineModalGraphType":"all","montageHistoryQuality":"50","enableAlarmCount":false,"forceImageModePath":false,"reachability":true,"enableLogs":true,"packeryPositionsArray":{},"EHpackeryPositions":"","resumeDelay":0,"disableNative":false,"vibrateOnPush":true,"soundOnPush":true,"cycleMonitors":false,"cycleMonitorsInterval":10,"cycleMontage":false,"cycleMontageInterval":10,"enableLowBandwidth":false,"autoSwitchBandwidth":false,"refreshSecLowBW":8,"disableAlarmCheckMontage":false,"useLocalTimeZone":true,"fastLogin":true,"currentMontageProfile":"","followTimeLine":false,"timelineScale":27930,"showMontageSubMenu":false,"monSingleImageQuality":100,"hideArchived":false,"videoPlaybackSpeed":2,"enableGIFMP4":true,"enableSlowLoading":false,"enableStrictSSL":false}
Jul 1, 2017 05:58 PM INFO SlowDelay is: false
Jul 1, 2017 05:58 PM INFO Setting DataModel init bandwidth to: highbw
Jul 1, 2017 05:58 PM DEBUG timeline graph type not set. Setting to all
Jul 1, 2017 05:58 PM INFO user profile encrypted, decoding...
Jul 1, 2017 05:58 PM INFO Setting up pause and resume handler AFTER language is loaded...
Jul 1, 2017 05:58 PM INFO Setting up POST LOGIN timer
Jul 1, 2017 05:58 PM INFO Checking for news updates
Jul 1, 2017 05:58 PM INFO Checking for new version updates...
Jul 1, 2017 05:58 PM INFO No Event Server present. Not initializing
Jul 1, 2017 05:58 PM INFO ZMData init: checking for stored variables & setting up log file
Jul 1, 2017 05:58 PM INFO Language file loaded, continuing with rest
Jul 1, 2017 05:58 PM INFO >>>>Language to be used:en
Jul 1, 2017 05:58 PM INFO Device Language is:en
Jul 1, 2017 05:58 PM INFO Language stored as:en
Jul 1, 2017 05:58 PM INFO App Version: 1.2.41
Jul 1, 2017 05:58 PM INFO Retrieving language before init is called...
Jul 1, 2017 05:58 PM INFO Enabling native transitions...
2017-07-01T16:58:19.289Z INFO Updating statusbar
2017-07-01T16:58:19.282Z INFO >>>>No data to import....
2017-07-01T16:58:19.093Z INFO Reachable: No server name configured, likely first use?
2017-07-01T16:58:19.059Z DEBUG zmAutoLogin: Inside auth-error emit
2017-07-01T16:58:19.058Z INFO zmAutologin Error null and status 0
2017-07-01T16:58:19.051Z INFO ZM has recaptcha disabled - good
2017-07-01T16:58:18.882Z DEBUG text zoom factor is 1
2017-07-01T16:58:18.846Z INFO Checking if reCaptcha is enabled in ZM...
2017-07-01T16:58:18.838Z INFO zmAutologin called
2017-07-01T16:58:18.833Z DEBUG Resetting zmCookie...
2017-07-01T16:58:18.820Z INFO Your network is online, re-authenticating
2017-07-01T16:58:18.746Z INFO localforage driver for storage:asyncStorage
2017-07-01T16:58:18.066Z INFO You are running on android
zm.log:
Jul  1 16:17:58 rugrat zmc_m1[6675]: INF [Conservatory: 37000 - Capturing at 3.75 fps]
Jul  1 17:58:21 rugrat zmc_m4[28961]: INF [Starting Capture version 1.30.4]
Jul  1 17:58:22 rugrat zmc_m2[6688]: INF [Lounge: 98000 - Capturing at 6.02 fps]
Jul  1 17:58:22 rugrat zma_m2[6694]: INF [Lounge: 98000 - Analysing at 6.06 fps]
Jul  1 17:58:23 rugrat zmc_m9[6766]: INF [CatBowls: 168000 - Capturing at 7.87 fps]
Jul  1 17:58:23 rugrat zma_m9[6774]: INF [CatBowls: 168000 - Analysing at 7.94 fps]
Jul  1 17:58:37 rugrat web_php[28729]: INF [Login successful for user "admin"]
Jul  1 17:58:38 rugrat zma_m9[6774]: INF [CatBowls: 168138 - Gone into alarm state]
Jul  1 17:58:38 rugrat zma_m9[6774]: INF [CatBowls: 168138 - Opening new event 1733638, alarm start]
Jul  1 17:58:40 rugrat zma_m9[6774]: INF [CatBowls: 168154 - Gone into alert state]
Jul  1 17:58:41 rugrat zma_m9[6774]: INF [CatBowls: 168155 - Gone back into alarm state]
Jul  1 17:58:41 rugrat zma_m9[6774]: INF [CatBowls: 168156 - Gone into alert state]
Jul  1 17:58:42 rugrat zma_m9[6774]: INF [CatBowls: 168166 - Gone back into alarm state]
Jul  1 17:58:43 rugrat zma_m9[6774]: INF [CatBowls: 168168 - Gone into alert state]
Jul  1 17:58:43 rugrat zma_m9[6774]: INF [CatBowls: 168170 - Gone back into alarm state]
Jul  1 17:58:44 rugrat zmu[29006]: INF [Authenticated user 'admin']
Jul  1 17:58:44 rugrat zmu[29008]: INF [Authenticated user 'admin']
Jul  1 17:58:44 rugrat zmu[29010]: INF [Authenticated user 'admin']
Jul  1 17:58:44 rugrat zmu[29012]: INF [Authenticated user 'admin']
Jul  1 17:58:44 rugrat zmu[29014]: INF [Authenticated user 'admin']
Jul  1 17:58:44 rugrat zmu[29016]: INF [Authenticated user 'admin']
Jul  1 17:58:47 rugrat zma_m9[6774]: INF [CatBowls: 168204 - Gone into alert state]
Apache access log:
<clientip> - - [01/Jul/2017:17:58:37 +0100] "GET /zm HTTP/1.1" 401 470
<clientip> - - [01/Jul/2017:17:58:37 +0100] "POST /zm/index.php HTTP/1.1" 401 470
<clientip> - admin [01/Jul/2017:17:58:37 +0100] "GET /zm HTTP/1.1" 301 331
<clientip> - admin [01/Jul/2017:17:58:37 +0100] "POST /zm/index.php HTTP/1.1" 200 3643
<clientip> - admin [01/Jul/2017:17:58:37 +0100] "GET /zm/ HTTP/1.1" 200 3643
<clientip> - - [01/Jul/2017:17:58:38 +0100] "GET /zm/api/host/getVersion.json HTTP/1.1" 401 470
<clientip> - admin [01/Jul/2017:17:58:38 +0100] "GET /zm/api/host/getVersion.json HTTP/1.1" 200 40
<clientip> - - [01/Jul/2017:17:58:38 +0100] "GET /zm/api/configs/viewByName/ZM_EVENT_IMAGE_DIGITS.json HTTP/1.1" 401 470
<clientip> - - [01/Jul/2017:17:58:38 +0100] "GET /zm/api/host/getTimeZone.json HTTP/1.1" 401 470
<clientip> - admin [01/Jul/2017:17:58:38 +0100] "GET /zm/api/configs/viewByName/ZM_EVENT_IMAGE_DIGITS.json HTTP/1.1" 200 24
<clientip> - - [01/Jul/2017:17:58:38 +0100] "GET /zm/api/monitors.json HTTP/1.1" 401 470
<clientip> - admin [01/Jul/2017:17:58:38 +0100] "GET /zm/api/host/getTimeZone.json HTTP/1.1" 200 24
<clientip> - admin [01/Jul/2017:17:58:38 +0100] "GET /zm/api/monitors.json HTTP/1.1" 200 12384
<clientip> - - [01/Jul/2017:17:58:38 +0100] "GET /zm/api/servers.json HTTP/1.1" 401 470
<clientip> - admin [01/Jul/2017:17:58:38 +0100] "GET /zm/api/servers.json HTTP/1.1" 200 14
<clientip> - - [01/Jul/2017:17:58:39 +0100] "GET /zm/index.php?view=watch&mid=2&connkey=499579 HTTP/1.1" 401 470
<clientip> - admin [01/Jul/2017:17:58:39 +0100] "GET /zm/index.php?view=watch&mid=2&connkey=499579 HTTP/1.1" 200 2260
<clientip> - - [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:2/command:status.json HTTP/1.1" 401 470
<clientip> - - [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:1/command:status.json HTTP/1.1" 401 470
<clientip> - - [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:3/command:status.json HTTP/1.1" 401 470
<clientip> - - [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:5/command:status.json HTTP/1.1" 401 470
<clientip> - admin [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:2/command:status.json HTTP/1.1" 200 14
<clientip> - - [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:9/command:status.json HTTP/1.1" 401 470
<clientip> - - [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:6/command:status.json HTTP/1.1" 401 470
<clientip> - admin [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:3/command:status.json HTTP/1.1" 200 14
<clientip> - admin [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:1/command:status.json HTTP/1.1" 200 14
<clientip> - admin [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:5/command:status.json HTTP/1.1" 200 14
<clientip> - admin [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:6/command:status.json HTTP/1.1" 200 14
<clientip> - admin [01/Jul/2017:17:58:44 +0100] "GET /zm/api/monitors/alarm/id:9/command:status.json HTTP/1.1" 200 14
Apache error log:
[Sat Jul 01 17:58:37.951288 2017] [:error] [pid 28729] [client <clientip>:59102] INF [Login successful for user "admin"]
Does anything jump out as being amiss?
You mention Android and Chrome 59 - it looks like I am using v59 however it only updated yesterday. This is after the issues I've been seeing however, that said, it is actually v59.0.3071.125 that I am currently on so I suppose I may well have had an older version of v59 for some weeks prior?
With regards to authentication type I am using 'remote' and relay method 'none' (I am using HTTP basic authentication in Apache).
Posted: Sat Jul 01, 2017 5:25 pm
by MJN
P.S. I have just worked out that you are the author of zmNinja so let me take this opportunity to thank you for such a great app (and to apologise for breaking it!).
Posted: Sat Jul 01, 2017 5:28 pm
by asker
Your logs look normal.
I think that's the problem. The person who discovered this problem pointed to this bug in Chrome (that will apparently be fixed in v61). If you have to use basic auth, I don't think there is an option but to downgrade. Alternately, if you can do without basic auth, that is another option. Finally, if neither is an option, the only other solution I have is to give you access to a 'crosswalk build' that essentially bundles its own browser in the app, so you should not be affected (but then you won't be able to update/upgrade via play store)
My pleasure - glad you like the app - and you didn't break it - Chrome updates did :)
Posted: Sat Jul 01, 2017 10:32 pm
by MJN
Thank you Asker. The opportunity to try the 'crosswalk' build if that's okay as, assuming it confirms the Chrome bug as being the cause, it would at least tide me over until it is fixed in 61. I note the lack of updates via Play in the meantime but I can happily live with that.
Posted: Sun Jul 02, 2017 3:24 am
by asker
Okay, please send me an email - pliablepixels/gmail and I'll send you a link
Posted: Sun Jul 02, 2017 6:08 pm
by MJN
For the benefit of the forum, I rolled back Android System Webview to the as-supplied version on the my phone (Nexus 4) and zmNinja works again. As Asker suggested it is therefore indeed an issue with Chrome v59.
Posted: Sat Sep 30, 2017 7:36 pm
by gman
Unfortunately, they decided to go forward with the "fix" for 61 only.
And, even more unfortunately, 61 does not fix the event-view problem. (subressources with user:pass@server autocomplete).
Now, to get worse, my phone insists on updating the system, and I suspect to get some webview version being broken with zmninja. I don't know the last for sure, but don't want to take chances, because a rollback is just impossible.
Any other hints on this? Possibility to compile zmninja with appropriate flags for webview to disable this "subressource auth-autocomplete disable"?
Posted: Sat Sep 30, 2017 7:47 pm
by MJN
The crosswalk build (i.e. with the bundled browser) works for me, however I'm sure Asker doesn't want to keep sending out links to that as opposed to people updating via Play.
Posted: Sun Oct 01, 2017 11:56 am
by asker
I think Google folks are generally against using basic authentication for anything.
@gman, if you need the xwalk build, shoot me an email. If you can get rid of basic auth and just use OPT_AUTH (zm auth), that would solve the issue too and you could get updates automatically.
Re: ZmNinja recently stopped working after android update (Chrome issue)
Posted: Sun Oct 15, 2017 4:55 pm
by gman
Ups. Just read the answers today (forgot the notification check). Sorry for that.
Google folks should not mess with users choice, they should better write software with no problems in the first place. My whole site is basic auth (with some apache specials) and I cannot change my whole site just because some jerky nerd @ google thinks this might be wrong... :evil:
If I add zm-auth on top of basic auth - would it work? Will test and report first and if not, shoot an email to asker. Thanks for the offer.
Posted: Sun Oct 15, 2017 8:08 pm
by gman
As long as basic auth is on, it does not work, just for everybody to know.
Google sucks on this one, because it forces more complicated solutions to otherwise simple solutions. I actually do trust simple solutions (here: basic auth instead of many [different] site specific auth solutions just a little more. Reason is, that if one servie is compromised, most likely the whole system is compromised anyway. Hence, I prefer to have a strong and simple auth, instead of a zoo of different auth mechs/services, which nobody can control.
/rant off/
No offense towards zm-folks, it just works and blends perfectly in my other solutions. But my use case as a whole works only with basic auth in a way easy to maintain. I do not have a fully blown it department, but only myself.
So, I'll shoot an email to asker....
